This error check was commented out because it is not in the POSIX
specification. However, the GNU/Linux manual page does document
that EPERM is to be returned in this situation.
Add thread parameter to _Thread_queue_Enqueue_with_handler() to avoid
access to global _Thread_Executing.
application visible API.
Move implementation specific parts of states.h and states.inl into new
header file statesimpl.h. The states.h contains now only the
Move implementation specific parts of cond.h and cond.inl into new
header file condimpl.h. The cond.h contains now only the application
visible API.
Move implementation specific parts of mutex.h and mutex.inl into new
header file muteximpl.h. The mutex.h contains now only the application
visible API.
Add and use _Objects_Put_without_thread_dispatch(). These two functions
pair with the _Objects_Get() function. This helps to introduce object
specific SMP locks to avoid lock contention.
http://www.google-melange.com/gci/task/view/google/gci2012/7988213
* posix/src/condinit.c, posix/src/condwaitsupp.c,
posix/src/psignalunblockthread.c: Clean up some signal interruption
code.
* posix/preinstall.am, posix/include/aio.h, posix/include/devctl.h,
posix/include/mqueue.h, posix/include/sched.h,
posix/include/semaphore.h, posix/include/rtems/posix/cancel.h,
posix/include/rtems/posix/timer.h,
posix/src/cancel.c, posix/src/cancelrun.c, posix/src/cleanuppop.c,
posix/src/cleanuppush.c, posix/src/cond.c,
posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c,
posix/src/condattrinit.c, posix/src/condattrsetpshared.c,
posix/src/condbroadcast.c, posix/src/conddefaultattributes.c,
posix/src/conddestroy.c, posix/src/condinit.c,
posix/src/condsignal.c, posix/src/condsignalsupp.c,
posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/key.c,
posix/src/keycreate.c, posix/src/keydelete.c,
posix/src/keysetspecific.c, posix/src/mqueue.c,
posix/src/mqueueclose.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c,
posix/src/mqueuenametoid.c, posix/src/mqueuenotify.c,
posix/src/mqueueopen.c, posix/src/mqueuereceive.c,
posix/src/mqueuerecvsupp.c, posix/src/mqueuesend.c,
posix/src/mqueueunlink.c, posix/src/mutex.c,
posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c,
posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexlock.c,
posix/src/mutextrylock.c, posix/src/mutexunlock.c,
posix/src/psignal.c, posix/src/psignalchecksignal.c,
posix/src/psignalunblockthread.c, posix/src/ptimer.c,
posix/src/sempost.c, posix/src/semtrywait.c, posix/src/semunlink.c,
posix/src/semwait.c, posix/src/setcancelstate.c,
posix/src/setcanceltype.c, posix/src/sysconf.c,
posix/src/testcancel.c: Add missing copyright statements.
* posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/semaphore.h, posix/src/cancel.c,
posix/src/conddestroy.c, posix/src/condsignalsupp.c,
posix/src/condwaitsupp.c, posix/src/keydelete.c,
posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/mqueueclose.c, posix/src/mqueuegetattr.c,
posix/src/mqueuetranslatereturncode.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c,
posix/src/mutexunlock.c, posix/src/pbarrierdestroy.c,
posix/src/pbarriertranslatereturncode.c, posix/src/pbarrierwait.c,
posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c,
posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c,
posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c,
posix/src/prwlockwrlock.c, posix/src/pspindestroy.c,
posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/pthreaddetach.c, posix/src/pthreadequal.c,
posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c,
posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c,
posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c,
rtems/src/msgqtranslatereturncode.c, rtems/src/semobtain.c,
rtems/src/timerfireafter.c, score/include/rtems/system.h,
score/include/rtems/score/coresem.h: Restructed to move the
OBJECTS_LOCAL case to the top of the switch statement and
eliminate the fall-through return of POSIX_BOTTOM_REACHED. These
changes produced simplier assembly code and allowed for complete
test coverage. Also applied some consistency to the functions
that translate the core status codes to POSIX status codes.
* posix/src/mutextranslatereturncode.c,
posix/src/semaphoretranslatereturncode.c: New files.
* posix/src/mutexfromcorestatus.c: Removed.
* posix/Makefile.am, posix/preinstall.am, posix/src/cancel.c,
posix/src/condsignalsupp.c, posix/src/condwaitsupp.c,
posix/src/mqueueunlink.c, posix/src/mutexattrdestroy.c,
posix/src/mutexunlock.c, posix/src/semaphorecreatesupp.c,
posix/src/semaphoredeletesupp.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/semunlink.c,
posix/src/types.c, score/cpu/powerpc/rtems/old-exceptions/cpu.h:
Remove all pretense of POSIX MP support. The support in place was
only a shell. This should make maintenance easier.
* posix/include/rtems/posix/condmp.h,
posix/include/rtems/posix/mqueuemp.h,
posix/include/rtems/posix/mutexmp.h,
posix/include/rtems/posix/pthreadmp.h,
posix/include/rtems/posix/semaphoremp.h, posix/src/condmp.c,
posix/src/mutexmp.c, posix/src/semaphoremp.c: Removed.
* itron/src/can_wup.c, itron/src/chg_pri.c, itron/src/del_mbf.c,
itron/src/del_mbx.c, itron/src/del_sem.c, itron/src/del_tsk.c,
itron/src/frsm_tsk.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c,
itron/src/ref_sem.c, itron/src/ref_tsk.c, itron/src/rel_wai.c,
itron/src/rsm_tsk.c, itron/src/sig_sem.c, itron/src/snd_mbx.c,
itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/ter_tsk.c,
itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tsnd_mbf.c,
itron/src/twai_sem.c, posix/src/cancel.c, posix/src/conddestroy.c,
posix/src/condinit.c, posix/src/condsignalsupp.c,
posix/src/mutexinit.c, posix/src/mutexlocksupp.c,
posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c,
posix/src/pbarrierdestroy.c, posix/src/pbarrierwait.c,
posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c,
posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c,
posix/src/pspindestroy.c, posix/src/pspinlock.c,
rtems/src/barrierdelete.c, rtems/src/barrierrelease.c,
rtems/src/barrierwait.c, rtems/src/dpmemdelete.c,
rtems/src/eventtimeout.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c,
rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partdelete.c,
rtems/src/partgetbuffer.c, rtems/src/partreturnbuffer.c,
rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c,
rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c,
rtems/src/ratemontimeout.c, rtems/src/regiondelete.c,
rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c,
rtems/src/regionreturnsegment.c, rtems/src/semdelete.c,
rtems/src/semflush.c, rtems/src/semobtain.c, rtems/src/semrelease.c,
rtems/src/signalsend.c, rtems/src/taskdelete.c,
rtems/src/taskgetnote.c, rtems/src/taskissuspended.c,
rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c,
rtems/src/taskvariableget.c, rtems/src/timercancel.c,
rtems/src/timerserverfirewhen.c, sapi/src/extensiondelete.c,
score/include/rtems/score/object.h, score/src/corerwlocktimeout.c,
score/src/mpci.c, score/src/objectgetnameasstring.c,
score/src/threaddelayended.c, score/src/threadqtimeout.c: When
multiprocessing is disabled, do not even allow the constant
OBJECTS_REMOTE to appear in the source. Even at -O2, the presence of
a case OBJECTS_REMOTE in each id->pointer _Objects_Get switch results
in the generation of binary code which can NOT be reached.
