path: root/cpukit/posix/include (follow)
* cpukit: Use Consistent Beginning of Doxygen Group NotationJoel Sherrill2013-01-1016-16/+16
| | | | | This is the result of a sed script which converts all uses of @{ into a consistent form.
* cpukit: Doxygen group fixes and many warnings addressedJoel Sherrill2013-01-1017-27/+29
| | | | | | | The output of the modules.html is much improved. Most filesystem and POSIX API related groups are properly nested. Some formatting issues were addressed as were multiple inconsistencies.
* posix: Doxygen Clean Up Task #1Alex Ivanov2013-01-0720-345/+419
* posix: Doxygen Clean Up Task #2Alex Ivanov2013-01-044-60/+76
* Header File Doxygen Enhancement Task #1Alex Ivanov2012-12-282-2/+6
* Header File Doxygen Enhancement Task #11Mathew Kallada2012-12-281-0/+2
* barrier.h: Use POSIX API Doxygen groupJoel Sherrill2012-12-281-0/+12
* posixapi.h: Add POSIX API Doxygen groupJoel Sherrill2012-12-281-0/+10
* Miscellaneous Doxygen clean-upJoel Sherrill2012-12-281-0/+2
* posix: Doxygen Enhancement Task #7Mathew Kallada2012-12-163-7/+13
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7958218
* posix: Doxygen Enhancement Task #2Alex Ivanov2012-12-155-23/+48
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7988213
* posix: Doxygen Enhancement Task #8Mathew Kallada2012-12-154-6/+49
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/8003213
* posix: Doxygen Enhancement Task #5Alex Ivanov2012-12-157-14/+69
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7959229
* posix: Doxygen Enhancement Task #1Alex Ivanov2012-12-156-11/+85
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7987220
* posix: Doxygen enhancement task #4Mathew Kallada2012-12-137-7/+78
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7955219
* posix: Add signal post switch extension on the flySebastian Huber2012-12-051-3/+7
* posix: Add and use <rtems/posix/psignalimpl.h>Sebastian Huber2012-12-052-90/+115
| | | | | This file contains the parts of <rtems/posix/psignal.h> that are only necessary for the POSIX API implementation.
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-1122-44/+0
* 2011-12-13 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-12-134-41/+41
| | | | | | | | | | | | | | | | | | | | | | * posix/src/mqueuenametoid.c, posix/src/semaphorenametoid.c: Removed files. * posix/src/psxnametoid.c: New file. * posix/Makefile.am: Reflect changes above. * posix/include/rtems/posix/config.h: Fixed integer types. * posix/include/rtems/posix/posixapi.h: Declare _POSIX_Name_to_id(). * posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/mqueue.inl: Changed parameter of _POSIX_Message_queue_Create_support(). _POSIX_Message_queue_Name_to_id() is now inline. * posix/include/rtems/posix/semaphore.h, posix/inline/rtems/posix/semaphore.inl: Changed parameter of _POSIX_Semaphore_Create_support(). _POSIX_Semaphore_Name_to_id() is now inline. * posix/src/mqueuecreatesupp.c, posix/src/semaphorecreatesupp.c: Use _Workspace_String_duplicate(). * posix/src/mqueuesendsupp.c, posix/src/mqueueopen.c, posix/src/mqueueunlink.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/semunlink.c: Update due to API changes.
* 2011-12-05 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-051-0/+8
| | | | | | | | | | * posix/include/rtems/posix/pthread.h: Add _POSIX_Threads_Initialize_user_threads_body. * rtems/include/rtems/rtems/tasks.h: Add _RTEMS_tasks_Initialize_user_tasks_body. * sapi/include/confdefs.h: Remove conditional, nested redeclaration of _POSIX_Threads_Initialize_user_threads_body, _RTEMS_tasks_Initialize_user_tasks_body.
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script.
* 2011-06-27 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-272-1/+2
| | | | | * posix/include/semaphore.h, posix/include/rtems/posix/mutex.h, posix/inline/rtems/posix/mutex.inl: Fix typos.
* 2011-06-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-2422-77/+106
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h, include/rtems/pci.h, include/rtems/userenv.h, libblock/include/rtems/flashdisk.h, libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h, libcsupport/include/console.h, libcsupport/include/iosupp.h, libcsupport/include/spurious.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h, libcsupport/include/rtems/framebuffer.h, libcsupport/include/rtems/gxx_wrappers.h, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/malloc.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h, libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h, libmisc/capture/capture-cli.h, libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h, libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h, libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h, libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h, libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h, posix/include/mqueue.h, posix/include/semaphore.h, posix/include/rtems/posix/aio_misc.h, posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/posixapi.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/sigset.h, posix/include/rtems/posix/spinlock.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/time.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/priority.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/spinlock.inl, posix/inline/rtems/posix/timer.inl, rtems/mainpage.h, rtems/include/rtems/rtems/barrier.h, rtems/include/rtems/rtems/object.h, rtems/include/rtems/rtems/timer.h, rtems/inline/rtems/rtems/barrier.inl, rtems/inline/rtems/rtems/timer.inl, rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h, sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h, score/include/rtems/score/object.h, score/include/rtems/score/priority.h, score/inline/rtems/score/object.inl, score/inline/rtems/score/priority.inl: Add @file Doxygen directives and descriptions to files which originated with RTEMS. This improves the file list page generated by Doxygen.
* 2011-06-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-171-2/+3
| | | | | | | | | | | | | | | | | | | * libcsupport/include/rtems/malloc.h, libmisc/stackchk/stackchk.h, posix/include/rtems/posix/time.h, rtems/include/rtems/rtems/object.h, score/include/rtems/score/apiext.h, score/include/rtems/score/interr.h, score/include/rtems/score/mpci.h, score/include/rtems/score/objectmp.h, score/include/rtems/score/thread.h, score/include/rtems/score/threadmp.h, score/include/rtems/score/threadq.h, score/include/rtems/score/timespec.h, score/include/rtems/score/timestamp.h, score/include/rtems/score/timestamp64.h, score/include/rtems/score/tod.h, score/include/rtems/score/watchdog.h, score/include/rtems/score/wkspace.h: Make @brief formatting more consistent. * score/include/rtems/score/rbtree.h: Also reformat.
* Add missing includes.Ralf Corsepius2011-02-242-1/+2
* 2011-02-23 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-231-4/+4
| | | | * posix/include/rtems/posix/mqueue.h: Relocate "extern C++" guards.
* 2011-02-23 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-231-0/+2
| | | | * posix/include/rtems/posix/key.h: Add missing includes.
* 2011-02-23 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-231-5/+6
| | | | * posix/include/mqueue.h: Relocate "extern C++" guards.
* 2010-11-01 Alin Rus <alin.codejunkie@gmail.com>Joel Sherrill2010-11-011-3/+3
| | | | | * posix/include/rtems/posix/aio_misc.h, posix/src/aio_misc.c: Small fixes.
* Remove.Ralf Corsepius2010-08-301-48/+0
* 2010-08-16 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-08-201-1/+1
| | | | | * posix/include/rtems/posix/aio_misc.h: Add decl for aio_request_queue. * posix/src/aio_misc.c: Add aio_request_queue.
* 2010-08-16 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-08-201-3/+3
| | | | | * posix/include/rtems/posix/aio_misc.h: Remove rtems_aio_request_s, rtems_aio_request_chain_s, rtems_aio_queue_s;
* 2010-08-16 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-08-201-4/+11
| | | | | * posix/include/aio.h: Separate LIO-modes from LIO-opcodes (From freebsd).
* 2010-08-16 Alin Rus <alin.codejunkie@gmail.com>Ralf Corsepius2010-08-202-5/+14
| | | | | | | | * posix/include/aio.h: Add LIO_SYNC. * posix/include/rtems/posix/aio_misc.h: Add aio_request_queue, Cosmetics. * posix/src/aio_cancel.c, posix/src/aio_fsync.c, posix/src/aio_misc.c: Rework.
* 2010-08-16 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-08-161-1/+0
| | | | | | | * posix/include/rtems/posix/aio_misc.h: Remove rtems_aio_queue_s.size (Unused). * posix/src/aio_misc.c: Remove aio_request_queue.size. Cosmetics.
* 2010-08-16 Alin Rus <alin.codejunkie@gmail.com>Ralf Corsepius2010-08-162-0/+105
| | | | | * posix/include/aio.h: Extend struct aiocb. * posix/include/rtems/posix/aio_misc.h: New.
* 2010-08-09 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-08-091-3/+3
| | | | | * posix/include/aio.h, posix/src/aio_return.c: Let aio_return return ssize_t (Mandated by POSIX).
* 2010-07-26 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-261-1/+12
| | | | | | | | | | * libcsupport/src/privateenv.c, libmisc/cpuuse/cpuusagereport.c, posix/Makefile.am, posix/include/rtems/posix/key.h, posix/src/keycreate.c, posix/src/keydelete.c, score/src/iterateoverthreads.c: Since removing ITRON, the loop over all APIs for tasks has a path that cannot be reached. Either modify the code or mark tests for NULL as RTEMS_DEBUG. * posix/src/keyfreememory.c: New file.
* 2010-06-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-06-151-4/+11
| | | | * posix/include/rtems/posix/pthread.h: Improve comments.
* 2010-06-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-151-3/+3
| | | | | * posix/include/rtems/posix/pthread.h: Remove stray comment. Work-around doxygen comment bug.
* 2010-06-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-141-3/+3
| | | | | | | | | * libnetworking/rtems/mkrootfs.h, posix/include/rtems/posix/pthread.h, score/include/rtems/score/coresem.h, score/include/rtems/score/priority.h, score/include/rtems/score/threadq.h, score/include/rtems/score/timestamp.h: Move 'extern "C"'.
* 2010-06-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-141-0/+8
| | | | * posix/include/rtems/posix/threadsup.h: Add extern "C".
* 2010-06-12 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-121-1/+1
| | | | * posix/include/devctl.h: Move mal-placed @file.
* 2010-04-03 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-04-031-105/+0
| | | | | * posix/include/sched.h: Remove. * posix/Makefile.am: Remove include/sched.h.
* Reflect having split out posix/include/rtems/posix/sigset.h.Ralf Corsepius2009-12-041-17/+1
* 2009-12-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-12-041-0/+42
| | | | | * posix/include/rtems/posix/sigset.h: New (Split out from posix/include/rtems/posix/psignal.h).
* Whitespace removal.Ralf Corsepius2009-11-309-11/+11
* 2009-10-10 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-10-101-1/+1
| | | | | | | * posix/include/rtems/posix/threadsup.h, posix/src/cancel.c, posix/src/canceleval.c: Make psxcancel run again. _POSIX_Thread_Exit() can be called on running thread or another thread when it is cancelled.
* 2009-10-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-10-041-0/+2
| | | | | | | * posix/include/rtems/posix/psignal.h: Add extern for ualarm timer. * posix/src/alarm.c, posix/src/ualarm.c: Change from switch to if since many enumerated values have no action. * posix/src/psignal.c: Initialize ualarm and alarm timers.
* 2009-09-25 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-09-251-1/+1
| | | | | * posix/include/rtems/posix/threadsup.h: Add no return atrribute to _POSIX_Thread_Exit().
