* | Split key.c into multiple files. | Joel Sherrill | 1999-11-02 | 1 | -225/+0 |
* | merged remote object id and invalid id error cases. | Joel Sherrill | 1996-08-09 | 1 | -6/+3 |
* | pthread_getspecific: use local variable so references to tcb are completed | Joel Sherrill | 1996-08-06 | 1 | -1/+6 |
| | | | | before enabling dispatching | ||||
* | key destructor is now run at correct point in pthread_exit() sequence and | Joel Sherrill | 1996-06-07 | 1 | -2/+2 |
| | | | | | | | | should be correct for other apis as well. missing page numbers added on some references. initial attempt at sig_procmask() and pthread_sigmask(). | ||||
* | comment clean up | Joel Sherrill | 1996-05-29 | 1 | -2/+1 |
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 1 | -0/+1 |
| | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. | ||||
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 1 | -0/+1 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 1 | -0/+259 |
