* inline/Makefile.am: Remove.
* macros/Makefile.am: Remove.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in removed Makefile.ams.
Use ../aclocal.
* inline/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* macros/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/sys/utsname.h: Remove.
* include/Makefile.am: Reflect changes above.
* src/utsname.c: Remove.
* src/Makefile.am: Reflect changes above.
* inline/Makefile.am: Remove AUTOMAKE_OPTIONS.
* macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/sys/Makefile.am: Remove.
* include/rtems/posix/Makefile.am: Remove.
* include/Makefile.am: Handle subdirs.
* inline/rtems/posix/Makefile.am: Remove.
* inline/Makefile.am: Handle subdirs.
* macros/rtems/posix/Makefile.am: Remove.
* macros/Makefile.am: Handle subdirs.
* include/sys/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='.
* inline/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='.
* macros/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/Makefile.am, include/rtems/posix/Makefile.am,
include/sys/Makefile.am, inline/rtems/posix/Makefile.am,
* include/Makefile.am: Updated to reflect files merged into newlib.
This resulted in some definitions moving to other files and thus
some secondary effects in RTEMS source code.
* include/unistd.h: Removed. Now use newlib's.
* include/rtems/posix/mqueue.h: Add include of <signal.h>.
* include/rtems/posix/threadsup.h: Add include of <sys/signal.h>
* src/execv.c: Corrected prototype to agree with newlib.
* src/execve.c: Corrected prototype to agree with newlib.
* src/execvp.c: Corrected prototype to agree with newlib.
* src/psignal.c: Rewrote reference to <siginfo.h> in comment since
that file no longer exists.
* src/pthreadkill.c: Added include of <signal.h>.
* src/sigaction.c: Added include of <signal.h>.
* src/sigtimedwait.c: Rewrote reference to <siginfo.h> in comment since
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
