path: root/cpukit/posix/src/getgid.c (unfollow)
2003-08-182003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-47/+0
PR 449/rtems: * src/getegid.c: Remove (Moved to ../libcsupport/src). * src/geteuid.c: Remove (Moved to ../libcsupport/src). * src/getgid.c: Remove (Moved to ../libcsupport/src). * src/getgroups.c: Remove (Moved to ../libcsupport/src). * src/getlogin.c: Remove (Moved to ../libcsupport/src). * src/getpgrp.c: Remove (Moved to ../libcsupport/src). * src/getpid.c: Remove (Moved to ../libcsupport/src). * src/getppid.c: Remove (Moved to ../libcsupport/src). * src/getuid.c: Remove (Moved to ../libcsupport/src). * src/setpgid.c: Remove (Moved to ../libcsupport/src). * src/setsid.c: Remove (Moved to ../libcsupport/src). * Makefile.am: Reflect changes above
2002-04-032002-04-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+0
* src/getegid.c: Remove <errno.h>. * src/geteuid.c: Ditto. * src/getgid.c: Ditto. * src/getuid.c: Ditto. * src/getlogin.c: Move <errno.h>.
2002-01-162002-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-2/+2
* src/getegid.c: Add #include <rtems/userenv.h>. Remove #include <rtems/libio_.h>. * src/geteuid.c: Ditto. * src/getgid.c: Ditto. * src/getlogin.c: Ditto. * src/getuid.c: Ditto.
2001-05-242000-05-24 Fernando Ruiz Casas <fernando.ruiz@ctv.es>Joel Sherrill1-0/+6
* src/getegid.c, src/geteuid.c, src/getgid.c, src/getlogin.c, src/getuid.c: Now save their values in private user environment.
2001-01-242001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
* configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
2000-08-302000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs.
1999-11-02Split types.s into individual files.Joel Sherrill1-0/+38
