path: root/cpukit/posix/src/mutexsetprioceiling.c (follow)
* doxygen: Switch @brief and @ingroupSebastian Huber2020-04-281-1/+2
| | | | This order change fixes the Latex documentation build via Doxygen.
* posix: Implement self-contained POSIX mutexSebastian Huber2017-10-051-7/+9
| | | | | | | | POSIX mutexes are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3112.
* score: Initialize thread queue context earlySebastian Huber2016-12-021-0/+2
| | | | | | | | Initialize thread queue context early preferably outside the critical section. Remove implicit _Thread_queue_Context_initialize() from _Thread_Wait_acquire().
* score: Fix thread queue context initializationSebastian Huber2016-11-281-1/+0
| | | | | Initialize the thread queue context with invalid data in debug configurations to catch missing set up steps.
* score: Rework thread priority managementSebastian Huber2016-09-211-1/+12
| | | | | | | | | | | | | | | | | | | | | | | | | Add priority nodes which contribute to the overall thread priority. The actual priority of a thread is now an aggregation of priority nodes. The thread priority aggregation for the home scheduler instance of a thread consists of at least one priority node, which is normally the real priority of the thread. The locking protocols (e.g. priority ceiling and priority inheritance), rate-monotonic period objects and the POSIX sporadic server add, change and remove priority nodes. A thread changes its priority now immediately, e.g. priority changes are not deferred until the thread releases its last resource. Replace the _Thread_Change_priority() function with * _Thread_Priority_perform_actions(), * _Thread_Priority_add(), * _Thread_Priority_remove(), * _Thread_Priority_change(), and * _Thread_Priority_update(). Update #2412. Update #2556.
* score: Introduce map priority scheduler operationSebastian Huber2016-06-221-17/+22
| | | | | | | | | | | Introduce map/unmap priority scheduler operations to map thread priority values from/to the user domain to/from the scheduler domain. Use the map priority operation to validate the thread priority. The EDF schedulers use this new operation to distinguish between normal priorities and priorities obtain through a job release. Update #2173. Update #2556.
* posix: Generalize _POSIX_Priority_To_core()Sebastian Huber2016-06-221-5/+4
| | | | Move POSIX API priority validation into _POSIX_Priority_To_core().
* posix: Make POSIX API aware of scheduler instancesSebastian Huber2016-06-221-13/+22
* score: Rework CORE priority ceiling mutexSebastian Huber2016-05-301-3/+2
| | | | | Rework seize and surrender methods to use CORE_ceiling_mutex_Control. This eliminates CORE_mutex_Disciplines.
* score: Add CORE mutex variantsSebastian Huber2016-05-301-2/+3
| | | | | | | | Add CORE_recursive_mutex_Control and CORE_ceiling_mutex_Control to avoid the run-time evaluation of attributes to figure out how a particular mutex methods should behave. Start with the no protocol variants. This eliminates the CORE_MUTEX_DISCIPLINES_FIFO and CORE_MUTEX_DISCIPLINES_PRIORITY disciplines.
* posix: Avoid use of internal mutex methodsSebastian Huber2016-05-301-21/+10
| | | | Avoid use of internal mutex methods for pthread_mutex_setprioceiling().
* score: Move thread queue MP callout to contextSebastian Huber2016-05-251-4/+3
| | | | | | | | Drop the multiprocessing (MP) dependent callout parameter from the thread queue extract, dequeue, flush and unblock methods. Merge this parameter with the lock context into new structure Thread_queue_Context. This helps to gets rid of the conditionally compiled method call helpers.
* score: Get rid of mp_id parameterSebastian Huber2016-05-251-1/+0
| | | | | Get rid of the mp_id parameter used for some thread queue methods. Use THREAD_QUEUE_QUEUE_TO_OBJECT() instead.
* Replace *_Get_interrupt_disable() with *_Get()Sebastian Huber2016-05-201-1/+1
| | | | | Uniformly use *_Get() to get an object by identifier with a lock context.
* posix: Avoid Giant lock for mutexesSebastian Huber2016-04-211-0/+1
| | | | | | | Delete _POSIX_Mutex_Get(). Use _POSIX_Mutex_Get_interrupt_disable() instead. Update #2555.
* posix: Simplify _POSIX_Mutex_Get_interrupt_disableSebastian Huber2016-04-211-37/+18
| | | | Remove superfluous location parameter.
* score: Rework MP thread queue callout supportSebastian Huber2016-04-061-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | The thread queue implementation was heavily reworked to support SMP. This broke the multiprocessing support of the thread queues. This is fixed by this patch. A thread proxy is unblocked due to three reasons 1) timeout, 2) request satisfaction, and 3) extraction. In case 1) no MPCI message must be sent. This is ensured via the _Thread_queue_MP_callout_do_nothing() callout set during _Thread_MP_Allocate_proxy(). In case 2) and 3) an MPCI message must be sent. In case we interrupt the blocking operation during _Thread_queue_Enqueue_critical(), then this message must be sent by the blocking thread. For this the new fields Thread_Proxy_control::thread_queue_callout and Thread_Proxy_control::thread_queue_id are used. Delete the individual API MP callout types and use Thread_queue_MP_callout throughout. This type is only defined in multiprocessing configurations. Prefix the multiprocessing parameters with mp_ to ease code review. Multiprocessing specific parameters are optional due to use of a similar macro pattern. There is no overhead for non-multiprocessing configurations.
* score: Rename _POSIX_Absolute_timeout_to_ticks()Sebastian Huber2015-07-281-1/+0
| | | | | | Rename _POSIX_Absolute_timeout_to_ticks() to _TOD_Absolute_timeout_to_ticks() and move it to the score directory. Delete empty <rtems/posix/time.h>.
* score: Fine grained locking for mutexesSebastian Huber2015-05-191-3/+8
| | | | Update #2273.
* posix: Create priority implementation headerSebastian Huber2013-07-221-1/+1
| | | | | | Move implementation specific parts of priority.h and priority.inl into new header file priorityimpl.h. Remove priority.h since there is no application visible API.
* score: Create mutex implementation headerSebastian Huber2013-07-181-1/+1
| | | | | | Move implementation specific parts of coremutex.h and coremutex.inl into new header file coremuteximpl.h. The coremutex.h contains now only the application visible API.
* posix: Create mutex implementation headerSebastian Huber2013-07-181-1/+1
| | | | | | Move implementation specific parts of mutex.h and mutex.inl into new header file muteximpl.h. The mutex.h contains now only the application visible API.
* score: Add and use _Objects_Put()Sebastian Huber2013-06-071-1/+1
| | | | | | Add and use _Objects_Put_without_thread_dispatch(). These two functions pair with the _Objects_Get() function. This helps to introduce object specific SMP locks to avoid lock contention.
* cpukit/posix: Doxygen group is POSIXAPIJoel Sherrill2013-01-101-1/+1
* posix: Doxygen Enhancement Task #3Ayush Awasthi2012-12-191-0/+7
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/8022219
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script.
* 2009-07-07 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-07-071-2/+1
| | | | * ChangeLog, posix/src/mutexsetprioceiling.c: Remove warning.
* 2009-07-07 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-07-071-5/+15
| | | | | | | * posix/src/mutexsetprioceiling.c: Restructure to eliminate code paths which are unreachable. Also add more comments. * score/src/coremutexsurrender.c: Mark some code as RTEMS_DEBUG only since it cannot be hit unless coremutexseize.c is broken.
* 2007-12-17 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-171-0/+7
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * posix/preinstall.am, posix/include/aio.h, posix/include/devctl.h, posix/include/mqueue.h, posix/include/sched.h, posix/include/semaphore.h, posix/include/rtems/posix/cancel.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/priority.inl, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cancel.c, posix/src/cancelrun.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/key.c, posix/src/keycreate.c, posix/src/keydelete.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mqueue.c, posix/src/mqueueclose.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenametoid.c, posix/src/mqueuenotify.c, posix/src/mqueueopen.c, posix/src/mqueuereceive.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/ptimer.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/setcancelstate.c, posix/src/setcanceltype.c, posix/src/sysconf.c, posix/src/testcancel.c: Add missing copyright statements.
* 2007-12-03 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-031-7/+0
| | | | | | | | | | | | | | | | | | | | | | | * libcsupport/src/malloc.c, libmisc/monitor/mon-command.c, posix/preinstall.am, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/semaphore.h, posix/src/conddestroy.c, posix/src/mutexdestroy.c, posix/src/mutexinit.c, posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c, sapi/include/confdefs.h, sapi/include/rtems/config.h, sapi/include/rtems/init.h, sapi/include/rtems/sptables.h, sapi/src/exinit.c, score/include/rtems/system.h, score/include/rtems/score/mpci.h, score/src/mpci.c, score/src/thread.c, score/src/threadcreateidle.c, score/src/threadstackallocate.c, score/src/threadstackfree.c, score/src/wkspace.c: Moved most of the remaining CPU Table fields to the Configuration Table. This included pretasking_hook, predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace, extra_mpci_receive_server_stack, stack_allocate_hook, and stack_free_hook. As a side-effect of this effort some multiprocessing code was made conditional and some style clean up occurred.
* 2007-11-30 Glenn Humphrey <glenn.humphrey@OARcorp.com>Glenn Humphrey2007-11-301-6/+9
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/semaphore.h, posix/src/cancel.c, posix/src/conddestroy.c, posix/src/condsignalsupp.c, posix/src/condwaitsupp.c, posix/src/keydelete.c, posix/src/keygetspecific.c, posix/src/keysetspecific.c, posix/src/mqueueclose.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetranslatereturncode.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c, posix/src/pbarrierdestroy.c, posix/src/pbarriertranslatereturncode.c, posix/src/pbarrierwait.c, posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c, posix/src/pspindestroy.c, posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c, posix/src/pspintrylock.c, posix/src/pspinunlock.c, posix/src/pthreaddetach.c, posix/src/pthreadequal.c, posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c, posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c, posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c, rtems/src/msgqtranslatereturncode.c, rtems/src/semobtain.c, rtems/src/timerfireafter.c, score/include/rtems/system.h, score/include/rtems/score/corebarrier.h, score/include/rtems/score/coremsg.h, score/include/rtems/score/coremutex.h, score/include/rtems/score/coresem.h: Restructed to move the OBJECTS_LOCAL case to the top of the switch statement and eliminate the fall-through return of POSIX_BOTTOM_REACHED. These changes produced simplier assembly code and allowed for complete test coverage. Also applied some consistency to the functions that translate the core status codes to POSIX status codes. * posix/src/mutextranslatereturncode.c, posix/src/semaphoretranslatereturncode.c: New files. * posix/src/mutexfromcorestatus.c: Removed.
* 2007-11-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-11-281-2/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * posix/Makefile.am, posix/preinstall.am, posix/src/cancel.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignalsupp.c, posix/src/condwaitsupp.c, posix/src/mqueueclose.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueueunlink.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c, posix/src/semaphorecreatesupp.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/semunlink.c, posix/src/types.c, score/cpu/powerpc/rtems/old-exceptions/cpu.h: Remove all pretense of POSIX MP support. The support in place was only a shell. This should make maintenance easier. * posix/include/rtems/posix/condmp.h, posix/include/rtems/posix/mqueuemp.h, posix/include/rtems/posix/mutexmp.h, posix/include/rtems/posix/pthreadmp.h, posix/include/rtems/posix/semaphoremp.h, posix/src/condmp.c, posix/src/mutexmp.c, posix/src/semaphoremp.c: Removed.
* 2007-10-26 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-10-261-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * itron/src/can_wup.c, itron/src/chg_pri.c, itron/src/del_mbf.c, itron/src/del_mbx.c, itron/src/del_sem.c, itron/src/del_tsk.c, itron/src/frsm_tsk.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c, itron/src/ref_sem.c, itron/src/ref_tsk.c, itron/src/rel_wai.c, itron/src/rsm_tsk.c, itron/src/sig_sem.c, itron/src/snd_mbx.c, itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/ter_tsk.c, itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tsnd_mbf.c, itron/src/twai_sem.c, posix/src/cancel.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignalsupp.c, posix/src/condwaitsupp.c, posix/src/keydelete.c, posix/src/keygetspecific.c, posix/src/keysetspecific.c, posix/src/mqueueclose.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c, posix/src/pbarrierdestroy.c, posix/src/pbarrierwait.c, posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c, posix/src/pspindestroy.c, posix/src/pspinlock.c, posix/src/pspintrylock.c, posix/src/pspinunlock.c, posix/src/pthreaddetach.c, posix/src/pthreadequal.c, posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c, posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c, posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c, rtems/src/barrierdelete.c, rtems/src/barrierrelease.c, rtems/src/barrierwait.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmeminternal2external.c, rtems/src/eventsend.c, rtems/src/eventtimeout.c, rtems/src/msgqbroadcast.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partreturnbuffer.c, rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/signalsend.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskissuspended.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c, rtems/src/timercancel.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/extensiondelete.c, score/include/rtems/score/object.h, score/src/corerwlocktimeout.c, score/src/mpci.c, score/src/objectgetnameasstring.c, score/src/threaddelayended.c, score/src/threadqtimeout.c: When multiprocessing is disabled, do not even allow the constant OBJECTS_REMOTE to appear in the source. Even at -O2, the presence of a case OBJECTS_REMOTE in each id->pointer _Objects_Get switch results in the generation of binary code which can NOT be reached.
* 2007-03-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-03-261-1/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | PR 1231/cpukit * posix/src/adasupp.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexmp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/posixintervaltotimespec.c, posix/src/posixtimespecsubtract.c, posix/src/posixtimespectointerval.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/ptimer.c, posix/src/ptimer1.c, posix/src/sched.c, posix/src/time.c: Remove unneeded includes of assert.h
* Remove stray white spaces.Ralf Corsepius2004-04-161-1/+1
* 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-241-0/+4
| | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
* Made sure POSIX would build with MP enabled.Joel Sherrill1999-11-291-1/+1
* Split time.c into multiple files.Joel Sherrill1999-11-021-8/+49
* Split mutex.c into multiple files.Joel Sherrill1999-11-021-0/+37
