path: root/cpukit/posix/src/clocknanosleep.c (follow)
* score: Simplify thread queue timeout handlingSebastian Huber2021-05-181-18/+20
| | | | | | | Add Thread_queue_Context::timeout_absolute to specify an absolute or relative timeout. This avoid having to get the current time twice for timeouts relative to the current time. It moves also functionality to common code.
* posix: Fix use of clock for relative timesSebastian Huber2021-05-181-13/+18
| | | | Close #4426.
* posix: Use RTEMS_POSIX_API in clock_nanosleep()Sebastian Huber2021-05-171-0/+5
| | | | | It is only possible to get interrupted by a POSIX signal if RTEMS_POSIX_API is defined.
* posix: Move clock_nanosleep()Sebastian Huber2021-05-171-0/+116
Move clock_nanosleep() to a separate file to avoid a dependency on errno which pulls in the Newlib reentrancy support. This is an issue since most parts which are pulled in cannot be garbage collected by the linker due to the system initialization linker set.
