[That is, https://github.com/cesanta/mongoose/commit/04fc209644b414d915c446bb1815b55e9fe63acc. See https://groups.google.com/forum/#!topic/mongoose-users/aafbOnHonkI]
The RTEMS patches described in the following emails and made to the previous Mongoose base have been applied:
- http://www.rtems.org/pipermail/rtems-devel/2012-July/001345.html
- http://www.rtems.org/pipermail/rtems-devel/2012-July/001343.html
- http://www.rtems.org/pipermail/rtems-devel/2012-July/001346.html (except to mongoose.1, see below)
...as well as a patch very similar to that discussed at http://forums.bannister.org/ubbthreads.php?ubb=showflat&topic=7600&gonew=1 to provide poll() (which might be able to go away soon, with incoming RTEMS poll() support)
mg_connect(), mg_url_encode() and mg_vprintf() were additionally marked "static" to silence warnings.
mongoose.1 appears to have been removed from the upstream distribution.
Note that the API's changed, for example:
- A struct mg_callbacks must now be provided to mg_start(). Initialise members to NULL to disable various types of callbacks
- Callback interfaces have changed significantly in general
- The short form of options (e.g., "u" instead of "run_as_user") are no longer available (upstream)
- The "max_request_size" options has been removed
Formerly, mghttpd was conditional only on networking being
enabled. It uses on pthread and must also be conditional
on POSIX threads support being enabled.
Update to Mongoose Mercurial revision 268:38a02c8a6744 available at:
https://code.google.com/p/mongoose/
* mghttpd/mongoose.c: crypto_sw table is not used when SSL is disabled.
RTEMS does not have flockfile/funlockfile.
* mghttpd/mongoose.c, mghttpd/mongoose.h, mghttpd/mongoose.1:
Import from svn http://mongoose.googlecode.com/svn/trunk (r477).
