* | Added #define for SEM_FAILED. | Joel Sherrill | 1999-11-02 | 1 | -0/+2 |
* | Added include of <sys/siginfo.h>. | Joel Sherrill | 1999-11-02 | 1 | -0/+2 |
* | Added message queues and semaphores. | Joel Sherrill | 1999-11-02 | 1 | -1/+3 |
* | Patch from Jiri Gaisler <jgais@ws.estec.esa.nl> to allow stacksize | Joel Sherrill | 1999-05-07 | 1 | -0/+1 |
| | | | | of POSIX Init thread to be user configured. | ||||
* | Enabled cancellation information in POSIX API thread extension structure. | Joel Sherrill | 1999-04-15 | 1 | -2/+0 |
* | Fixed typo where _POSIX_signals_Clear_process_signals was not prototyped | Joel Sherrill | 1999-03-30 | 1 | -1/+1 |
| | | | | and _POSIX_signals_Set_process_signals was done twice. | ||||
* | Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-03-01 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | > 5) rtems-rc-19990202-1.diff/reorg-install.sh > > reorg-install.sh fixes a Makefile variable name clash of RTEMS > configuration files and automake/autoconf standards. > Until now, RTEMS used $(INSTALL) for install-if-change. Automake and > autoconf use $(INSTALL) for a bsd-compatible install. As > install-if-change and bsd-install are not compatible, I renamed all > references to install-if-changed to $(INSTALL_CHANGED) and used > $(INSTALL) for bsd-install (==automake/autoconf standard). When > automake will be introduced install-if-change will probably be replaced > by $(INSTALL) and therefore will slowly vanish. For the moment, this > patch fixes a very nasty problem which prevents adding any automake file > until now (There are still more). | ||||
* | POSIX Timers submitted by Juan Zamorano Flores | Joel Sherrill | 1999-02-03 | 2 | -0/+92 |
| | | | | <jzamora@avellano.datsi.fi.upm.es>. | ||||
* | Split psignal.c into many more files. This reduced the amount of | Joel Sherrill | 1999-01-31 | 1 | -0/+93 |
| | | | | | object code that has to be loaded just for initializing the signal manager. | ||||
* | Added enough prototypes to allow most of POSIX Threads Manager to be | Joel Sherrill | 1999-01-25 | 1 | -0/+26 |
| | | | | split into multiple files. | ||||
* | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 1998-11-23 | 5 | -0/+10 |
| | | | | it work. | ||||
* | Changed __POSIX_SIGNALS_h to __RTEMS_POSIX_SIGNALS_h to avoid conflict with | Joel Sherrill | 1998-04-27 | 1 | -2/+7 |
| | | | | | | | the system signals.h file. Moved POSIX_signals_Siginfo_node type definition to this file to allow confdefs.h to know the size per queued signal. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 14 | -14/+14 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 14 | -28/+28 |
* | Changed name from entry to thread_entry to be more compatible with | Joel Sherrill | 1997-07-09 | 1 | -1/+1 |
| | | | | Ada interface where entry is a keyword. | ||||
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 14 | -70/+70 |
* | Reduced number of POSIX thread priorities from 255 to 254 to avoid conflicts | Joel Sherrill | 1997-04-15 | 1 | -1/+7 |
| | | | | | of lowest priority with the RTEMS IDLE thread. This was causing the lowest priority GNAT Ada task to never run. | ||||
* | added prototype for _POSIX_Timespec_subtract | Joel Sherrill | 1996-09-17 | 1 | -0/+11 |
* | moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to here so it would be | Joel Sherrill | 1996-09-08 | 1 | -0/+2 |
| | | | | visible to other files. | ||||
* | added constant to indicate there is no mutex associated with this | Joel Sherrill | 1996-08-15 | 1 | -0/+7 |
| | | | | condition variable | ||||
* | mutex.h: removes the promotion of core status code to POSXI status codes | Mark Johannes | 1996-08-12 | 1 | -12/+0 |
* | mutex.h: promoted out _POSIX_Mutex_From_core_mutex_status | Mark Johannes | 1996-08-12 | 1 | -0/+12 |
* | added ss_high_priority field to support sporadic server. | Joel Sherrill | 1996-08-08 | 1 | -0/+1 |
* | switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE" | Joel Sherrill | 1996-07-03 | 8 | -32/+32 |
* | fields for init threads stuff said tasks. | Joel Sherrill | 1996-06-14 | 1 | -2/+2 |
* | config.h: added maximum_queued_signals. | Joel Sherrill | 1996-06-13 | 2 | -1/+4 |
| | | | | psignal.h: fixed typo. | ||||
* | added prototype for manager initialization routine. | Joel Sherrill | 1996-06-13 | 1 | -0/+2 |
* | deleted field for signals_global_pending. | Joel Sherrill | 1996-06-11 | 1 | -1/+0 |
* | new file. | Joel Sherrill | 1996-06-11 | 1 | -1/+1 |
* | added psignal.h | Joel Sherrill | 1996-06-10 | 1 | -0/+13 |
* | *** empty log message *** | Joel Sherrill | 1996-06-10 | 1 | -1/+1 |
* | in newlib now | Joel Sherrill | 1996-06-06 | 1 | -0/+4 |
* | added Sporadic_timer field to support sporadic server | Joel Sherrill | 1996-06-06 | 1 | -0/+1 |
* | added comments to priority.h to document the definition of posix priority | Joel Sherrill | 1996-06-05 | 2 | -2/+6 |
| | | | | | | and how it corresponds to rtems core priority. Schedule was renamed schedparam | ||||
* | added scheduling policy and parameter information | Joel Sherrill | 1996-06-04 | 1 | -0/+3 |
* | added thread queue for list of threads waiting to join. | Joel Sherrill | 1996-06-03 | 1 | -0/+2 |
* | deleted POSIX threads typedef masking Thread_Control | Joel Sherrill | 1996-06-03 | 2 | -11/+6 |
* | renamed _POSIX_Time_Spec_to_interval to _POSIX_Timespec_to_interval | Joel Sherrill | 1996-06-03 | 1 | -1/+15 |
* | added constant for seconds between posix epoch (1970) and rtems epoch (1988). | Joel Sherrill | 1996-06-03 | 1 | -0/+11 |
| | | | | Formerly this constant was in the file src/time.c. | ||||
* | commented out cancel handlers related items. | Joel Sherrill | 1996-05-31 | 1 | -0/+3 |
* | posix initialization threads table was misnamed "posix initialization | Joel Sherrill | 1996-05-29 | 2 | -14/+14 |
| | | | | tasks table" | ||||
* | first cut at pthread_create | Joel Sherrill | 1996-05-29 | 1 | -3/+3 |
* | added entry point for posix initialization threads to the posix initialization | Joel Sherrill | 1996-05-29 | 1 | -2/+8 |
| | | | | threads table structure | ||||
* | split the inclusion of "EXTERN" data based on whether it was sapi, | Joel Sherrill | 1996-05-28 | 8 | -10/+48 |
| | | | | score, rtems api, or posix api related. | ||||
* | added initial set of api extension callouts | Joel Sherrill | 1996-05-28 | 2 | -2/+16 |
* | commented out interrupt support | Joel Sherrill | 1996-05-28 | 1 | -0/+2 |
* | added maximum keys | Joel Sherrill | 1996-05-28 | 1 | -0/+1 |
* | added initial posix configuration support | Joel Sherrill | 1996-05-28 | 1 | -0/+51 |
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 1 | -2/+1 |
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 2 | -0/+2 |
