path: root/cpukit/posix/src/mqueue.c (follow)
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-301-1/+1
| | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs.
* Split mqueue.c into a variety of files.Joel Sherrill1999-11-021-672/+0
* Added name to id support routine.Joel Sherrill1999-11-011-0/+15
* Now compiles and is included in normal build even though it is untested.Joel Sherrill1999-04-151-35/+39
| | | | Added multiprocessing conditional.
* changed code which set errno and then returned -1 to use the macroJoel Sherrill1996-06-071-10/+6
| | | | set_errno_and_return_minus_one.
* renamed _POSIX_Time_Spec_to_interval to _POSIX_Timespec_to_intervalJoel Sherrill1996-06-031-2/+2
* comment clean upJoel Sherrill1996-05-291-2/+1
* These files have been modified in the initial pass at getting the portionJoel Sherrill1996-05-221-1/+1
| | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have.
* fixed missing CVS IDsJoel Sherrill1995-10-061-0/+2
* posix support initially addedJoel Sherrill1995-09-261-0/+713
