path: root/cpukit/posix/ChangeLog (follow)
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+4
| | | | * src/Makefile.am, optman/Makefile.am: Include compile.am.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-301-0/+6
| | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs.
* 2000-08-25 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2000-08-251-0/+8
| | | | | | | | * inline/rtems/posix/timer.inl, include/rtems/posix/timer.h, inline/rtems/posix/Makefile.am, src/ptimer1.c: Redid the style of src/ptimer1.c. Continued effort to make the POSIX Timer implementation match that of other managers. Added data structures required to use SuperCore Object Handler.
* 2000-08-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-151-0/+4
| | | | * src/ptimer1.c: Minor formatting fixes.
* 2000-08-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-151-2/+10
| | | | | | | | * src/ptimer1.c: Removed unused routine PRINT_ERRNO_S. * src/ptimer1.c: Removed unnecessary routine COPY_ITIMERSPEC_S and used structure copy instead. * src/ptimer1.c: Renamed timer_alive_t to POSIX_Timer_Control. * include/rtems/posix/timer.h: Ditto.
* 2000-08-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-151-0/+5
| | | | | * posix/src/ptimer1.c: Switched to using set_errno_and_return_minus_one() to ensure that errno was always set.
| | | | | * posix/src/ptimer1.c (timer_settime): Converted use of rtems_clock_get to use SuperCore _TOD_Current variable.
