Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
Make the interrupt lock context the second parameter to avoid register
moves.
Update #2555.
Rename _POSIX_Absolute_timeout_to_ticks() to
_TOD_Absolute_timeout_to_ticks() and move it to the score directory.
Delete empty <rtems/posix/time.h>.
application visible API.
Move implementation specific parts of states.h and states.inl into new
header file statesimpl.h. The states.h contains now only the
Move implementation specific parts of cond.h and cond.inl into new
header file condimpl.h. The cond.h contains now only the application
visible API.
Move implementation specific parts of mutex.h and mutex.inl into new
header file muteximpl.h. The mutex.h contains now only the application
visible API.
* libcsupport/src/gxx_wrappers.c, posix/include/mqueue.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/key.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl, posix/src/condget.c,
posix/src/mqueuenametoid.c, posix/src/mutexget.c,
posix/src/semaphorenametoid.c, posix/src/semopen.c,
sapi/src/itronapi.c, sapi/src/posixapi.c: Make changes necessary for
all tests to run on SPARC with 16-bit Ids. This required ensuring
that all POSIX and compilering binding code makes a distinction
between the public Id type (e.g. pthread_t, etc.) and the RTEMS
Object_Id type. All POSIX Object Get routines should not take the
POSIX Id type as the argument. Sixteen bit RTEMS Ids should be placed
into the 32-bits reserved by the POSIX API type in a uniform manner
now. This removed all assumptions that the external Id types in POSIX
and ITRON are the same as the internal Object Id type.
* posix/Makefile.am, posix/include/rtems/posix/cond.h,
posix/include/rtems/posix/mutex.h, posix/inline/rtems/posix/cond.inl,
posix/inline/rtems/posix/mutex.inl: Do not include POSIX Mutex or
Condition Variable object get helpers because they are more
complicated than the norm. They can implicitly perform a create. They
cross the line as being too complex and large to inline since they
negatively impact size and binary test coverage.
* posix/src/condget.c, posix/src/mutexget.c: New files.
