1999-11-02 | Split mqueue into multiple files. | Joel Sherrill | 1 | -0/+28 | |
1999-11-02 | Added #define for SEM_FAILED. | Joel Sherrill | 1 | -0/+2 | |
1999-11-02 | Added include of <sys/siginfo.h>. | Joel Sherrill | 1 | -0/+2 | |
1999-11-02 | Added message queues and semaphores. | Joel Sherrill | 1 | -1/+3 | |
1999-05-07 | Patch from Jiri Gaisler <jgais@ws.estec.esa.nl> to allow stacksize | Joel Sherrill | 1 | -0/+1 | |
of POSIX Init thread to be user configured. | |||||
1999-04-15 | Enabled cancellation information in POSIX API thread extension structure. | Joel Sherrill | 1 | -2/+0 | |
1999-03-30 | Fixed typo where _POSIX_signals_Clear_process_signals was not prototyped | Joel Sherrill | 1 | -1/+1 | |
and _POSIX_signals_Set_process_signals was done twice. | |||||
1999-03-01 | Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1 | -2/+2 | |
> 5) rtems-rc-19990202-1.diff/reorg-install.sh > > reorg-install.sh fixes a Makefile variable name clash of RTEMS > configuration files and automake/autoconf standards. > Until now, RTEMS used $(INSTALL) for install-if-change. Automake and > autoconf use $(INSTALL) for a bsd-compatible install. As > install-if-change and bsd-install are not compatible, I renamed all > references to install-if-changed to $(INSTALL_CHANGED) and used > $(INSTALL) for bsd-install (==automake/autoconf standard). When > automake will be introduced install-if-change will probably be replaced > by $(INSTALL) and therefore will slowly vanish. For the moment, this > patch fixes a very nasty problem which prevents adding any automake file > until now (There are still more). | |||||
1999-02-03 | POSIX Timers submitted by Juan Zamorano Flores | Joel Sherrill | 2 | -0/+92 | |
<jzamora@avellano.datsi.fi.upm.es>. | |||||
1999-01-31 | Split psignal.c into many more files. This reduced the amount of | Joel Sherrill | 1 | -0/+93 | |
object code that has to be loaded just for initializing the signal manager. | |||||
1999-01-25 | Added enough prototypes to allow most of POSIX Threads Manager to be | Joel Sherrill | 1 | -0/+26 | |
split into multiple files. | |||||
1998-11-23 | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 5 | -0/+10 | |
it work. | |||||
1998-04-27 | Changed __POSIX_SIGNALS_h to __RTEMS_POSIX_SIGNALS_h to avoid conflict with | Joel Sherrill | 1 | -2/+7 | |
the system signals.h file. Moved POSIX_signals_Siginfo_node type definition to this file to allow confdefs.h to know the size per queued signal. | |||||
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 14 | -14/+14 | |
1997-10-08 | Fixed typo in the pointer to the license terms. | Joel Sherrill | 14 | -28/+28 | |
1997-07-09 | Changed name from entry to thread_entry to be more compatible with | Joel Sherrill | 1 | -1/+1 | |
Ada interface where entry is a keyword. | |||||
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | 14 | -70/+70 | |
of switching to the modified GNU GPL. | |||||
1997-04-15 | Reduced number of POSIX thread priorities from 255 to 254 to avoid conflicts | Joel Sherrill | 1 | -1/+7 | |
of lowest priority with the RTEMS IDLE thread. This was causing the lowest priority GNAT Ada task to never run. | |||||
1996-09-17 | added prototype for _POSIX_Timespec_subtract | Joel Sherrill | 1 | -0/+11 | |
1996-09-08 | moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to here so it would be | Joel Sherrill | 1 | -0/+2 | |
visible to other files. | |||||
1996-08-15 | added constant to indicate there is no mutex associated with this | Joel Sherrill | 1 | -0/+7 | |
condition variable | |||||
1996-08-12 | mutex.h: removes the promotion of core status code to POSXI status codes | Mark Johannes | 1 | -12/+0 | |
1996-08-12 | mutex.h: promoted out _POSIX_Mutex_From_core_mutex_status | Mark Johannes | 1 | -0/+12 | |
1996-08-08 | added ss_high_priority field to support sporadic server. | Joel Sherrill | 1 | -0/+1 | |
1996-07-03 | switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE" | Joel Sherrill | 8 | -32/+32 | |
1996-06-14 | fields for init threads stuff said tasks. | Joel Sherrill | 1 | -2/+2 | |
1996-06-13 | config.h: added maximum_queued_signals. | Joel Sherrill | 2 | -1/+4 | |
psignal.h: fixed typo. | |||||
1996-06-13 | added prototype for manager initialization routine. | Joel Sherrill | 1 | -0/+2 | |
1996-06-11 | deleted field for signals_global_pending. | Joel Sherrill | 1 | -1/+0 | |
1996-06-11 | new file. | Joel Sherrill | 1 | -1/+1 | |
1996-06-10 | added psignal.h | Joel Sherrill | 1 | -0/+13 | |
1996-06-10 | *** empty log message *** | Joel Sherrill | 1 | -1/+1 | |
1996-06-06 | in newlib now | Joel Sherrill | 1 | -0/+4 | |
1996-06-06 | added Sporadic_timer field to support sporadic server | Joel Sherrill | 1 | -0/+1 | |
1996-06-05 | added comments to priority.h to document the definition of posix priority | Joel Sherrill | 2 | -2/+6 | |
and how it corresponds to rtems core priority. Schedule was renamed schedparam | |||||
1996-06-04 | added scheduling policy and parameter information | Joel Sherrill | 1 | -0/+3 | |
1996-06-03 | added thread queue for list of threads waiting to join. | Joel Sherrill | 1 | -0/+2 | |
1996-06-03 | deleted POSIX threads typedef masking Thread_Control | Joel Sherrill | 2 | -11/+6 | |
1996-06-03 | renamed _POSIX_Time_Spec_to_interval to _POSIX_Timespec_to_interval | Joel Sherrill | 1 | -1/+15 | |
1996-06-03 | added constant for seconds between posix epoch (1970) and rtems epoch (1988). | Joel Sherrill | 1 | -0/+11 | |
Formerly this constant was in the file src/time.c. | |||||
1996-05-31 | commented out cancel handlers related items. | Joel Sherrill | 1 | -0/+3 | |
1996-05-29 | posix initialization threads table was misnamed "posix initialization | Joel Sherrill | 2 | -14/+14 | |
tasks table" | |||||
1996-05-29 | first cut at pthread_create | Joel Sherrill | 1 | -3/+3 | |
1996-05-29 | added entry point for posix initialization threads to the posix initialization | Joel Sherrill | 1 | -2/+8 | |
threads table structure | |||||
1996-05-28 | split the inclusion of "EXTERN" data based on whether it was sapi, | Joel Sherrill | 8 | -10/+48 | |
score, rtems api, or posix api related. | |||||
1996-05-28 | added initial set of api extension callouts | Joel Sherrill | 2 | -2/+16 | |
1996-05-28 | commented out interrupt support | Joel Sherrill | 1 | -0/+2 | |
1996-05-28 | added maximum keys | Joel Sherrill | 1 | -0/+1 | |
1996-05-28 | added initial posix configuration support | Joel Sherrill | 1 | -0/+51 | |
1995-10-30 | SPARC port passes all tests | Joel Sherrill | 1 | -2/+1 | |
