#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
A 32-bit Priority_Control limits the uptime to 49 days with a 1ms clock
tick in case the EDF scheduler is used. Increase it to 64-bit to enable
proper operation of the EDF scheduler,
Close 2173.
Introduce map/unmap priority scheduler operations to map thread priority
values from/to the user domain to/from the scheduler domain. Use the
map priority operation to validate the thread priority. The EDF
schedulers use this new operation to distinguish between normal
priorities and priorities obtain through a job release.
Update #2173.
Update #2556.
Move POSIX API priority validation into _POSIX_Priority_To_core().
Make _POSIX_Mutex_Default_attributes constant and independent of the
scheduler instance. Use INT_MAX to indicate the default ceiling
priority.
Move implementation specific parts of priority.h and priority.inl into
new header file priorityimpl.h. Remove priority.h since there is no
application visible API.
http://www.google-melange.com/gci/task/view/google/gci2012/7987220
* posix/Makefile.am, posix/include/rtems/posix/priority.h,
posix/inline/rtems/posix/priority.inl, posix/src/killinfo.c,
posix/src/pthread.c, posix/src/pthreadcreate.c,
posix/src/pthreadsetschedparam.c: Various modifications to improve
binary code coverage analysis. Some of these are to mark code as
debug only. Some are to break conditional expressions into multiple
lines. Some are to move inline methods that are not time critical
into subroutines to make them easier to test. Inlining them multiple
times means that their logic paths are spread across multiple
methods. This explodes the test cases required.
* posix/src/psxpriorityisvalid.c, posix/src/psxtransschedparam.c: New files.
