* include/rtems/posix/cond.h, include/rtems/posix/condmp.h,
include/rtems/posix/config.h, include/rtems/posix/intr.h,
include/rtems/posix/key.h, include/rtems/posix/mqueue.h,
include/rtems/posix/mqueuemp.h, include/rtems/posix/mutex.h,
include/rtems/posix/mutexmp.h, include/rtems/posix/posixapi.h,
include/rtems/posix/pthread.h, include/rtems/posix/pthreadmp.h,
include/rtems/posix/ptimer.h, include/rtems/posix/semaphore.h,
include/rtems/posix/semaphoremp.h, inline/rtems/posix/cond.inl,
inline/rtems/posix/intr.inl, inline/rtems/posix/key.inl,
inline/rtems/posix/mqueue.inl, inline/rtems/posix/mutex.inl,
inline/rtems/posix/pthread.inl, inline/rtems/posix/semaphore.inl,
inline/rtems/posix/timer.inl, macros/rtems/posix/cond.inl,
macros/rtems/posix/intr.inl, macros/rtems/posix/key.inl,
macros/rtems/posix/mqueue.inl, macros/rtems/posix/mutex.inl,
macros/rtems/posix/pthread.inl, macros/rtems/posix/semaphore.inl,
macros/rtems/posix/timer.inl, src/alarm.c, src/kill.c,
src/killinfo.c, src/mqueuetranslatereturncode.c, src/pause.c,
src/pthreadattrdestroy.c, src/pthreadattrgetdetachstate.c,
src/pthreadattrgetinheritsched.c, src/pthreadattrgetschedparam.c,
src/pthreadattrgetschedpolicy.c, src/pthreadattrgetscope.c,
src/pthreadattrgetstackaddr.c, src/pthreadattrgetstacksize.c,
src/pthreadattrinit.c, src/pthreadattrsetdetachstate.c,
src/pthreadattrsetinheritsched.c, src/pthreadattrsetschedparam.c,
src/pthreadattrsetschedpolicy.c, src/pthreadattrsetscope.c,
src/pthreadattrsetstackaddr.c, src/pthreadattrsetstacksize.c,
src/pthreadcreate.c, src/pthreaddetach.c, src/pthreadequal.c,
src/pthreadexit.c, src/pthreadgetcpuclockid.c,
src/pthreadgetcputime.c, src/pthreadgetschedparam.c,
src/pthreadjoin.c, src/pthreadkill.c, src/pthreadonce.c,
src/pthreadself.c, src/pthreadsetcputime.c,
src/pthreadsetschedparam.c, src/pthreadsigmask.c, src/sigaction.c,
src/sigaddset.c, src/sigdelset.c, src/sigemptyset.c,
src/sigfillset.c, src/sigismember.c, src/signal_2.c,
src/sigpending.c, src/sigprocmask.c, src/sigqueue.c,
src/sigsuspend.c, src/sigtimedwait.c, src/sigwait.c,
src/sigwaitinfo.c, src/ualarm.c: URL for license changed.
* inline/Makefile.am: Remove.
* macros/Makefile.am: Remove.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in removed Makefile.ams.
* include/rtems/posix/timer.h, src/keygetspecific.c,
src/posixtimespecsubtract.c, src/ptimer1.c, src/semunlink.c:
Added casts to eliminate warnings on 16-bit targets like the h8300.
* include/rtems/posix/cancel.h, src/cancel.c, src/cancelrun.c,
src/mqueue.c, src/pthread.c, src/semaphore.c, src/setcancelstate.c,
src/setcanceltype.c, src/testcancel.c: Per PR164, corrected the
behavior of thread cancellation and did some cleanup as a side-effect.
* Mega patch merge to change the format of the object IDs to
loosen the dependency between the SCORE and the various APIs.
There was considerable work to simplify the object name management
and it appears that the name_table field is no longer needed.
This patch also includes the addition of the internal mutex
which is currently only used to protect some types of allocation
and deallocation. This significantly can reduce context
switch latency under certain circumstances. In particular,
some heap/region operations were O(n) and had dispatching
disabled. This should help enormously. With this merge,
the patch is not as clean as it should be. In particular,
the documentation has not been modified to reflect the new object
ID layout, the IDs in the test screens are not updated, and
_Objects_Get_information needs to be a real routine not inlined.
As part of this patch a lot of MP code for thread/proxy blocking
was made conditional and cleaned up.
* include/rtems/posix/key.h, src/cond.c, src/condinit.c, src/intr.c,
src/key.c, src/keycreate.c, src/keydelete.c, src/killinfo.c,
src/mqueue.c, src/mqueuecreatesupp.c, src/mutex.c, src/mutexinit.c,
src/psignal.c, src/pthread.c, src/semaphore.c,
src/semaphorecreatesupp.c: Modified as part of above.
Use ../aclocal.
* inline/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* macros/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/sys/utsname.h: Remove.
* include/Makefile.am: Reflect changes above.
* src/utsname.c: Remove.
* src/Makefile.am: Reflect changes above.
* include/rtems/posix/mqueue.h, inline/rtems/posix/mqueue.inl,
src/mqueue.c, src/mqueueclose.c, src/mqueuecreatesupp.c,
src/mqueuegetattr.c, src/mqueuenotify.c, src/mqueueopen.c,
src/mqueuerecvsupp.c, src/mqueuesendsupp.c, src/mqueuesetattr.c:
Per PR81 reworked to add a message queue descriptor separate from
the underlying message queue. This allows non-blocking to follow
the "open" not the underlying queue.
* inline/Makefile.am: Remove AUTOMAKE_OPTIONS.
* macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/sys/Makefile.am: Remove.
* include/rtems/posix/Makefile.am: Remove.
* include/Makefile.am: Handle subdirs.
* inline/rtems/posix/Makefile.am: Remove.
* inline/Makefile.am: Handle subdirs.
* macros/rtems/posix/Makefile.am: Remove.
* macros/Makefile.am: Handle subdirs.
* include/sys/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='.
* inline/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='.
* macros/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/Makefile.am, include/rtems/posix/Makefile.am,
include/sys/Makefile.am, inline/rtems/posix/Makefile.am,
* include/rtems/posix/semaphore.h, inline/rtems/posix/semaphore.inl,
src/ptimer1.c, include/rtems/posix/semaphore.h,
inline/rtems/posix/semaphore.inl, src/alarm.c, src/ptimer1.c,
src/semaphorenametoid.c, src/semopen.c, src/semunlink.c:
Modifications to make CodeWarrior happy.
* include/rtems/posix/cond.h: #if 0'ed out prototype of
_POSIX_Condition_variables_Get to avoid conflict with macro
implementation.
* Added macro support to POSIX API. This is known to compile.
* macros/rtems/posix/cond.inl, macros/rtems/posix/intr.inl,
macros/rtems/posix/key.inl, macros/rtems/posix/mqueue.inl,
macros/rtems/posix/mutex.inl, macros/rtems/posix/priority.inl,
macros/rtems/posix/timer.inl: New files.
* configure.in: Removed error check for enabling macros.
* rtems/posix/mutex.h: #if 0'ed out prototypes for inlined routines
since you cannot have prototypes for macros.
* macros/rtems/posix/Makefile.am: Added files.
* include/Makefile.am: Updated to reflect files merged into newlib.
This resulted in some definitions moving to other files and thus
some secondary effects in RTEMS source code.
* include/unistd.h: Removed. Now use newlib's.
* include/rtems/posix/mqueue.h: Add include of <signal.h>.
* include/rtems/posix/threadsup.h: Add include of <sys/signal.h>
* src/execv.c: Corrected prototype to agree with newlib.
* src/execve.c: Corrected prototype to agree with newlib.
* src/execvp.c: Corrected prototype to agree with newlib.
* src/psignal.c: Rewrote reference to <siginfo.h> in comment since
that file no longer exists.
* src/pthreadkill.c: Added include of <signal.h>.
* src/sigaction.c: Added include of <signal.h>.
* src/sigtimedwait.c: Rewrote reference to <siginfo.h> in comment since
* inline/rtems/posix/timer.inl, include/rtems/posix/timer.h,
inline/rtems/posix/Makefile.am, src/ptimer1.c: Redid the
style of src/ptimer1.c. Continued effort to make the
POSIX Timer implementation match that of other managers.
Added data structures required to use SuperCore Object Handler.
* src/ptimer1.c: Removed unused routine PRINT_ERRNO_S.
* src/ptimer1.c: Removed unnecessary routine COPY_ITIMERSPEC_S
and used structure copy instead.
* src/ptimer1.c: Renamed timer_alive_t to POSIX_Timer_Control.
* include/rtems/posix/timer.h: Ditto.
were done by Joel.
Addtional major bugs:
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
internal symbols are supposed to have leading underscores.
of POSIX Init thread to be user configured.
and _POSIX_signals_Set_process_signals was done twice.
object code that has to be loaded just for initializing the signal
manager.
split into multiple files.
it work.
