2001-01-24 | 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support. | |||||
2000-08-30 | 2000-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs. | |||||
1999-04-15 | Now compiles and is included in normal build even though it is untested. | Joel Sherrill | 1 | -0/+3 | |
1996-05-29 | comment clean up | Joel Sherrill | 1 | -2/+1 | |
1996-05-29 | removed all ifdef's on NOT_IMPLEMENTED. | Joel Sherrill | 1 | -3/+0 | |
1996-05-22 | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1 | -0/+2 | |
of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. | |||||
1995-10-06 | fixed missing CVS IDs | Joel Sherrill | 1 | -0/+1 | |
1995-09-26 | posix support initially added | Joel Sherrill | 1 | -0/+112 | |
