Make _POSIX_Mutex_Default_attributes constant and independent of the
scheduler instance. Use INT_MAX to indicate the default ceiling
priority.
Add Thread_Life_state::THREAD_LIFE_CHANGE_DEFERRED and rework the POSIX
thread cancellation to use the thread life states.
Update #2555.
Update #2626.
Rename _POSIX_Absolute_timeout_to_ticks() to
_TOD_Absolute_timeout_to_ticks() and move it to the score directory.
Delete empty <rtems/posix/time.h>.
not updated.
Enable pthread_once() for all configurations. The pthread_once()
function is one means to initialize POSIX keys. Another use case is the
C++ support.
Formerly POSIX keys were only enabled when POSIX threads
were enabled. Because they are a truly safe alternative
to per-task variables in an SMP system, they are being
enabled in all configurations.
Change pthread_once from using disabled pre-emption to using a
pthread mutex making it SMP safe. GCC using a posix threading
model uses pthread_once.
The pthread mutex requires at least 1 mutex is configured so
confdefs.h has been updated to account for the internal
mutex.
Move implementation specific parts of key.h and key.inl into new header
file keyimpl.h. The key.h contains now only the application visible
API.
Move implementation specific parts of spinlock.h and spinlock.inl into
new header file spinlockimpl.h. The spinlock.h contains now only the
application visible API.
Move implementation specific parts of timer.h and timer.inl into new
header file timerimpl.h. The timer.h contains now only the application
visible API.
Move implementation specific parts of rwlock.h and rwlock.inl into new
header file rwlockimpl.h. The rwlock.h contains now only the
Move implementation specific parts of pthread.h and pthread.inl into new
header file pthreadimpl.h. The pthread.h contains now only the
Move implementation specific parts of priority.h and priority.inl into
new header file priorityimpl.h. Remove priority.h since there is no
Move implementation specific parts of cond.h and cond.inl into new
header file condimpl.h. The cond.h contains now only the application
visible API.
Move implementation specific parts of barrier.h and barrier.inl into new
header file barrierimpl.h. The barrier.h contains now only the
Move implementation specific parts of mqueue.h and mqueue.inl into new
header file mqueueimpl.h. The mqueue.h contains now only the
Move implementation specific parts of semaphore.h and semaphore.inl into
new header file semaphoreimpl.h. The semaphore.h contains now only the
Move implementation specific parts of mutex.h and mutex.inl into new
header file muteximpl.h. The mutex.h contains now only the application
visible API.
This file contains the parts of <rtems/posix/psignal.h> that are only
necessary for the POSIX API implementation.
* libcsupport/Makefile.am, libcsupport/preinstall.am,
posix/Makefile.am, posix/preinstall.am, rtems/Makefile.am,
rtems/preinstall.am, score/Makefile.am, score/preinstall.am: Revert
modifications accidentally committed.
* libcsupport/preinstall.am, posix/preinstall.am: Revert temporary
changes which aid in coverage testing.
* posix/preinstall.am, posix/include/aio.h, posix/include/devctl.h,
posix/include/mqueue.h, posix/include/sched.h,
posix/include/semaphore.h, posix/include/rtems/posix/cancel.h,
posix/include/rtems/posix/timer.h,
posix/src/cancel.c, posix/src/cancelrun.c, posix/src/cleanuppop.c,
posix/src/cleanuppush.c, posix/src/cond.c,
posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c,
posix/src/condattrinit.c, posix/src/condattrsetpshared.c,
posix/src/condbroadcast.c, posix/src/conddefaultattributes.c,
posix/src/conddestroy.c, posix/src/condinit.c,
posix/src/condsignal.c, posix/src/condsignalsupp.c,
posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/key.c,
posix/src/keycreate.c, posix/src/keydelete.c,
posix/src/keysetspecific.c, posix/src/mqueue.c,
posix/src/mqueueclose.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c,
posix/src/mqueuenametoid.c, posix/src/mqueuenotify.c,
posix/src/mqueueopen.c, posix/src/mqueuereceive.c,
posix/src/mqueuerecvsupp.c, posix/src/mqueuesend.c,
posix/src/mqueueunlink.c, posix/src/mutex.c,
posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c,
posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexlock.c,
posix/src/mutextrylock.c, posix/src/mutexunlock.c,
posix/src/psignal.c, posix/src/psignalchecksignal.c,
posix/src/psignalunblockthread.c, posix/src/ptimer.c,
posix/src/sempost.c, posix/src/semtrywait.c, posix/src/semunlink.c,
posix/src/semwait.c, posix/src/setcancelstate.c,
posix/src/setcanceltype.c, posix/src/sysconf.c,
posix/src/testcancel.c: Add missing copyright statements.
* posix/Makefile.am, posix/preinstall.am,
posix/include/rtems/posix/timer.h, score/src/objectget.c: Split POSIX
Timer implementation into multiple files. Add obvious error checks
for NULL parameters. Attempt to reduce include files.
* posix/src/timercreate.c, posix/src/timerdelete.c,
posix/src/timergetoverrun.c, posix/src/timergettime.c,
posix/src/timerinserthelper.c, posix/src/timersettime.c,
posix/src/timertsr.c: New files.
* posix/src/ptimer1.c: Removed.
* libcsupport/preinstall.am, posix/preinstall.am, rtems/Makefile.am,
rtems/preinstall.am, sapi/Makefile.am, sapi/preinstall.am,
score/Makefile.am, score/preinstall.am: Revert testing patch.
* libcsupport/preinstall.am, posix/preinstall.am, posix/src/aio.c,
posix/src/clockgettime.c, posix/src/clocksetenableattr.c,
posix/src/clocksettime.c, posix/src/devctl.c,
posix/src/pthreadcreate.c, posix/src/pthreadgetcpuclockid.c,
posix/src/types.c, rtems/preinstall.am, sapi/Makefile.am,
sapi/preinstall.am, score/Makefile.am, score/preinstall.am: Eliminate
POSIX_NOT_IMPLEMENTED(). Return ENOSYS instead.
* posix/preinstall.am: Revert debug patch.
* libcsupport/src/malloc.c, libmisc/monitor/mon-command.c,
posix/preinstall.am, posix/include/rtems/posix/cond.h,
posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/semaphore.h, posix/src/conddestroy.c,
posix/src/mutexdestroy.c, posix/src/mutexinit.c,
posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c,
sapi/include/confdefs.h, sapi/include/rtems/config.h,
sapi/include/rtems/init.h, sapi/include/rtems/sptables.h,
sapi/src/exinit.c, score/include/rtems/system.h,
score/include/rtems/score/mpci.h, score/src/mpci.c,
score/src/thread.c, score/src/threadcreateidle.c,
score/src/threadstackallocate.c, score/src/threadstackfree.c,
score/src/wkspace.c: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* posix/Makefile.am, posix/preinstall.am, posix/src/cancel.c,
posix/src/condsignalsupp.c, posix/src/condwaitsupp.c,
posix/src/mqueueunlink.c, posix/src/mutexattrdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c,
posix/src/mutexunlock.c, posix/src/semaphorecreatesupp.c,
posix/src/semaphoredeletesupp.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/semunlink.c,
posix/src/types.c, score/cpu/powerpc/rtems/old-exceptions/cpu.h:
Remove all pretense of POSIX MP support. The support in place was
only a shell. This should make maintenance easier.
* posix/include/rtems/posix/condmp.h,
posix/include/rtems/posix/mqueuemp.h,
posix/include/rtems/posix/mutexmp.h,
posix/include/rtems/posix/pthreadmp.h,
posix/include/rtems/posix/semaphoremp.h, posix/src/condmp.c,
posix/src/mutexmp.c, posix/src/semaphoremp.c: Removed.
* libcsupport/src/termios.c, posix/Makefile.am, posix/preinstall.am,
posix/include/rtems/posix/config.h, posix/include/rtems/posix/time.h,
sapi/src/posixapi.c, score/Makefile.am, score/preinstall.am,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/threadq.h,
score/src/corerwlockobtainread.c, score/src/threadqenqueue.c,
score/src/threadqtimeout.c: Adding POSIX barriers, POSIX spinlocks,
and partial implementation of POSIX rwlocks.
* posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/src/pbarrier.c, posix/src/pbarrierdestroy.c,
posix/src/pbarrierinit.c, posix/src/pbarriertranslatereturncode.c,
posix/src/pbarrierwait.c, posix/src/prwlock.c,
posix/src/prwlockdestroy.c, posix/src/prwlockinit.c,
posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c,
posix/src/prwlocktimedwrlock.c,
posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c,
posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c,
posix/src/prwlockwrlock.c, posix/src/pspin.c,
posix/src/pspindestroy.c, posix/src/pspininit.c,
posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c: New files.
* configure.ac, itron/Makefile.am, itron/preinstall.am,
score/Makefile.am, score/preinstall.am, score/include/rtems/system.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/thread.h, score/src/chain.c,
score/src/coremutexseize.c, score/src/threadget.c: Remove all macro
implementations and use only the static inline. Static inline
functions are now well supported so there is no reason for duplicate
maintenance.
* itron/macros/rtems/itron/eventflags.inl,
itron/macros/rtems/itron/fmempool.inl,
itron/macros/rtems/itron/intr.inl, itron/macros/rtems/itron/mbox.inl,
itron/macros/rtems/itron/msgbuffer.inl,
itron/macros/rtems/itron/network.inl,
itron/macros/rtems/itron/port.inl,
itron/macros/rtems/itron/semaphore.inl,
itron/macros/rtems/itron/sysmgmt.inl,
itron/macros/rtems/itron/task.inl, itron/macros/rtems/itron/time.inl,
itron/macros/rtems/itron/vmempool.inl,
posix/macros/rtems/posix/cond.inl, posix/macros/rtems/posix/key.inl,
posix/macros/rtems/posix/mqueue.inl,
posix/macros/rtems/posix/mutex.inl,
posix/macros/rtems/posix/priority.inl,
posix/macros/rtems/posix/pthread.inl,
posix/macros/rtems/posix/semaphore.inl,
posix/macros/rtems/posix/timer.inl, rtems/macros/rtems/rtems/asr.inl,
rtems/macros/rtems/rtems/attr.inl,
rtems/macros/rtems/rtems/barrier.inl,
rtems/macros/rtems/rtems/dpmem.inl,
rtems/macros/rtems/rtems/event.inl,
rtems/macros/rtems/rtems/eventset.inl,
rtems/macros/rtems/rtems/message.inl,
rtems/macros/rtems/rtems/modes.inl,
rtems/macros/rtems/rtems/options.inl,
rtems/macros/rtems/rtems/part.inl,
rtems/macros/rtems/rtems/ratemon.inl,
rtems/macros/rtems/rtems/region.inl,
rtems/macros/rtems/rtems/sem.inl,
rtems/macros/rtems/rtems/status.inl,
rtems/macros/rtems/rtems/support.inl,
rtems/macros/rtems/rtems/tasks.inl,
rtems/macros/rtems/rtems/timer.inl, sapi/macros/rtems/extension.inl,
score/macros/README, score/macros/rtems/score/address.inl,
score/macros/rtems/score/chain.inl,
score/macros/rtems/score/corebarrier.inl,
score/macros/rtems/score/coremsg.inl,
score/macros/rtems/score/coremutex.inl,
score/macros/rtems/score/corerwlock.inl,
score/macros/rtems/score/coresem.inl,
score/macros/rtems/score/corespinlock.inl,
score/macros/rtems/score/heap.inl, score/macros/rtems/score/isr.inl,
score/macros/rtems/score/mppkt.inl,
score/macros/rtems/score/object.inl,
score/macros/rtems/score/objectmp.inl,
score/macros/rtems/score/priority.inl,
score/macros/rtems/score/stack.inl,
score/macros/rtems/score/states.inl,
score/macros/rtems/score/sysstate.inl,
score/macros/rtems/score/thread.inl,
score/macros/rtems/score/threadmp.inl,
score/macros/rtems/score/tod.inl,
score/macros/rtems/score/tqdata.inl,
score/macros/rtems/score/userext.inl,
score/macros/rtems/score/watchdog.inl,
score/macros/rtems/score/wkspace.inl: Removed.
posix/include/rtems/posix/timer.h, posix/src/ptimer.c,
posix/src/ptimer1.c, sapi/src/posixapi.c,
score/include/rtems/score/object.h:
