Move implementation specific parts of rwlock.h and rwlock.inl into new
header file rwlockimpl.h. The rwlock.h contains now only the
application visible API.
* posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/cond.h, posix/include/rtems/posix/key.h,
posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/spinlock.h,
posix/include/rtems/posix/timer.h, posix/src/cond.c, posix/src/key.c,
posix/src/mqueue.c, posix/src/mutex.c, posix/src/pbarrier.c,
posix/src/prwlock.c, posix/src/psignal.c, posix/src/pspin.c,
posix/src/pthread.c, posix/src/pthreadinitthreads.c,
posix/src/ptimer.c, posix/src/semaphore.c, sapi/src/posixapi.c:
Convert POSIX manager initialization routines to directly pull
parameters from configuration table.
* posix/src/cond.c, posix/src/key.c, posix/src/mqueuenametoid.c,
posix/src/mutex.c, posix/src/pbarrier.c, posix/src/prwlock.c,
posix/src/pspin.c, posix/src/pthread.c, posix/src/ptimer.c,
posix/src/semaphorenametoid.c: Add option for all POSIX objects
whether named or unnamed to have a string name. If the API does
not directly support having a name, then the user must explicitly
assign it using rtems_object_set_name().
* rtems/src/rtemsobjectgetapiclassname.c: Improved testability.
* score/include/rtems/score/object.h,
score/src/objectgetnameasstring.c, score/src/objectnametoidstring.c,
score/src/objectsetname.c: Modifications required to pass testing of
recently modified object name operations. Also eliminated
multiprocessing related code that was not reachable.
* libcsupport/src/termios.c, posix/Makefile.am, posix/preinstall.am,
posix/include/rtems/posix/config.h, posix/include/rtems/posix/time.h,
sapi/src/posixapi.c, score/Makefile.am, score/preinstall.am,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/threadq.h,
score/src/corerwlockobtainread.c, score/src/threadqenqueue.c,
score/src/threadqtimeout.c: Adding POSIX barriers, POSIX spinlocks,
and partial implementation of POSIX rwlocks.
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/src/pbarrier.c, posix/src/pbarrierdestroy.c,
posix/src/pbarrierinit.c, posix/src/pbarriertranslatereturncode.c,
posix/src/pbarrierwait.c, posix/src/prwlock.c,
posix/src/prwlockdestroy.c, posix/src/prwlockinit.c,
posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c,
posix/src/prwlocktimedwrlock.c,
posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c,
posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c,
posix/src/prwlockwrlock.c, posix/src/pspin.c,
posix/src/pspindestroy.c, posix/src/pspininit.c,
posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c: New files.
