* | Reflect POSIX sched_parm changes. | Ralf Corsepius | 2010-04-03 | 1 | -7/+7 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -1/+1 |
* | 2009-08-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-01 | 1 | -0/+8 |
| | | | | | | | * posix/src/psxtransschedparam.c, posix/src/pthread.c: Add error checks for 0 time on sporadic scheduler replenish period and initial budget. This avoids having to correct for it in the TSR, so we can eliminate the check for ticks == 0 there. | ||||
* | 2009-07-06 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-06 | 1 | -23/+23 |
| | | | | | * posix/src/psxtransschedparam.c: Restructure to avoid untestable code being generated by switch. | ||||
* | 2009-06-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-06-24 | 1 | -0/+65 |
* posix/Makefile.am, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/pthread.h, posix/inline/rtems/posix/priority.inl, posix/src/killinfo.c, posix/src/pthread.c, posix/src/pthreadcreate.c, posix/src/pthreadsetschedparam.c: Various modifications to improve binary code coverage analysis. Some of these are to mark code as debug only. Some are to break conditional expressions into multiple lines. Some are to move inline methods that are not time critical into subroutines to make them easier to test. Inlining them multiple times means that their logic paths are spread across multiple methods. This explodes the test cases required. * posix/src/psxpriorityisvalid.c, posix/src/psxtransschedparam.c: New files. |
