#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Rename _POSIX_Absolute_timeout_to_ticks() to
_TOD_Absolute_timeout_to_ticks() and move it to the score directory.
Delete empty <rtems/posix/time.h>.
Move implementation specific parts of priority.h and priority.inl into
new header file priorityimpl.h. Remove priority.h since there is no
application visible API.
Move implementation specific parts of coremutex.h and coremutex.inl into
new header file coremuteximpl.h. The coremutex.h contains now only the
Move implementation specific parts of mutex.h and mutex.inl into new
header file muteximpl.h. The mutex.h contains now only the application
visible API.
http://www.google-melange.com/gci/task/view/google/gci2012/7987220
* posix/Makefile.am, posix/src/mutex.c, posix/src/mutexinit.c: Add
initial support for the pthread mutex type attribute added by UNIX98.
It can be normal, recursive, errorcheck or default.
* posix/src/mutexattrgettype.c, posix/src/mutexattrsettype.c: New files.
