Updates #3053.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Turn pthread_spinlock_t into a self-contained object. On uni-processor
configurations, interrupts are disabled in the lock/trylock operations
and the previous interrupt status is restored in the corresponding
unlock operations. On SMP configurations, a ticket lock is a acquired
and released in addition.
The self-contained pthread_spinlock_t object is defined by Newlib in
<sys/_pthreadtypes.h>.
typedef struct {
struct _Ticket_lock_Control _lock;
__uint32_t _interrupt_state;
} pthread_spinlock_t;
This implementation is simple and efficient. However, this test case of
the Linux Test Project would fail due to call of printf() and sleep()
during spin lock ownership:
https://github.com/linux-test-project/ltp/blob/master/testcases/open_posix_testsuite/conformance/interfaces/pthread_spin_lock/1-2.c
There is only limited support for profiling on SMP configurations.
Delete CORE spinlock implementation.
Update #2674.
Use an ISR lock to protect the spinlock state. Remove empty attributes.
Update #2555.
Use allocator mutex for objects allocate/free. This prevents that the
thread dispatch latency depends on the workspace/heap fragmentation.
Move implementation specific parts of spinlock.h and spinlock.inl into
new header file spinlockimpl.h. The spinlock.h contains now only the
application visible API.
http://www.google-melange.com/gci/task/view/google/gci2012/7948216
Coverity Id 164/UNINIT
Coverity Id 165/UNINIT
* posix/src/prwlockinit.c, posix/src/pspininit.c,
score/include/rtems/score/corespinlock.h,
score/inline/rtems/score/corerwlock.inl,
score/inline/rtems/score/corespinlock.inl: Add initialization helpers
for score rwlock and spinlock. Use them from POSIX.
* itron/include/rtems/itron/object.h, itron/src/cre_tsk.c,
libblock/src/show_bdbuf.c, libmisc/capture/capture-cli.c,
libmisc/capture/capture.c, libmisc/monitor/mon-manager.c,
libmisc/stackchk/check.c, posix/src/condinit.c,
posix/src/keycreate.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueuenametoid.c,
posix/src/mqueueopen.c, posix/src/mqueueunlink.c,
posix/src/mutexinit.c, posix/src/pbarrierinit.c,
posix/src/pthreadcreate.c, posix/src/pthreadexit.c,
posix/src/semaphorecreatesupp.c, posix/src/semaphorenametoid.c,
posix/src/timercreate.c, rtems/src/barrierident.c,
rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c,
rtems/src/ratemonident.c, rtems/src/regionident.c,
rtems/src/semident.c, rtems/src/taskident.c, rtems/src/timerident.c,
sapi/src/extensionident.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/apimutexallocate.c,
score/src/objectextendinformation.c,
score/src/objectgetnameasstring.c, score/src/objectmp.c,
score/src/objectnametoid.c: Convert the Objects_Name type from a
* score/src/objectclearname.c, score/src/objectcomparenameraw.c,
score/src/objectcopynamestring.c: Removed.
* libcsupport/src/termios.c, posix/Makefile.am, posix/preinstall.am,
posix/include/rtems/posix/config.h, posix/include/rtems/posix/time.h,
sapi/src/posixapi.c, score/Makefile.am, score/preinstall.am,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/threadq.h,
score/src/corerwlockobtainread.c, score/src/threadqenqueue.c,
score/src/threadqtimeout.c: Adding POSIX barriers, POSIX spinlocks,
and partial implementation of POSIX rwlocks.
* posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/src/pbarrier.c, posix/src/pbarrierdestroy.c,
posix/src/pbarrierinit.c, posix/src/pbarriertranslatereturncode.c,
posix/src/pbarrierwait.c, posix/src/prwlock.c,
posix/src/prwlockdestroy.c, posix/src/prwlockinit.c,
posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c,
posix/src/prwlocktimedwrlock.c,
posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c,
posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c,
posix/src/prwlockwrlock.c, posix/src/pspin.c,
posix/src/pspindestroy.c, posix/src/pspininit.c,
posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c: New files.
