http://www.google-melange.com/gci/task/view/google/gci2012/7997223
* posix/src/getitimer.c, posix/src/setitimer.c: Add error checks and
clean up so coverage analysis is possible.
* posix/Makefile.am, posix/include/rtems/posix/psignal.h: Add stubs for
gettimer() and setitimer().
* posix/src/getitimer.c, posix/src/setitimer.c: New files.
* posix/Makefile.am, posix/src/clockgetcpuclockid.c,
posix/src/clockgetenableattr.c, posix/src/clockgettime.c,
posix/src/devctl.c, posix/src/execl.c, posix/src/execle.c,
posix/src/execlp.c, posix/src/execv.c, posix/src/execve.c,
posix/src/execvp.c, posix/src/fork.c, posix/src/mutexinit.c,
posix/src/pthreadatfork.c, posix/src/pthreadgetcpuclockid.c,
posix/src/pthreadkill.c, posix/src/semaphorecreatesupp.c,
posix/src/sysconf.c, posix/src/wait.c, posix/src/waitpid.c: Split
files into one function per file.
* posix/src/aio_cancel.c, posix/src/aio_error.c, posix/src/aio_fsync.c,
posix/src/aio_read.c, posix/src/aio_return.c,
posix/src/aio_suspend.c, posix/src/aio_write.c,
posix/src/lio_listio.c, posix/src/sched_getparam.c,
posix/src/sched_getprioritymax.c, posix/src/sched_getprioritymin.c,
posix/src/sched_getscheduler.c, posix/src/sched_rr_get_interval.c,
posix/src/sched_setparam.c, posix/src/sched_setscheduler.c,
posix/src/sched_yield.c: New files.
* posix/src/aio.c, posix/src/sched.c, posix/src/types.c: Removed.
* libcsupport/preinstall.am, posix/preinstall.am, posix/src/aio.c,
posix/src/clockgettime.c, posix/src/clocksetenableattr.c,
posix/src/clocksettime.c, posix/src/devctl.c,
posix/src/pthreadcreate.c, posix/src/pthreadgetcpuclockid.c,
posix/src/types.c, rtems/preinstall.am, sapi/Makefile.am,
sapi/preinstall.am, score/Makefile.am, score/preinstall.am: Eliminate
POSIX_NOT_IMPLEMENTED(). Return ENOSYS instead.
* include/rtems/posix/cond.h, include/rtems/posix/condmp.h,
include/rtems/posix/config.h, include/rtems/posix/intr.h,
include/rtems/posix/key.h, include/rtems/posix/mqueue.h,
include/rtems/posix/mqueuemp.h, include/rtems/posix/mutex.h,
include/rtems/posix/mutexmp.h, include/rtems/posix/posixapi.h,
include/rtems/posix/pthread.h, include/rtems/posix/pthreadmp.h,
include/rtems/posix/ptimer.h, include/rtems/posix/semaphore.h,
include/rtems/posix/semaphoremp.h, inline/rtems/posix/cond.inl,
inline/rtems/posix/intr.inl, inline/rtems/posix/key.inl,
inline/rtems/posix/mqueue.inl, inline/rtems/posix/mutex.inl,
inline/rtems/posix/pthread.inl, inline/rtems/posix/semaphore.inl,
inline/rtems/posix/timer.inl, macros/rtems/posix/cond.inl,
macros/rtems/posix/intr.inl, macros/rtems/posix/key.inl,
macros/rtems/posix/mqueue.inl, macros/rtems/posix/mutex.inl,
macros/rtems/posix/pthread.inl, macros/rtems/posix/semaphore.inl,
macros/rtems/posix/timer.inl, src/alarm.c, src/kill.c,
src/killinfo.c, src/mqueuetranslatereturncode.c, src/pause.c,
src/pthreadattrdestroy.c, src/pthreadattrgetdetachstate.c,
src/pthreadattrgetinheritsched.c, src/pthreadattrgetschedparam.c,
src/pthreadattrgetschedpolicy.c, src/pthreadattrgetscope.c,
src/pthreadattrgetstackaddr.c, src/pthreadattrgetstacksize.c,
src/pthreadattrinit.c, src/pthreadattrsetdetachstate.c,
src/pthreadattrsetinheritsched.c, src/pthreadattrsetschedparam.c,
src/pthreadattrsetschedpolicy.c, src/pthreadattrsetscope.c,
src/pthreadattrsetstackaddr.c, src/pthreadattrsetstacksize.c,
src/pthreadcreate.c, src/pthreaddetach.c, src/pthreadequal.c,
src/pthreadexit.c, src/pthreadgetcpuclockid.c,
src/pthreadgetcputime.c, src/pthreadgetschedparam.c,
src/pthreadjoin.c, src/pthreadkill.c, src/pthreadonce.c,
src/pthreadself.c, src/pthreadsetcputime.c,
src/pthreadsetschedparam.c, src/pthreadsigmask.c, src/sigaction.c,
src/sigaddset.c, src/sigdelset.c, src/sigemptyset.c,
src/sigfillset.c, src/sigismember.c, src/signal_2.c,
src/sigpending.c, src/sigprocmask.c, src/sigqueue.c,
src/sigsuspend.c, src/sigtimedwait.c, src/sigwait.c,
src/sigwaitinfo.c, src/ualarm.c: URL for license changed.
* src/pthreadgetcpuclockid.c: Add include of <rtems/system.h> to
eliminate warning.
PROBLEMS
can/will be fixed.
based on the GNU tools. This usually involved correcting the
type of bsp_start(), bsp_cleanup(), adjusting the start code to
call the right start routine (the shared boot_card()), and then
removing code from bsp_start() which was performed in the new
boot_card()/main() path.
