Fix T_check_task_context() in RTEMS_SMP with RTEMS_DEBUG configurations.
Use the user provided now handler of the test configuration to get the
time in T_now().
Use separator character '_' for all test states.
Use the value expected by the RTEMS Tester. There are two separator
characters used ('-' and '_') for the states. This is a bit
inconsistent.
Output only the basename of source files to be independent of the build
system source paths.
In the future it may be better to use the GCC -fmacro-prefix-map option.
This option is available in GCC 8 and later. It is not yet available in
clang.
Update #3818.
This allows more control over the initialization and finalization run.
Update #3199.
This ensures that lines are output atomically if they are produced by
different other contexts, e.g. interrupts, other processors, other
threads.
Update #3199.
Update #3732.
Add rtems_scheduler_get_processor() as a replacement for
rtems_get_current_processor(). The rtems_get_current_processor() is a
bit orphaned. Adopt it by the Scheduler Manager. This is in line with
the glibc sched_getcpu() function.
Deprecate rtems_get_current_processor().
Update #3731.
Update #3199.
One reason to move the test support into a dedicated library are the
standard output __wrap_*() functions. They may conflict with
application level wrappers.
Update #3199.
