path: root/cpukit/posix/src/prwlockinit.c (follow)
* doxygen: Switch @brief and @ingroupSebastian Huber2020-04-281-1/+2
| | | | This order change fixes the Latex documentation build via Doxygen.
* posix: Implement self-contained POSIX rwlocksSebastian Huber2017-10-051-49/+32
| | | | | | | | POSIX rwlocks are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3115.
* posix: Allow PTHREAD_PROCESS_SHARED for rwlocksSebastian Huber2017-09-221-23/+7
| | | | Close #3153.
* score: Move thread queue MP callout to contextSebastian Huber2016-05-251-3/+3
| | | | | | | | Drop the multiprocessing (MP) dependent callout parameter from the thread queue extract, dequeue, flush and unblock methods. Merge this parameter with the lock context into new structure Thread_queue_Context. This helps to gets rid of the conditionally compiled method call helpers.
* posix: Add and use _POSIX_Get_object_body()Sebastian Huber2016-05-201-37/+7
* score: Optimize _Objects_Get_local()Sebastian Huber2016-05-021-2/+2
| | | | | Make the interrupt lock context the second parameter to avoid register moves.
* score: Avoid Giant lock for CORE rwlockSebastian Huber2016-04-221-15/+7
| | | | Update #2555.
* score: Delete unused CORE_RWLock_AttributesSebastian Huber2016-04-211-9/+1
* posix: Add auto initializaton for rwlockSebastian Huber2014-10-081-1/+51
* score: PR2152: Use allocator mutex for objectsSebastian Huber2014-03-311-7/+2
| | | | | Use allocator mutex for objects allocate/free. This prevents that the thread dispatch latency depends on the workspace/heap fragmentation.
* posix: Create rwlock implementation headerSebastian Huber2013-07-221-1/+1
| | | | | | Move implementation specific parts of rwlock.h and rwlock.inl into new header file rwlockimpl.h. The rwlock.h contains now only the application visible API.
* cpukit/posix: Doxygen group is POSIXAPIJoel Sherrill2013-01-101-1/+1
* posix: Doxygen Enhancement Task #3Ayush Awasthi2012-12-191-0/+7
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/8022219
* 2010-08-25 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-08-251-1/+3
| | | | | | | | | | Coverity Id 164/UNINIT Coverity Id 165/UNINIT * posix/src/prwlockinit.c, posix/src/pspininit.c, score/include/rtems/score/corespinlock.h, score/inline/rtems/score/corerwlock.inl, score/inline/rtems/score/corespinlock.inl: Add initialization helpers for score rwlock and spinlock. Use them from POSIX.
* 2008-08-15 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-08-151-2/+2
| | | | | PR 1297/cpukit * posix/src/prwlockinit.c: Fix NULL attribute pointer handling.
* 2008-01-23 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-01-231-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * itron/include/rtems/itron/object.h, itron/src/cre_tsk.c, libblock/src/show_bdbuf.c, libmisc/capture/capture-cli.c, libmisc/capture/capture.c, libmisc/monitor/mon-manager.c, libmisc/stackchk/check.c, posix/src/condinit.c, posix/src/keycreate.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuenametoid.c, posix/src/mqueueopen.c, posix/src/mqueueunlink.c, posix/src/mutexinit.c, posix/src/pbarrierinit.c, posix/src/prwlockinit.c, posix/src/pspininit.c, posix/src/pthreadcreate.c, posix/src/pthreadexit.c, posix/src/semaphorecreatesupp.c, posix/src/semaphorenametoid.c, posix/src/timercreate.c, rtems/src/barrierident.c, rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c, rtems/src/ratemonident.c, rtems/src/regionident.c, rtems/src/semident.c, rtems/src/taskident.c, rtems/src/timerident.c, sapi/src/extensionident.c, score/Makefile.am, score/include/rtems/score/object.h, score/inline/rtems/score/object.inl, score/src/apimutexallocate.c, score/src/objectextendinformation.c, score/src/objectgetnameasstring.c, score/src/objectmp.c, score/src/objectnametoid.c: Convert the Objects_Name type from a simple type to a union of an unsigned 32 bit integer and a pointer. This should help eliminate weird casts between u32 and pointers in various places. The APIs now have to explicitly call _u32 or _string versions of helper routines. This should also simplify things and eliminate the need for ugly casts in some cases. * score/src/objectclearname.c, score/src/objectcomparenameraw.c, score/src/objectcomparenamestring.c, score/src/objectcopynameraw.c, score/src/objectcopynamestring.c: Removed.
* 2007-11-06 Glenn Humphrey <glenn.humphrey@OARcorp.com>Glenn Humphrey2007-11-061-9/+27
| | | | | | | | | | | | | | | | Miscellaneous changes made after a review against the POSIX spec. * posix/src/pbarrierinit.c, posix/src/prwlockinit.c: If the caller passes a NULL in the attributes parameter, default attributes are used. * posix/src/prwlockdestroy.c: If there is at least one thread waiting, do not allow deletion. * posix/src/prwlockwrlock.c: Corrected parameter passed to the core operation used to obtain a RWLock for writing. * posix/src/pspinlocktranslatereturncode.c, score/include/rtems/score/corespinlock.h, score/src/corespinlockrelease.c: If the current thread is not the holder of the lock, do not allow an unlock and return EPERM. * score/src/corerwlockobtainwrite.c: Corrected to use the operation for queueing with a timeout handler.
* 2006-11-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2006-11-151-0/+90
* libcsupport/src/termios.c, posix/Makefile.am, posix/preinstall.am, posix/include/rtems/posix/config.h, posix/include/rtems/posix/time.h, sapi/src/posixapi.c, score/Makefile.am, score/preinstall.am, score/include/rtems/score/corerwlock.h, score/include/rtems/score/threadq.h, score/src/corerwlockobtainread.c, score/src/threadqenqueue.c, score/src/threadqtimeout.c: Adding POSIX barriers, POSIX spinlocks, and partial implementation of POSIX rwlocks. * posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/spinlock.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/spinlock.inl, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/pbarrier.c, posix/src/pbarrierdestroy.c, posix/src/pbarrierinit.c, posix/src/pbarriertranslatereturncode.c, posix/src/pbarrierwait.c, posix/src/prwlock.c, posix/src/prwlockdestroy.c, posix/src/prwlockinit.c, posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c, posix/src/pspin.c, posix/src/pspindestroy.c, posix/src/pspininit.c, posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c, posix/src/pspintrylock.c, posix/src/pspinunlock.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c: New files.
