path: root/cpukit/posix/src/pspin.c (follow)
* Eliminate TRUE/FALSE.Ralf Corsepius2009-02-031-2/+2
* 2008-12-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-171-15/+10
| | | | | | | | | | | | | | | | | | | | * posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/spinlock.h, posix/include/rtems/posix/timer.h, posix/src/cond.c, posix/src/key.c, posix/src/mqueue.c, posix/src/mutex.c, posix/src/pbarrier.c, posix/src/prwlock.c, posix/src/psignal.c, posix/src/pspin.c, posix/src/pthread.c, posix/src/pthreadinitthreads.c, posix/src/ptimer.c, posix/src/semaphore.c, sapi/src/posixapi.c: Convert POSIX manager initialization routines to directly pull parameters from configuration table.
* include <limits.h>Ralf Corsepius2008-02-151-0/+2
* 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-01-311-2/+2
| | | | | | | | | | | | | | | | * posix/src/cond.c, posix/src/key.c, posix/src/mqueuenametoid.c, posix/src/mutex.c, posix/src/pbarrier.c, posix/src/prwlock.c, posix/src/pspin.c, posix/src/pthread.c, posix/src/ptimer.c, posix/src/semaphorenametoid.c: Add option for all POSIX objects whether named or unnamed to have a string name. If the API does not directly support having a name, then the user must explicitly assign it using rtems_object_set_name(). * rtems/src/rtemsobjectgetapiclassname.c: Improved testability. * score/include/rtems/score/object.h, score/src/objectgetnameasstring.c, score/src/objectnametoidstring.c, score/src/objectsetname.c: Modifications required to pass testing of recently modified object name operations. Also eliminated multiprocessing related code that was not reachable.
* 2006-11-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2006-11-151-0/+60
* libcsupport/src/termios.c, posix/Makefile.am, posix/preinstall.am, posix/include/rtems/posix/config.h, posix/include/rtems/posix/time.h, sapi/src/posixapi.c, score/Makefile.am, score/preinstall.am, score/include/rtems/score/corerwlock.h, score/include/rtems/score/threadq.h, score/src/corerwlockobtainread.c, score/src/threadqenqueue.c, score/src/threadqtimeout.c: Adding POSIX barriers, POSIX spinlocks, and partial implementation of POSIX rwlocks. * posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/spinlock.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/spinlock.inl, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/pbarrier.c, posix/src/pbarrierdestroy.c, posix/src/pbarrierinit.c, posix/src/pbarriertranslatereturncode.c, posix/src/pbarrierwait.c, posix/src/prwlock.c, posix/src/prwlockdestroy.c, posix/src/prwlockinit.c, posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c, posix/src/pspin.c, posix/src/pspindestroy.c, posix/src/pspininit.c, posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c, posix/src/pspintrylock.c, posix/src/pspinunlock.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c: New files.
