2016-05-20 | posix: Rework thread cancellation | Sebastian Huber | 1 | -37/+0 | |
Add Thread_Life_state::THREAD_LIFE_CHANGE_DEFERRED and rework the POSIX thread cancellation to use the thread life states. Update #2555. Update #2626. | |||||
2016-02-03 | Optional POSIX Cleanup initialization | Sebastian Huber | 1 | -13/+0 | |
Update #2408. | |||||
2015-11-24 | posix: Require struct _pthread_cleanup_context | Sebastian Huber | 1 | -14/+0 | |
This structure is available in Newlib since 2013-11-29 (Git commit a534dfd26e765047621acd0eda656ded886e7108). | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2013-12-02 | posix: Use cleanup contexts on the stack | Sebastian Huber | 1 | -0/+2 | |
Provide support for latest Newlib <pthread.h> change. The cleanup contexts are stored on the thread stack. This is conformant with the POSIX requirements for the pthread_cleanup_push() and pthread_cleanup_pop() statement pair. Passing an invalid pointer as the routine to pthread_cleanup_push() is now a usage error and the behaviour is undefined. | |||||
2013-01-07 | posix: Doxygen Clean Up Task #1 | Alex Ivanov | 1 | -11/+13 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2009-11-30 | Whitespace removal. | Ralf Corsepius | 1 | -1/+1 | |
2009-07-21 | 2009-07-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -11/+19 | |
* posix/include/rtems/posix/cancel.h, posix/src/cancel.c, posix/src/canceleval.c, posix/src/setcancelstate.c, posix/src/setcanceltype.c: Fix a minor bug in the previous modification which resulted in psxcancel failing. | |||||
2009-07-21 | 2009-07-21 Santosh G Vattam <vattam.santosh@gmail.com> | Joel Sherrill | 1 | -1/+16 | |
* posix/Makefile.am, posix/include/rtems/posix/cancel.h, posix/src/cancel.c, posix/src/setcancelstate.c, posix/src/setcanceltype.c: Add _POSIX_Thread_Evaluate_cancellation_and_enable_dispatch method to avoid duplication of code and ease coverage analysis. * posix/src/canceleval.c: New file. | |||||
2007-12-17 | 2007-12-17 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -1/+7 | |
* posix/preinstall.am, posix/include/aio.h, posix/include/devctl.h, posix/include/mqueue.h, posix/include/sched.h, posix/include/semaphore.h, posix/include/rtems/posix/cancel.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/priority.inl, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cancel.c, posix/src/cancelrun.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/key.c, posix/src/keycreate.c, posix/src/keydelete.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mqueue.c, posix/src/mqueueclose.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenametoid.c, posix/src/mqueuenotify.c, posix/src/mqueueopen.c, posix/src/mqueuereceive.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/ptimer.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/setcancelstate.c, posix/src/setcanceltype.c, posix/src/sysconf.c, posix/src/testcancel.c: Add missing copyright statements. | |||||
2005-02-21 | New header guards. | Ralf Corsepius | 1 | -2/+2 | |
2004-11-21 | Add doxygen preamble. | Ralf Corsepius | 1 | -0/+4 | |
2002-07-05 | 2002-07-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -2/+2 | |
* include/rtems/posix/cancel.h, src/cancel.c, src/cancelrun.c, src/mqueue.c, src/pthread.c, src/semaphore.c, src/setcancelstate.c, src/setcanceltype.c, src/testcancel.c: Per PR164, corrected the behavior of thread cancellation and did some cleanup as a side-effect. | |||||
1999-11-03 | Renamed POSIX_Thread_cancel_run to _POSIX_Thread_cancel_run since RTEMS | Joel Sherrill | 1 | -3/+4 | |
internal symbols are supposed to have leading underscores. | |||||
1999-11-03 | Added prototype of POSIX_Thread_cancel_run to avoid warnings. | Joel Sherrill | 1 | -0/+12 | |
1995-10-06 | fixed missing CVS IDs | Joel Sherrill | 1 | -0/+1 | |
1995-09-26 | posix support initially added | Joel Sherrill | 1 | -0/+15 | |
