* | *** empty log message *** | Joel Sherrill | 1996-06-10 | 1 | -1/+1 | |
* | in newlib now | Joel Sherrill | 1996-06-06 | 1 | -0/+4 | |
* | added Sporadic_timer field to support sporadic server | Joel Sherrill | 1996-06-06 | 1 | -0/+1 | |
* | added comments to priority.h to document the definition of posix priority | Joel Sherrill | 1996-06-05 | 2 | -2/+6 | |
| | | | | | | and how it corresponds to rtems core priority. Schedule was renamed schedparam | |||||
* | added scheduling policy and parameter information | Joel Sherrill | 1996-06-04 | 1 | -0/+3 | |
* | added thread queue for list of threads waiting to join. | Joel Sherrill | 1996-06-03 | 1 | -0/+2 | |
* | deleted POSIX threads typedef masking Thread_Control | Joel Sherrill | 1996-06-03 | 2 | -11/+6 | |
* | renamed _POSIX_Time_Spec_to_interval to _POSIX_Timespec_to_interval | Joel Sherrill | 1996-06-03 | 1 | -1/+15 | |
* | added constant for seconds between posix epoch (1970) and rtems epoch (1988). | Joel Sherrill | 1996-06-03 | 1 | -0/+11 | |
| | | | | Formerly this constant was in the file src/time.c. | |||||
* | commented out cancel handlers related items. | Joel Sherrill | 1996-05-31 | 1 | -0/+3 | |
* | posix initialization threads table was misnamed "posix initialization | Joel Sherrill | 1996-05-29 | 2 | -14/+14 | |
| | | | | tasks table" | |||||
* | first cut at pthread_create | Joel Sherrill | 1996-05-29 | 1 | -3/+3 | |
* | added entry point for posix initialization threads to the posix initialization | Joel Sherrill | 1996-05-29 | 1 | -2/+8 | |
| | | | | threads table structure | |||||
* | split the inclusion of "EXTERN" data based on whether it was sapi, | Joel Sherrill | 1996-05-28 | 8 | -10/+48 | |
| | | | | score, rtems api, or posix api related. | |||||
* | added initial set of api extension callouts | Joel Sherrill | 1996-05-28 | 2 | -2/+16 | |
* | commented out interrupt support | Joel Sherrill | 1996-05-28 | 1 | -0/+2 | |
* | added maximum keys | Joel Sherrill | 1996-05-28 | 1 | -0/+1 | |
* | added initial posix configuration support | Joel Sherrill | 1996-05-28 | 1 | -0/+51 | |
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 1 | -2/+1 | |
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 2 | -0/+2 | |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 16 | -0/+1862 | |
