Yields higher performance on SMP systems.
Close #2625.
Remove compare function and is unique indicator from the control
structure. Rename RBTree_Compare_function to RBTree_Compare. Rename
rtems_rbtree_compare_function to rtems_rbtree_compare. Provide C++
compatible initializers. Add compare function and is unique indicator
to _RBTree_Find(), _RBTree_Insert(), rtems_rbtree_find() and
rtems_rbtree_insert(). Remove _RBTree_Is_unique() and
rtems_rbtree_is_unique(). Remove compare function and is unique
indicator from _RBTree_Initialize_empty() and
rtems_rbtree_initialize_empty().
Move implementation specific parts of key.h and key.inl into new header
file keyimpl.h. The key.h contains now only the application visible
API.
This patch enables unlimited model in POSIX key manger and have a decent
runtime on POSIX key searching, adding and deleting operations. Memory
overhead is lower than current implementation when the size of key and key
value becomes big.
Add and use _Objects_Put_without_thread_dispatch(). These two functions
pair with the _Objects_Get() function. This helps to introduce object
specific SMP locks to avoid lock contention.
http://www.google-melange.com/gci/task/view/google/gci2012/7958218
* posix/preinstall.am, posix/include/aio.h, posix/include/devctl.h,
posix/include/mqueue.h, posix/include/sched.h,
posix/include/semaphore.h, posix/include/rtems/posix/cancel.h,
posix/include/rtems/posix/timer.h,
posix/src/cancel.c, posix/src/cancelrun.c, posix/src/cleanuppop.c,
posix/src/cleanuppush.c, posix/src/cond.c,
posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c,
posix/src/condattrinit.c, posix/src/condattrsetpshared.c,
posix/src/condbroadcast.c, posix/src/conddefaultattributes.c,
posix/src/conddestroy.c, posix/src/condinit.c,
posix/src/condsignal.c, posix/src/condsignalsupp.c,
posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/key.c,
posix/src/keycreate.c, posix/src/keydelete.c,
posix/src/keysetspecific.c, posix/src/mqueue.c,
posix/src/mqueueclose.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c,
posix/src/mqueuenametoid.c, posix/src/mqueuenotify.c,
posix/src/mqueueopen.c, posix/src/mqueuereceive.c,
posix/src/mqueuerecvsupp.c, posix/src/mqueuesend.c,
posix/src/mqueueunlink.c, posix/src/mutex.c,
posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c,
posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexlock.c,
posix/src/mutextrylock.c, posix/src/mutexunlock.c,
posix/src/psignal.c, posix/src/psignalchecksignal.c,
posix/src/psignalunblockthread.c, posix/src/ptimer.c,
posix/src/sempost.c, posix/src/semtrywait.c, posix/src/semunlink.c,
posix/src/semwait.c, posix/src/setcancelstate.c,
posix/src/setcanceltype.c, posix/src/sysconf.c,
posix/src/testcancel.c: Add missing copyright statements.
* posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/semaphore.h, posix/src/cancel.c,
posix/src/conddestroy.c, posix/src/condsignalsupp.c,
posix/src/condwaitsupp.c, posix/src/keydelete.c,
posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/mqueueclose.c, posix/src/mqueuegetattr.c,
posix/src/mqueuetranslatereturncode.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c,
posix/src/mutexunlock.c, posix/src/pbarrierdestroy.c,
posix/src/pbarriertranslatereturncode.c, posix/src/pbarrierwait.c,
posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c,
posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c,
posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c,
posix/src/prwlockwrlock.c, posix/src/pspindestroy.c,
posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/pthreaddetach.c, posix/src/pthreadequal.c,
posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c,
posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c,
posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c,
rtems/src/msgqtranslatereturncode.c, rtems/src/semobtain.c,
rtems/src/timerfireafter.c, score/include/rtems/system.h,
score/include/rtems/score/coresem.h: Restructed to move the
OBJECTS_LOCAL case to the top of the switch statement and
eliminate the fall-through return of POSIX_BOTTOM_REACHED. These
changes produced simplier assembly code and allowed for complete
test coverage. Also applied some consistency to the functions
that translate the core status codes to POSIX status codes.
* posix/src/mutextranslatereturncode.c,
posix/src/semaphoretranslatereturncode.c: New files.
* posix/src/mutexfromcorestatus.c: Removed.
* itron/src/can_wup.c, itron/src/chg_pri.c, itron/src/del_mbf.c,
itron/src/del_mbx.c, itron/src/del_sem.c, itron/src/del_tsk.c,
itron/src/frsm_tsk.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c,
itron/src/ref_sem.c, itron/src/ref_tsk.c, itron/src/rel_wai.c,
itron/src/rsm_tsk.c, itron/src/sig_sem.c, itron/src/snd_mbx.c,
itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/ter_tsk.c,
itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tsnd_mbf.c,
itron/src/twai_sem.c, posix/src/cancel.c, posix/src/conddestroy.c,
posix/src/condinit.c, posix/src/condsignalsupp.c,
posix/src/mutexinit.c, posix/src/mutexlocksupp.c,
posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c,
posix/src/pbarrierdestroy.c, posix/src/pbarrierwait.c,
posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c,
posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c,
posix/src/pspindestroy.c, posix/src/pspinlock.c,
rtems/src/barrierdelete.c, rtems/src/barrierrelease.c,
rtems/src/barrierwait.c, rtems/src/dpmemdelete.c,
rtems/src/eventtimeout.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c,
rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partdelete.c,
rtems/src/partgetbuffer.c, rtems/src/partreturnbuffer.c,
rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c,
rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c,
rtems/src/ratemontimeout.c, rtems/src/regiondelete.c,
rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c,
rtems/src/regionreturnsegment.c, rtems/src/semdelete.c,
rtems/src/semflush.c, rtems/src/semobtain.c, rtems/src/semrelease.c,
rtems/src/signalsend.c, rtems/src/taskdelete.c,
rtems/src/taskgetnote.c, rtems/src/taskissuspended.c,
rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c,
rtems/src/taskvariableget.c, rtems/src/timercancel.c,
rtems/src/timerserverfirewhen.c, sapi/src/extensiondelete.c,
score/include/rtems/score/object.h, score/src/corerwlocktimeout.c,
score/src/mpci.c, score/src/objectgetnameasstring.c,
score/src/threaddelayended.c, score/src/threadqtimeout.c: When
multiprocessing is disabled, do not even allow the constant
OBJECTS_REMOTE to appear in the source. Even at -O2, the presence of
a case OBJECTS_REMOTE in each id->pointer _Objects_Get switch results
in the generation of binary code which can NOT be reached.
* posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/semtimedwait.c: Correct indexing of key data to use api and
index NOT class and index. Class is always 1.
* posix/include/rtems/posix/cond.h,
posix/include/rtems/posix/intr.h, posix/include/rtems/posix/key.h,
posix/include/rtems/posix/timer.h, posix/src/cond.c,
posix/src/intr.c, posix/src/key.c, posix/src/keycreate.c,
posix/src/keydelete.c, posix/src/keygetspecific.c,
posix/src/keyrundestructors.c, posix/src/keysetspecific.c,
posix/src/killinfo.c, posix/src/mqueue.c,
posix/src/mqueuerecvsupp.c, posix/src/mqueuesendsupp.c,
posix/src/mqueuetranslatereturncode.c, posix/src/mutex.c,
posix/src/posixintervaltotimespec.c,
posix/src/posixtimespecsubtract.c, posix/src/psignal.c,
posix/src/pthread.c, posix/src/ptimer1.c, posix/src/semaphore.c,
posix/src/sysconf.c: Convert to using c99 fixed size types.
* include/rtems/posix/timer.h, src/keygetspecific.c,
src/posixtimespecsubtract.c, src/ptimer1.c, src/semunlink.c:
Added casts to eliminate warnings on 16-bit targets like the h8300.
