* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+2 |
| | | | | adds .cvsignore. | ||||
* | POSIX message queues now include complete functionality including | Joel Sherrill | 2000-01-13 | 1 | -2/+0 |
| | | | | | | | | | | | | | | | | blocking sends when the queue is full. The SuperCore was enhanced to support blocking on send. The existing POSIX API was debugged and numerous test cases were added to psxmsgq01 by Jennifer Averett. SuperCore enhancements and resulting modifications to other APIs were done by Joel. There is one significant point of interpretation for the POSIX API. What happens to threads already blocked on a message queue when the mode of that same message queue is changed from blocking to non-blocking? We decided to unblock all waiting tasks with an EAGAIN error just as if a non-blocking version of the same operation had returned unsatisfied. This case is not discussed in the POSIX standard and other implementations may have chosen differently. | ||||
* | Added priority conversion between POSIX and core priorities. | Jennifer Averett | 2000-01-05 | 1 | -2/+29 |
* | Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-29 | 2 | -7/+20 |
| | | | | | | | | | | | | | | | | | | | | | | | which (among other things) converted the mptests to automake. SUB_DIRS was used instead of SUBDIRS in some Makefile.ins (apparently a leftover from moving the start* directories) Addtional major bugs: * psxtests/include was empty (incomplete psxtests changes). * bogus handling of *.scn in itrontests (screens/sptests vs. screens/itrontests installation dirs) In addition I have added a few more changes (I couldn't resist) * automake support for itrontests * OPERATION_COUNT support in tmitrontests/ * automake support for tmitrontests * automake suppport for mptests * Some (minor) corrections to several configure.in/Makefile.ams => c/src/tests/ is completly under automake control, now. => we could start to sort out the structural issues with c/src/tests (tests/support, stubdr, tools, get "make dist" working) | ||||
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 14 | -28/+14 |
* | Renamed POSIX_Thread_cancel_run to _POSIX_Thread_cancel_run since RTEMS | Joel Sherrill | 1999-11-03 | 1 | -3/+4 |
| | | | | internal symbols are supposed to have leading underscores. | ||||
* | Added prototype of _POSIX_Semaphore_Delete to avoid warnings. | Joel Sherrill | 1999-11-03 | 1 | -0/+12 |
* | Added prototype of POSIX_Thread_cancel_run to avoid warnings. | Joel Sherrill | 1999-11-03 | 1 | -0/+12 |
* | Final tuning required to drop out POSIX timers. | Joel Sherrill | 1999-11-02 | 1 | -0/+25 |
* | *** empty log message *** | Joel Sherrill | 1999-11-02 | 1 | -0/+32 |
* | Split condition variables into multiple files. | Joel Sherrill | 1999-11-02 | 1 | -0/+36 |
* | Split the POSIX semaphore manager into multiple files. | Joel Sherrill | 1999-11-02 | 2 | -1/+38 |
* | Split mutex.c into multiple files. | Joel Sherrill | 1999-11-02 | 1 | -0/+35 |
* | Split mqueue into multiple files. | Joel Sherrill | 1999-11-02 | 1 | -0/+28 |
* | Added #define for SEM_FAILED. | Joel Sherrill | 1999-11-02 | 1 | -0/+2 |
* | Added include of <sys/siginfo.h>. | Joel Sherrill | 1999-11-02 | 1 | -0/+2 |
* | Added message queues and semaphores. | Joel Sherrill | 1999-11-02 | 1 | -1/+3 |
* | Patch from Jiri Gaisler <jgais@ws.estec.esa.nl> to allow stacksize | Joel Sherrill | 1999-05-07 | 1 | -0/+1 |
| | | | | of POSIX Init thread to be user configured. | ||||
* | Enabled cancellation information in POSIX API thread extension structure. | Joel Sherrill | 1999-04-15 | 1 | -2/+0 |
* | Fixed typo where _POSIX_signals_Clear_process_signals was not prototyped | Joel Sherrill | 1999-03-30 | 1 | -1/+1 |
| | | | | and _POSIX_signals_Set_process_signals was done twice. | ||||
* | Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-03-01 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | > 5) rtems-rc-19990202-1.diff/reorg-install.sh > > reorg-install.sh fixes a Makefile variable name clash of RTEMS > configuration files and automake/autoconf standards. > Until now, RTEMS used $(INSTALL) for install-if-change. Automake and > autoconf use $(INSTALL) for a bsd-compatible install. As > install-if-change and bsd-install are not compatible, I renamed all > references to install-if-changed to $(INSTALL_CHANGED) and used > $(INSTALL) for bsd-install (==automake/autoconf standard). When > automake will be introduced install-if-change will probably be replaced > by $(INSTALL) and therefore will slowly vanish. For the moment, this > patch fixes a very nasty problem which prevents adding any automake file > until now (There are still more). | ||||
* | POSIX Timers submitted by Juan Zamorano Flores | Joel Sherrill | 1999-02-03 | 2 | -0/+92 |
| | | | | <jzamora@avellano.datsi.fi.upm.es>. | ||||
* | Split psignal.c into many more files. This reduced the amount of | Joel Sherrill | 1999-01-31 | 1 | -0/+93 |
| | | | | | object code that has to be loaded just for initializing the signal manager. | ||||
* | Added enough prototypes to allow most of POSIX Threads Manager to be | Joel Sherrill | 1999-01-25 | 1 | -0/+26 |
| | | | | split into multiple files. | ||||
* | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 1998-11-23 | 5 | -0/+10 |
| | | | | it work. | ||||
* | Changed __POSIX_SIGNALS_h to __RTEMS_POSIX_SIGNALS_h to avoid conflict with | Joel Sherrill | 1998-04-27 | 1 | -2/+7 |
| | | | | | | | the system signals.h file. Moved POSIX_signals_Siginfo_node type definition to this file to allow confdefs.h to know the size per queued signal. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 14 | -14/+14 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 14 | -28/+28 |
* | Changed name from entry to thread_entry to be more compatible with | Joel Sherrill | 1997-07-09 | 1 | -1/+1 |
| | | | | Ada interface where entry is a keyword. | ||||
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 14 | -70/+70 |
* | Reduced number of POSIX thread priorities from 255 to 254 to avoid conflicts | Joel Sherrill | 1997-04-15 | 1 | -1/+7 |
| | | | | | of lowest priority with the RTEMS IDLE thread. This was causing the lowest priority GNAT Ada task to never run. | ||||
* | added prototype for _POSIX_Timespec_subtract | Joel Sherrill | 1996-09-17 | 1 | -0/+11 |
* | moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to here so it would be | Joel Sherrill | 1996-09-08 | 1 | -0/+2 |
| | | | | visible to other files. | ||||
* | added constant to indicate there is no mutex associated with this | Joel Sherrill | 1996-08-15 | 1 | -0/+7 |
| | | | | condition variable | ||||
* | mutex.h: removes the promotion of core status code to POSXI status codes | Mark Johannes | 1996-08-12 | 1 | -12/+0 |
* | mutex.h: promoted out _POSIX_Mutex_From_core_mutex_status | Mark Johannes | 1996-08-12 | 1 | -0/+12 |
* | added ss_high_priority field to support sporadic server. | Joel Sherrill | 1996-08-08 | 1 | -0/+1 |
* | switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE" | Joel Sherrill | 1996-07-03 | 8 | -32/+32 |
* | fields for init threads stuff said tasks. | Joel Sherrill | 1996-06-14 | 1 | -2/+2 |
* | config.h: added maximum_queued_signals. | Joel Sherrill | 1996-06-13 | 2 | -1/+4 |
| | | | | psignal.h: fixed typo. | ||||
* | added prototype for manager initialization routine. | Joel Sherrill | 1996-06-13 | 1 | -0/+2 |
* | deleted field for signals_global_pending. | Joel Sherrill | 1996-06-11 | 1 | -1/+0 |
* | new file. | Joel Sherrill | 1996-06-11 | 1 | -1/+1 |
* | added psignal.h | Joel Sherrill | 1996-06-10 | 1 | -0/+13 |
* | *** empty log message *** | Joel Sherrill | 1996-06-10 | 1 | -1/+1 |
* | in newlib now | Joel Sherrill | 1996-06-06 | 1 | -0/+4 |
* | added Sporadic_timer field to support sporadic server | Joel Sherrill | 1996-06-06 | 1 | -0/+1 |
* | added comments to priority.h to document the definition of posix priority | Joel Sherrill | 1996-06-05 | 2 | -2/+6 |
| | | | | | | and how it corresponds to rtems core priority. Schedule was renamed schedparam | ||||
* | added scheduling policy and parameter information | Joel Sherrill | 1996-06-04 | 1 | -0/+3 |
* | added thread queue for list of threads waiting to join. | Joel Sherrill | 1996-06-03 | 1 | -0/+2 |
