* | moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to here so it would be | Joel Sherrill | 1996-09-08 | 1 | -0/+2 | |
| | | | | visible to other files. | |||||
* | added constant to indicate there is no mutex associated with this | Joel Sherrill | 1996-08-15 | 1 | -0/+7 | |
| | | | | condition variable | |||||
* | mutex.h: removes the promotion of core status code to POSXI status codes | Mark Johannes | 1996-08-12 | 1 | -12/+0 | |
* | mutex.h: promoted out _POSIX_Mutex_From_core_mutex_status | Mark Johannes | 1996-08-12 | 1 | -0/+12 | |
* | added ss_high_priority field to support sporadic server. | Joel Sherrill | 1996-08-08 | 1 | -0/+1 | |
* | switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE" | Joel Sherrill | 1996-07-03 | 8 | -32/+32 | |
* | fields for init threads stuff said tasks. | Joel Sherrill | 1996-06-14 | 1 | -2/+2 | |
* | config.h: added maximum_queued_signals. | Joel Sherrill | 1996-06-13 | 2 | -1/+4 | |
| | | | | psignal.h: fixed typo. | |||||
* | added prototype for manager initialization routine. | Joel Sherrill | 1996-06-13 | 1 | -0/+2 | |
* | deleted field for signals_global_pending. | Joel Sherrill | 1996-06-11 | 1 | -1/+0 | |
* | new file. | Joel Sherrill | 1996-06-11 | 1 | -1/+1 | |
* | added psignal.h | Joel Sherrill | 1996-06-10 | 1 | -0/+13 | |
* | *** empty log message *** | Joel Sherrill | 1996-06-10 | 1 | -1/+1 | |
* | in newlib now | Joel Sherrill | 1996-06-06 | 1 | -0/+4 | |
* | added Sporadic_timer field to support sporadic server | Joel Sherrill | 1996-06-06 | 1 | -0/+1 | |
* | added comments to priority.h to document the definition of posix priority | Joel Sherrill | 1996-06-05 | 2 | -2/+6 | |
| | | | | | | and how it corresponds to rtems core priority. Schedule was renamed schedparam | |||||
* | added scheduling policy and parameter information | Joel Sherrill | 1996-06-04 | 1 | -0/+3 | |
* | added thread queue for list of threads waiting to join. | Joel Sherrill | 1996-06-03 | 1 | -0/+2 | |
* | deleted POSIX threads typedef masking Thread_Control | Joel Sherrill | 1996-06-03 | 2 | -11/+6 | |
* | renamed _POSIX_Time_Spec_to_interval to _POSIX_Timespec_to_interval | Joel Sherrill | 1996-06-03 | 1 | -1/+15 | |
* | added constant for seconds between posix epoch (1970) and rtems epoch (1988). | Joel Sherrill | 1996-06-03 | 1 | -0/+11 | |
| | | | | Formerly this constant was in the file src/time.c. | |||||
* | commented out cancel handlers related items. | Joel Sherrill | 1996-05-31 | 1 | -0/+3 | |
* | posix initialization threads table was misnamed "posix initialization | Joel Sherrill | 1996-05-29 | 2 | -14/+14 | |
| | | | | tasks table" | |||||
* | first cut at pthread_create | Joel Sherrill | 1996-05-29 | 1 | -3/+3 | |
* | added entry point for posix initialization threads to the posix initialization | Joel Sherrill | 1996-05-29 | 1 | -2/+8 | |
| | | | | threads table structure | |||||
* | split the inclusion of "EXTERN" data based on whether it was sapi, | Joel Sherrill | 1996-05-28 | 8 | -10/+48 | |
| | | | | score, rtems api, or posix api related. | |||||
* | added initial set of api extension callouts | Joel Sherrill | 1996-05-28 | 2 | -2/+16 | |
* | commented out interrupt support | Joel Sherrill | 1996-05-28 | 1 | -0/+2 | |
* | added maximum keys | Joel Sherrill | 1996-05-28 | 1 | -0/+1 | |
* | added initial posix configuration support | Joel Sherrill | 1996-05-28 | 1 | -0/+51 | |
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 1 | -1/+1 | |
| | | | | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. The removed files were moved to newlib as they were duplicates of files already included there. | |||||
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 1 | -2/+1 | |
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 8 | -0/+9 | |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 22 | -0/+2435 | |
