* posix/src/nanosleep.c: Include rtems/score/timespec.h instead of
rtems/posix/time.h.
* posix/Makefile.am, posix/include/rtems/posix/time.h,
posix/src/adjtime.c, posix/src/alarm.c, posix/src/clockgetres.c,
posix/src/condtimedwait.c, posix/src/mqueuetimedreceive.c,
posix/src/mqueuetimedsend.c, posix/src/mutextimedlock.c,
posix/src/nanosleep.c, posix/src/posixtimespecabsolutetimeout.c,
posix/src/pthread.c, posix/src/pthreadcreate.c,
posix/src/pthreadsetschedparam.c, posix/src/ptimer1.c,
posix/src/sched.c, posix/src/semtimedwait.c,
posix/src/sigtimedwait.c, posix/src/ualarm.c,
rtems/src/clocktodtoseconds.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/tod.h,
score/inline/rtems/score/tod.inl, score/src/coretod.c,
score/src/coretodget.c, score/src/coretodgetuptime.c,
score/src/coretodset.c, score/src/coretodtickle.c: Provide timespec
manipulation routines in the SuperCore. Use them everywhere possible.
This lead to significant cleanup in the API routines and eliminated
some of the same code from the POSIX API. At this point, the
SuperCore keeps time in POSIX timespec format properly from 1970. You
just cannot set it before 1988 in keeping with RTEMS traditional
behavior.
* score/include/rtems/score/timespec.h, score/src/timespecaddto.c,
score/src/timespecfromticks.c, score/src/timespecisvalid.c,
score/src/timespeclessthan.c, score/src/timespecsubtract.c,
score/src/timespectoticks.c: New files.
* posix/src/posixintervaltotimespec.c,
posix/src/posixtimespecsubtract.c,
posix/src/posixtimespectointerval.c: Removed.
* itron/src/itrontime.c, libcsupport/src/__gettod.c,
posix/src/clockgettime.c, posix/src/clocksettime.c,
posix/src/nanosleep.c, posix/src/posixtimespecsubtract.c,
posix/src/posixtimespectointerval.c, posix/src/ptimer1.c,
posix/src/sleep.c, rtems/Makefile.am,
rtems/include/rtems/rtems/clock.h, rtems/include/rtems/rtems/timer.h,
rtems/include/rtems/rtems/types.h, rtems/src/clockget.c,
rtems/src/clockset.c, rtems/src/clocktodtoseconds.c,
rtems/src/clocktodvalidate.c, rtems/src/taskwakewhen.c,
score/Makefile.am, score/include/rtems/score/tod.h,
score/src/coretodset.c: Convert from Classic API style TOD_Control as
fundamental time structure to POSIX struct timespec. Add
clock_get_uptime().
* rtems/src/clockgetuptime.c, score/src/coretodget.c,
score/src/coretodgetuptime.c: New files.
* score/src/coretodtickle.c, score/src/coretodtoseconds.c,
score/src/coretodvalidate.c: Removed.
PR 1231/cpukit
* posix/src/adasupp.c, posix/src/clockgetcpuclockid.c,
posix/src/clockgetenableattr.c, posix/src/clockgetres.c,
posix/src/clockgettime.c, posix/src/clocksetenableattr.c,
posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexlock.c,
posix/src/mutexlocksupp.c, posix/src/mutexmp.c,
posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c,
posix/src/mutextrylock.c, posix/src/mutexunlock.c,
posix/src/nanosleep.c, posix/src/posixintervaltotimespec.c,
posix/src/psignalunblockthread.c, posix/src/ptimer.c,
posix/src/ptimer1.c, posix/src/sched.c, posix/src/time.c: Remove
unneeded includes of assert.h
* src/clockgetres.c: Apply rtems_set_errno_and_return_minus_one.
* src/clockgettime.c: Apply rtems_set_errno_and_return_minus_one.
* src/clocksettime.c: Apply rtems_set_errno_and_return_minus_one.
* src/killinfo.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueueclose.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuecreatesupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuegetattr.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuenotify.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueueopen.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuerecvsupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuesendsupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuesetattr.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueueunlink.c: Apply rtems_set_errno_and_return_minus_one.
* src/nanosleep.c: Apply rtems_set_errno_and_return_minus_one.
* src/pthreadkill.c: Apply rtems_set_errno_and_return_minus_one.
* src/pthreadsigmask.c: Apply rtems_set_errno_and_return_minus_one.
* src/ptimer1.c: Apply rtems_set_errno_and_return_minus_one.
* src/sched.c: Apply rtems_set_errno_and_return_minus_one.
* src/semaphorecreatesupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/semaphorewaitsupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/semclose.c: Apply rtems_set_errno_and_return_minus_one.
* src/semdestroy.c: Apply rtems_set_errno_and_return_minus_one.
* src/semgetvalue.c: Apply rtems_set_errno_and_return_minus_one.
* src/seminit.c: Apply rtems_set_errno_and_return_minus_one.
* src/semopen.c: Apply rtems_set_errno_and_return_minus_one.
* src/sempost.c: Apply rtems_set_errno_and_return_minus_one.
* src/semunlink.c: Apply rtems_set_errno_and_return_minus_one.
* src/setpgid.c: Apply rtems_set_errno_and_return_minus_one.
* src/setsid.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigaction.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigaddset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigdelset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigemptyset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigfillset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigismember.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigpending.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigtimedwait.c: Apply rtems_set_errno_and_return_minus_one.
* src/utsname.c: Apply rtems_set_errno_and_return_minus_one.
all APIs.
