2021-09-02 | libtest: Return fixture context in T_case_begin() | Sebastian Huber | 1 | -1/+2 | |
This makes it similar to T_push_fixture(). | |||||
2021-07-29 | score: Add _Per_CPU_Submit_job() | Sebastian Huber | 1 | -3/+1 | |
2021-05-03 | libtest: Fix use of flexible array member | Sebastian Huber | 1 | -12/+12 | |
Flexible array members must not appear in the middle of a structure. | |||||
2021-02-26 | libtest: Print SHA256 hash in base64url | Sebastian Huber | 1 | -7/+6 | |
2021-02-26 | libtest: Report target hash | Sebastian Huber | 1 | -0/+2 | |
Update #4267. | |||||
2021-02-25 | libtest: Report build label | Sebastian Huber | 1 | -0/+1 | |
Update #4269. | |||||
2021-02-24 | libtest: Add support to seize/surrender objects | Sebastian Huber | 1 | -0/+54 | |
2021-02-08 | libtest: Add T_get_thread_timer_state() | Sebastian Huber | 1 | -0/+29 | |
2021-02-01 | libtest: Remove double definition | Sebastian Huber | 1 | -1/+0 | |
2021-02-01 | libtest: Fix implicit type conversions | Sebastian Huber | 2 | -6/+9 | |
This fix relates to a Coverity issue (PW.MIXED_ENUM_TYPE). | |||||
2021-02-01 | libtest: Check return values with RTEMS_DEBUG | Sebastian Huber | 1 | -13/+47 | |
This fix relates to a Coverity issue (UNINIT). | |||||
2021-01-27 | libtest: Remove superfluous NULL pointer check | Sebastian Huber | 1 | -1/+1 | |
This fix relates to CID 1468683 (REVERSE_INULL). | |||||
2021-01-27 | libtest: Use dependency injection | Sebastian Huber | 1 | -5/+11 | |
This helps static analyzers. | |||||
2020-11-24 | libtest: Fix undefined setjmp() behaviour | Sebastian Huber | 1 | -52/+58 | |
Bug was introduced by 78baeb757957fa0807c30e6c4d21ae99c9639e6a. Update #3199. | |||||
2020-11-19 | libtest: Simplify "Load" environment reporting | Sebastian Huber | 1 | -2/+2 | |
Report all runtime measurement environments with a name only and encode the worker count of the "Load" environment in the name. Update #3199. | |||||
2020-11-19 | libtest: Allow assert checks during test begin | Sebastian Huber | 1 | -12/+17 | |
Allow assert checks in test begin actions and setup fixture methods. | |||||
2020-11-19 | libtest: Rename ValidCache in FullCache | Sebastian Huber | 1 | -5/+5 | |
This name better reflects the execution envirnoment in which the cache is fully loaded with valid data unrelated to the body request handler. | |||||
2020-11-19 | libtest: Add primitive test case memory allocator | Sebastian Huber | 1 | -0/+86 | |
This primitive test case memory allocator uses memory from the low-level memory information provided by the BSP. At the beginning of each test case, the memory available to the test case is reinitialized. This allows the use of a simple allocate only allocator. | |||||
2020-11-19 | libtest: Simplify runtime measurement support | Sebastian Huber | 1 | -47/+32 | |
Use the test case allocator functions T_zalloc() and T_malloc(). Restore the task affinity of the runner task. | |||||
2020-11-19 | libtest: Make test case allocator configurable | Sebastian Huber | 3 | -112/+90 | |
2020-09-24 | libtest: Remove superfluous assignment | Sebastian Huber | 1 | -1/+0 | |
Issue found by Coverity (CID 1437643). | |||||
2020-09-17 | libtest: Fix T_thread_switch_record() | Sebastian Huber | 1 | -0/+1 | |
If RTEMS_DEBUG is not defined, then we have to explicitly set the node off the chain. Update #3199. | |||||
2020-08-18 | libtest: Add T_push_plan() and T_pop_plan() | Sebastian Huber | 1 | -0/+15 | |
2020-08-18 | libtest: Use a destructor | Sebastian Huber | 1 | -10/+5 | |
Do not set up a new test steps environment. Update #3199. | |||||
2020-08-18 | libtest: Change T_step() and T_assert_step() | Sebastian Huber | 1 | -0/+11 | |
Normally, the expected test step must be a compile time constant. Allow variable expected test steps for the T_step() and T_assert_step(). This can be used for parameterized test loops with individual fixtures. Remove the ability to use custom failure messages due to some implementation constraints. Update #3199. | |||||
2020-08-18 | libtest: Add fixture steps | Sebastian Huber | 1 | -28/+55 | |
Support a new test plan for each nested fixture. Update #3199. | |||||
2020-08-18 | libtest: Add T_check_steps() | Sebastian Huber | 1 | -18/+13 | |
2020-08-18 | libtest: Use line buffer in T_check() | Sebastian Huber | 1 | -31/+86 | |
2020-08-18 | libtest: Add T_puts() | Sebastian Huber | 1 | -0/+24 | |
2020-08-18 | libtest: Add T_do_is_runner() | Sebastian Huber | 1 | -30/+34 | |
2020-08-18 | libtest: Add output buffer drain and fill | Sebastian Huber | 1 | -25/+35 | |
2020-08-18 | libtest: Change fixture scope method | Sebastian Huber | 1 | -61/+75 | |
Return the produced character count. There is no need for a NUL termination. Update #3199. | |||||
2020-08-11 | libtest: Add T_thread_switch_record() | Sebastian Huber | 1 | -0/+165 | |
Add support to record thread switch events. This can be used to check that a blocking operation results in the expected sequence of thread switches. Update #3199. | |||||
2020-08-10 | libtest: Constify | Sebastian Huber | 1 | -1/+1 | |
2020-08-07 | libtest: Improve T_check_task_context | Sebastian Huber | 1 | -0/+46 | |
2020-08-06 | libtest: Fix T_interrupt_test() in SMP configs | Sebastian Huber | 1 | -0/+45 | |
2020-07-23 | libtest: Add T_interrupt_test() | Sebastian Huber | 1 | -0/+441 | |
2020-07-23 | libtest: Add rtems_test_run() | Sebastian Huber | 1 | -0/+87 | |
2020-07-23 | libtest: Add T_CHECK_FMT | Sebastian Huber | 10 | -164/+171 | |
Rename internal function T_check_true() to T_check() and use the new flag T_CHECK_FMT to indicate if a format string is present. This is a preparation step to make the format string optional. Make the check context the first parameter. The API remains the same. Update #3199. | |||||
2020-07-23 | libtest: Add T_stop() | Sebastian Huber | 1 | -3/+9 | |
2020-07-23 | libtest: Split POSIX Keys support | Sebastian Huber | 3 | -80/+192 | |
2020-07-23 | libtest: Add T_get_scope() | Sebastian Huber | 1 | -0/+39 | |
2020-07-23 | libtest: Add push/pop fixture support | Sebastian Huber | 1 | -21/+89 | |
2020-07-23 | libtest: Support custom scope messages via fixture | Sebastian Huber | 1 | -8/+24 | |
2020-07-23 | libtest: Add T_make_runner() | Sebastian Huber | 1 | -2/+8 | |
2020-07-23 | libtest: Add T_get_one_clock_tick_busy() | Sebastian Huber | 2 | -73/+121 | |
2020-07-23 | libtest: Add T_busy() | Sebastian Huber | 2 | -17/+61 | |
2020-07-23 | libtest: Move <t.h> to <rtems/test.h> | Sebastian Huber | 13 | -13/+13 | |
2020-07-23 | libtest: <rtems/test.h> to <rtems/test-info.h> | Sebastian Huber | 5 | -5/+5 | |
Rename this header file to later move <t.h> to <rtems/test.h>. The main feature provided by <rtems/test-info.h> is the output of standard test information which is consumed by the RTEMS Tester. Update #3199. | |||||
2020-04-16 | Canonicalize config.h include | Sebastian Huber | 4 | -4/+4 | |
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif |
