* inline/rtems/posix/timer.inl, include/rtems/posix/timer.h,
inline/rtems/posix/Makefile.am, src/ptimer1.c: Redid the
style of src/ptimer1.c. Continued effort to make the
POSIX Timer implementation match that of other managers.
Added data structures required to use SuperCore Object Handler.
* src/ptimer1.c: Removed unused routine PRINT_ERRNO_S.
* src/ptimer1.c: Removed unnecessary routine COPY_ITIMERSPEC_S
and used structure copy instead.
* src/ptimer1.c: Renamed timer_alive_t to POSIX_Timer_Control.
* include/rtems/posix/timer.h: Ditto.
were done by Joel.
Addtional major bugs:
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
internal symbols are supposed to have leading underscores.
of POSIX Init thread to be user configured.
and _POSIX_signals_Set_process_signals was done twice.
object code that has to be loaded just for initializing the signal
manager.
split into multiple files.
it work.
the system signals.h file.
Moved POSIX_signals_Siginfo_node type definition to this file to allow
confdefs.h to know the size per queued signal.
Ada interface where entry is a keyword.
of lowest priority with the RTEMS IDLE thread. This was causing the lowest
priority GNAT Ada task to never run.
visible to other files.
condition variable
psignal.h: fixed typo.
