path: root/cpukit/posix/src/cleanuppush.c (follow)
* Optional POSIX Cleanup initializationSebastian Huber2016-02-031-8/+71
| | | | Update #2408.
* posix: Require struct _pthread_cleanup_contextSebastian Huber2015-11-241-49/+0
| | | | | This structure is available in Newlib since 2013-11-29 (Git commit a534dfd26e765047621acd0eda656ded886e7108).
* posix: Use cleanup contexts on the stackSebastian Huber2013-12-021-4/+33
| | | | | | | | | | Provide support for latest Newlib <pthread.h> change. The cleanup contexts are stored on the thread stack. This is conformant with the POSIX requirements for the pthread_cleanup_push() and pthread_cleanup_pop() statement pair. Passing an invalid pointer as the routine to pthread_cleanup_push() is now a usage error and the behaviour is undefined.
* Fix compiler warningsR. Diez2013-08-061-1/+1
* posix: Create pthread implementation headerSebastian Huber2013-07-221-1/+1
| | | | | | Move implementation specific parts of pthread.h and pthread.inl into new header file pthreadimpl.h. The pthread.h contains now only the application visible API.
* cpukit/posix: Doxygen group is POSIXAPIJoel Sherrill2013-01-101-1/+1
* posix: Doxygen enhancement task #4Mathew Kallada2012-12-131-0/+7
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7955219
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script.
* Whitespace removal.Ralf Corsepius2009-11-301-1/+1
* 2008-01-18 Jennifer Averett <jennifer.averett@OARcorp.com>Jennifer Averett2008-01-181-13/+14
| | | | | | | * posix/include/rtems/posix/timer.h, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/mqueueclose.c, posix/src/timergettime.c, posix/src/timersettime.c, score/include/rtems/score/timespec.h:
* 2007-12-17 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-171-0/+7
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * posix/preinstall.am, posix/include/aio.h, posix/include/devctl.h, posix/include/mqueue.h, posix/include/sched.h, posix/include/semaphore.h, posix/include/rtems/posix/cancel.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/priority.inl, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cancel.c, posix/src/cancelrun.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/key.c, posix/src/keycreate.c, posix/src/keydelete.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mqueue.c, posix/src/mqueueclose.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenametoid.c, posix/src/mqueuenotify.c, posix/src/mqueueopen.c, posix/src/mqueuereceive.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/ptimer.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/setcancelstate.c, posix/src/setcanceltype.c, posix/src/sysconf.c, posix/src/testcancel.c: Add missing copyright statements.
* Remove stray white spaces.Ralf Corsepius2004-04-161-3/+3
* 2003-10-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-10-131-1/+6
| | | | | * src/cleanuppop.c, src/cleanuppush.c: Protect use of _Workspace_Allocate and _Workspec_Free.
* 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-241-0/+4
| | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
* Split cancel.c into multiple files.Joel Sherrill1999-11-021-0/+47
