* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 3 | -0/+6 |
| | | | | adds .cvsignore. | ||||
* | Added priority conversion between POSIX and core. | Jennifer Averett | 2000-01-05 | 1 | -2/+17 |
* | + Added routine to remove from namespace. | Jennifer Averett | 1999-12-23 | 1 | -0/+13 |
* | Added a routine to remove a semaphore name from its namespace. | Jennifer Averett | 1999-11-18 | 1 | -0/+15 |
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 7 | -14/+7 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bug | Joel Sherrill | 1999-10-04 | 1 | -3/+3 |
| | | | | where wrapup left pieces out of the librtemsall.a. | ||||
* | Applied patch rtems-rc-19990820-6.diff.gz from | Joel Sherrill | 1999-09-07 | 1 | -0/+10 |
| | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> which converted many Makefile.in's to Makefile.am's. This added a lot of files. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 7 | -7/+7 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 7 | -14/+14 |
* | Added commit about missing support for condition initializer. | Joel Sherrill | 1997-08-22 | 1 | -0/+1 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 7 | -35/+35 |
* | Reduced number of POSIX thread priorities from 255 to 254 to avoid conflicts | Joel Sherrill | 1997-04-15 | 1 | -3/+3 |
| | | | | | of lowest priority with the RTEMS IDLE thread. This was causing the lowest priority GNAT Ada task to never run. | ||||
* | _POSIX_Mutex_Get: made null id an error | Joel Sherrill | 1996-08-12 | 1 | -0/+5 |
* | switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE" | Joel Sherrill | 1996-07-03 | 8 | -32/+32 |
* | added comments to to document the definition of posix priority | Joel Sherrill | 1996-06-05 | 1 | -0/+8 |
| | | | | and how it corresponds to rtems core priority. | ||||
* | deleted POSIX threads typedef masking Thread_Control | Joel Sherrill | 1996-06-03 | 1 | -9/+8 |
| | | | | added initial version of pthread_detach and pthread_join | ||||
* | cleaned up spacing and parentheses | Joel Sherrill | 1996-05-29 | 1 | -2/+2 |
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 1 | -0/+3 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 8 | -0/+557 |
