path: root/cpukit/posix/src/prwlocktrywrlock.c (follow)
* Whitespace removal.Ralf Corsepius2009-11-301-1/+1
* Eliminate TRUE/FALSE.Ralf Corsepius2009-02-031-1/+1
* Use C-style comments.Ralf Corsepius2008-07-291-1/+1
* 2007-11-30 Glenn Humphrey <glenn.humphrey@OARcorp.com>Glenn Humphrey2007-11-301-7/+7
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/semaphore.h, posix/src/cancel.c, posix/src/conddestroy.c, posix/src/condsignalsupp.c, posix/src/condwaitsupp.c, posix/src/keydelete.c, posix/src/keygetspecific.c, posix/src/keysetspecific.c, posix/src/mqueueclose.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetranslatereturncode.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c, posix/src/pbarrierdestroy.c, posix/src/pbarriertranslatereturncode.c, posix/src/pbarrierwait.c, posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c, posix/src/pspindestroy.c, posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c, posix/src/pspintrylock.c, posix/src/pspinunlock.c, posix/src/pthreaddetach.c, posix/src/pthreadequal.c, posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c, posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c, posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c, rtems/src/msgqtranslatereturncode.c, rtems/src/semobtain.c, rtems/src/timerfireafter.c, score/include/rtems/system.h, score/include/rtems/score/corebarrier.h, score/include/rtems/score/coremsg.h, score/include/rtems/score/coremutex.h, score/include/rtems/score/coresem.h: Restructed to move the OBJECTS_LOCAL case to the top of the switch statement and eliminate the fall-through return of POSIX_BOTTOM_REACHED. These changes produced simplier assembly code and allowed for complete test coverage. Also applied some consistency to the functions that translate the core status codes to POSIX status codes. * posix/src/mutextranslatereturncode.c, posix/src/semaphoretranslatereturncode.c: New files. * posix/src/mutexfromcorestatus.c: Removed.
* 2007-10-26 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-10-261-1/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * itron/src/can_wup.c, itron/src/chg_pri.c, itron/src/del_mbf.c, itron/src/del_mbx.c, itron/src/del_sem.c, itron/src/del_tsk.c, itron/src/frsm_tsk.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c, itron/src/ref_sem.c, itron/src/ref_tsk.c, itron/src/rel_wai.c, itron/src/rsm_tsk.c, itron/src/sig_sem.c, itron/src/snd_mbx.c, itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/ter_tsk.c, itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tsnd_mbf.c, itron/src/twai_sem.c, posix/src/cancel.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignalsupp.c, posix/src/condwaitsupp.c, posix/src/keydelete.c, posix/src/keygetspecific.c, posix/src/keysetspecific.c, posix/src/mqueueclose.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c, posix/src/pbarrierdestroy.c, posix/src/pbarrierwait.c, posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c, posix/src/pspindestroy.c, posix/src/pspinlock.c, posix/src/pspintrylock.c, posix/src/pspinunlock.c, posix/src/pthreaddetach.c, posix/src/pthreadequal.c, posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c, posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c, posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c, rtems/src/barrierdelete.c, rtems/src/barrierrelease.c, rtems/src/barrierwait.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmeminternal2external.c, rtems/src/eventsend.c, rtems/src/eventtimeout.c, rtems/src/msgqbroadcast.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partreturnbuffer.c, rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/signalsend.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskissuspended.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c, rtems/src/timercancel.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/extensiondelete.c, score/include/rtems/score/object.h, score/src/corerwlocktimeout.c, score/src/mpci.c, score/src/objectgetnameasstring.c, score/src/threaddelayended.c, score/src/threadqtimeout.c: When multiprocessing is disabled, do not even allow the constant OBJECTS_REMOTE to appear in the source. Even at -O2, the presence of a case OBJECTS_REMOTE in each id->pointer _Objects_Get switch results in the generation of binary code which can NOT be reached.
* 2006-11-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2006-11-151-0/+71
* libcsupport/src/termios.c, posix/Makefile.am, posix/preinstall.am, posix/include/rtems/posix/config.h, posix/include/rtems/posix/time.h, sapi/src/posixapi.c, score/Makefile.am, score/preinstall.am, score/include/rtems/score/corerwlock.h, score/include/rtems/score/threadq.h, score/src/corerwlockobtainread.c, score/src/threadqenqueue.c, score/src/threadqtimeout.c: Adding POSIX barriers, POSIX spinlocks, and partial implementation of POSIX rwlocks. * posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/spinlock.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/spinlock.inl, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/pbarrier.c, posix/src/pbarrierdestroy.c, posix/src/pbarrierinit.c, posix/src/pbarriertranslatereturncode.c, posix/src/pbarrierwait.c, posix/src/prwlock.c, posix/src/prwlockdestroy.c, posix/src/prwlockinit.c, posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c, posix/src/pspin.c, posix/src/pspindestroy.c, posix/src/pspininit.c, posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c, posix/src/pspintrylock.c, posix/src/pspinunlock.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c: New files.
