#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
The top-level IO library structures should contain no special-case data.
Update #2859.
Use the libio mutex lock instead of the mmap mappings lock.
Updates #2859.
Operarations are already protected by mmap_mappings_lock.
Updates #2859.
Added a mmap file handler to struct _rtems_filesystem_file_handlers_r.
Updated each file handler object to support the default mmap handler.
Updated mmap() to call the mmap handler for MAP_SHARED.
Added a mmap file handler for shm
Added support for MAP_ANON in mmap().
Updates #2859
Update #2859.
This version of mmap comes from early work done
on the RTL code base circa 2012.
Update #2859.
mmap was previously in munmap.c and munmap was in mmap.c.
* Makefile.am updated and preinstall.am regenerated.
* mprotect.c had a prototype removed now that we have mman.h
* mmap.c, munmap.c: New stub files.
