* | 2002-12-06 Vladimir Nesic <vnesic@dkts.co.yu> | Joel Sherrill | 2002-12-06 | 1 | -8/+37 |
| | | | | | | * inline/rtems/posix/cond.inl, macros/rtems/posix/cond.inl: Implemented PTHREAD_COND_INITIALIZER support. Vladimir implemented the inline version and Joel adapted it to the macro version. | ||||
* | 2001-05-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-05-17 | 1 | -10/+29 |
| | | | | | * macros/rtems/posix/mqueue.inl: Implemented missing routines to support message queue FDs. | ||||
* | 2001-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-08-30 | 1 | -1/+3 |
| | | | | * macros/rtems/posix/mqueue.inl: Add cast so negation works. | ||||
* | 2000-12-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-12-01 | 9 | -0/+551 |
| | | | | | | | | | | | | | * Added macro support to POSIX API. This is known to compile. * macros/rtems/posix/cond.inl, macros/rtems/posix/intr.inl, macros/rtems/posix/key.inl, macros/rtems/posix/mqueue.inl, macros/rtems/posix/mutex.inl, macros/rtems/posix/priority.inl, macros/rtems/posix/pthread.inl, macros/rtems/posix/semaphore.inl, macros/rtems/posix/timer.inl: New files. * configure.in: Removed error check for enabling macros. * rtems/posix/mutex.h: #if 0'ed out prototypes for inlined routines since you cannot have prototypes for macros. * macros/rtems/posix/Makefile.am: Added files. | ||||
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+2 |
adds .cvsignore. |
