Add ISR lock to chain control for proper SMP protection. Replace
rtems_chain_extract() with rtems_chain_explicit_extract() and
rtems_chain_insert() with rtems_chain_explicit_insert() on SMP
configurations. Use rtems_chain_explicit_extract() and
rtems_chain_explicit_insert() to provide SMP support.
http://www.google-melange.com/gci/task/view/google/gci2012/7948216
* posix/src/aio_misc.c: Make rtems_aio_move_to_work,
rtems_aio_insert_prio static.
* posix/src/aio_cancel.c: Fixed ending of if braces.
2011-01-17 Alin Rus <alin.codejunkie@gmail.com>
* posix/src/aio_misc.c: Add debug information. Fixed idle_threads/
active_threads issues. Fixed infinite loop in rtems_aio_handle().
* posix/src/aio_misc.c: Fix rtems_aio_remove_req did not iterate
over chain.
* posix/src/aio_cancel.c: Add debug information. Add check for
bad file descriptor. Add else branch for cancel request on empty
IQ chain.
* posix/include/rtems/posix/aio_misc.h, posix/src/aio_misc.c: Small
fixes.
* posix/include/rtems/posix/aio_misc.h: Add decl for aio_request_queue.
* posix/src/aio_misc.c: Add aio_request_queue.
* posix/include/aio.h: Add LIO_SYNC.
* posix/include/rtems/posix/aio_misc.h: Add aio_request_queue,
Cosmetics.
* posix/src/aio_cancel.c, posix/src/aio_fsync.c, posix/src/aio_misc.c:
Rework.
* posix/include/rtems/posix/aio_misc.h: Remove
rtems_aio_queue_s.size (Unused).
* posix/src/aio_misc.c: Remove aio_request_queue.size.
Cosmetics.
* posix/src/aio_misc.c: New.
* posix/src/aio_error.c, posix/src/aio_read.c,
* posix/src/aio_return.c, posix/src/aio_write.c:
New implementation.
