Delete unused POSIX_Message_queue_Control::named.
Delete unused POSIX_Message_queue_Control::process_shared.
Make _POSIX_Message_queue_Create_support() static since it is only used
by mq_open().
Update #2555.
Update #2555.
Use _Thread_queue_Flush_critical() to atomically release the barrier.
Update #2555.
This simplifies the code since the object location is no longer used.
Remove superfluous header includes.
Avoid Giant lock for CORE mutex and semaphore flush and delete
operations.
Update #2555.
Make the id the first parameter since usual callers get the object
identifier as the first parameter themself.
Delete _POSIX_Mutex_Get(). Use _POSIX_Mutex_Get_interrupt_disable()
instead.
Update #2555.
Remove superfluous location parameter.
Use proper CORE_semaphore_Status for _CORE_semaphore_Flush() and
_CORE_semaphore_Destroy() operations.
Close #2696.
Apparently killinfo() is not defined by POSIX, glibc or FreeBSD. Rename
killinfo() to _POSIX_signals_Send() to cleary mark it as an internal
function.
This functions supports only local objects. Thus, drop the location
parameter which was unused by all callers.
Remove superfluous includes from Classic Region implementation.
Update #2555.
The thread queue implementation was heavily reworked to support SMP.
This broke the multiprocessing support of the thread queues. This is
fixed by this patch.
A thread proxy is unblocked due to three reasons
1) timeout,
2) request satisfaction, and
3) extraction.
In case 1) no MPCI message must be sent. This is ensured via the
_Thread_queue_MP_callout_do_nothing() callout set during
_Thread_MP_Allocate_proxy().
In case 2) and 3) an MPCI message must be sent. In case we interrupt
the blocking operation during _Thread_queue_Enqueue_critical(), then
this message must be sent by the blocking thread. For this the new
fields Thread_Proxy_control::thread_queue_callout and
Thread_Proxy_control::thread_queue_id are used.
Delete the individual API MP callout types and use
Thread_queue_MP_callout throughout. This type is only defined in
multiprocessing configurations. Prefix the multiprocessing parameters
with mp_ to ease code review. Multiprocessing specific parameters are
optional due to use of a similar macro pattern. There is no overhead
for non-multiprocessing configurations.
This field was only by the monitor in non-multiprocessing
configurations. Add new field Thread_Wait_information::remote_id in
multiprocessing configurations and use it for the remote procedure call
thread queue.
Add _Thread_Wait_get_id() to obtain the object identifier for debug and
system information tools. Ensure the object layout via static asserts.
Add test cases to sptests/spthreadq01.
Remove the Thread_queue_Queue::operations field to reduce the size of
this structure. Add a thread queue operations parameter to the
_Thread_queue_First(), _Thread_queue_First_locked(),
_Thread_queue_Enqueue(), _Thread_queue_Dequeue() and
_Thread_queue_Flush() functions. This is a preparation patch to reduce
the size of several synchronization objects.
Use an ISR lock to protect the spinlock state. Remove empty attributes.
Update #2555.
Replace _Objects_Name_to_id_string() with _Objects_Get_by_name() since
all users of this function are interested in the object itself and not
the identifier.
Use the object allocator lock to protect the search.
Update #2555.
Yields higher performance on SMP systems.
Close #2625.
This simplifies the handling with local-only objects.
Update #2555.
Use a red-black tree instead of delta chains.
Close #2344.
Update #2554.
Update #2555.
Close #2606.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Store the unblock signals to exploit the zero-initialization of the
thread control block.
This structure is available in Newlib since 2013-11-29 (Git commit
a534dfd26e765047621acd0eda656ded886e7108).
Updates #2405.
Rename _POSIX_Absolute_timeout_to_ticks() to
_TOD_Absolute_timeout_to_ticks() and move it to the score directory.
Delete empty <rtems/posix/time.h>.
Move the storage for the thread queue heads to the threads. Each thread
provides a set of thread queue heads allocated from a dedicated memory
pool. In case a thread blocks on a queue, then it lends its heads to
the queue. In case the thread unblocks, then it takes a free set of
threads from the queue. Since a thread can block on at most one queue
this works. This mechanism is used in FreeBSD. The motivation for this
change is to reduce the memory demands of the synchronization objects.
On a 32-bit uni-processor configuration the Thread_queue_Control size is
now 8 bytes, compared to 64 bytes in RTEMS 4.10 (other changes reduced
the size as well).
Replace the extend function with an allocator since this fits better
to the current use case.
Avoid Thread_Control typedef in <rtems/score/percpu.h>. This helps to
get rid of the <rtems/score/percpu.h> include in <rtems/score/thread.h>
which exposes a lot of implementation details.
