* | rtems: Fix rate monotonic statistics | Sebastian Huber | 2021-10-25 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | The rate monotonic period statistics were affected by rtems_cpu_usage_reset(). The logic to detect and work around a CPU usage reset was broken. The Thread_Contol::cpu_time_used is changed to contain the processor time used throughout the entire lifetime of the thread. The new member Thread_Contol::cpu_time_used_at_last_reset is added to contain the processor time used at the time of the last reset through rtems_cpu_usage_reset(). This decouples the resets of the CPU usage and the rate monotonic period statistics. Update #4528. | ||||
* | libtest: Improve T_now_tick() | Sebastian Huber | 2021-09-21 | 1 | -0/+45 |
| | | | | | | | The T_now_tick() is a fall back time measurement using the CPU counter in case no Clock Driver is configured. Some CPU counter may overflow during the test execution. Accumulate the elapsed time to reduce the chance of CPU counter overflows. | ||||
* | libtest: Return fixture context in T_case_begin() | Sebastian Huber | 2021-09-02 | 1 | -1/+2 |
| | | | | This makes it similar to T_push_fixture(). | ||||
* | score: Add _Per_CPU_Submit_job() | Sebastian Huber | 2021-07-29 | 1 | -3/+1 |
* | libtest: Fix use of flexible array member | Sebastian Huber | 2021-05-03 | 1 | -12/+12 |
| | | | | Flexible array members must not appear in the middle of a structure. | ||||
* | libtest: Print SHA256 hash in base64url | Sebastian Huber | 2021-02-26 | 1 | -7/+6 |
* | libtest: Report target hash | Sebastian Huber | 2021-02-26 | 1 | -0/+2 |
| | | | | Update #4267. | ||||
* | libtest: Report build label | Sebastian Huber | 2021-02-25 | 1 | -0/+1 |
| | | | | Update #4269. | ||||
* | libtest: Add support to seize/surrender objects | Sebastian Huber | 2021-02-24 | 1 | -0/+54 |
* | libtest: Add T_get_thread_timer_state() | Sebastian Huber | 2021-02-08 | 1 | -0/+29 |
* | libtest: Remove double definition | Sebastian Huber | 2021-02-01 | 1 | -1/+0 |
* | libtest: Fix implicit type conversions | Sebastian Huber | 2021-02-01 | 2 | -6/+9 |
| | | | | This fix relates to a Coverity issue (PW.MIXED_ENUM_TYPE). | ||||
* | libtest: Check return values with RTEMS_DEBUG | Sebastian Huber | 2021-02-01 | 1 | -13/+47 |
| | | | | This fix relates to a Coverity issue (UNINIT). | ||||
* | libtest: Remove superfluous NULL pointer check | Sebastian Huber | 2021-01-27 | 1 | -1/+1 |
| | | | | This fix relates to CID 1468683 (REVERSE_INULL). | ||||
* | libtest: Use dependency injection | Sebastian Huber | 2021-01-27 | 1 | -5/+11 |
| | | | | This helps static analyzers. | ||||
* | libtest: Fix undefined setjmp() behaviour | Sebastian Huber | 2020-11-24 | 1 | -52/+58 |
| | | | | | | Bug was introduced by 78baeb757957fa0807c30e6c4d21ae99c9639e6a. Update #3199. | ||||
* | libtest: Simplify "Load" environment reporting | Sebastian Huber | 2020-11-19 | 1 | -2/+2 |
| | | | | | | | Report all runtime measurement environments with a name only and encode the worker count of the "Load" environment in the name. Update #3199. | ||||
* | libtest: Allow assert checks during test begin | Sebastian Huber | 2020-11-19 | 1 | -12/+17 |
| | | | | Allow assert checks in test begin actions and setup fixture methods. | ||||
* | libtest: Rename ValidCache in FullCache | Sebastian Huber | 2020-11-19 | 1 | -5/+5 |
| | | | | | This name better reflects the execution envirnoment in which the cache is fully loaded with valid data unrelated to the body request handler. | ||||
* | libtest: Add primitive test case memory allocator | Sebastian Huber | 2020-11-19 | 1 | -0/+86 |
| | | | | | | | This primitive test case memory allocator uses memory from the low-level memory information provided by the BSP. At the beginning of each test case, the memory available to the test case is reinitialized. This allows the use of a simple allocate only allocator. | ||||
* | libtest: Simplify runtime measurement support | Sebastian Huber | 2020-11-19 | 1 | -47/+32 |
| | | | | | Use the test case allocator functions T_zalloc() and T_malloc(). Restore the task affinity of the runner task. | ||||
* | libtest: Make test case allocator configurable | Sebastian Huber | 2020-11-19 | 3 | -112/+90 |
* | libtest: Remove superfluous assignment | Sebastian Huber | 2020-09-24 | 1 | -1/+0 |
| | | | | Issue found by Coverity (CID 1437643). | ||||
* | libtest: Fix T_thread_switch_record() | Sebastian Huber | 2020-09-17 | 1 | -0/+1 |
| | | | | | | | If RTEMS_DEBUG is not defined, then we have to explicitly set the node off the chain. Update #3199. | ||||
* | libtest: Add T_push_plan() and T_pop_plan() | Sebastian Huber | 2020-08-18 | 1 | -0/+15 |
* | libtest: Use a destructor | Sebastian Huber | 2020-08-18 | 1 | -10/+5 |
| | | | | | | Do not set up a new test steps environment. Update #3199. | ||||
* | libtest: Change T_step() and T_assert_step() | Sebastian Huber | 2020-08-18 | 1 | -0/+11 |
| | | | | | | | | | | | Normally, the expected test step must be a compile time constant. Allow variable expected test steps for the T_step() and T_assert_step(). This can be used for parameterized test loops with individual fixtures. Remove the ability to use custom failure messages due to some implementation constraints. Update #3199. | ||||
* | libtest: Add fixture steps | Sebastian Huber | 2020-08-18 | 1 | -28/+55 |
| | | | | | | Support a new test plan for each nested fixture. Update #3199. | ||||
* | libtest: Add T_check_steps() | Sebastian Huber | 2020-08-18 | 1 | -18/+13 |
* | libtest: Use line buffer in T_check() | Sebastian Huber | 2020-08-18 | 1 | -31/+86 |
* | libtest: Add T_puts() | Sebastian Huber | 2020-08-18 | 1 | -0/+24 |
* | libtest: Add T_do_is_runner() | Sebastian Huber | 2020-08-18 | 1 | -30/+34 |
* | libtest: Add output buffer drain and fill | Sebastian Huber | 2020-08-18 | 1 | -25/+35 |
* | libtest: Change fixture scope method | Sebastian Huber | 2020-08-18 | 1 | -61/+75 |
| | | | | | | | Return the produced character count. There is no need for a NUL termination. Update #3199. | ||||
* | libtest: Add T_thread_switch_record() | Sebastian Huber | 2020-08-11 | 1 | -0/+165 |
| | | | | | | | | Add support to record thread switch events. This can be used to check that a blocking operation results in the expected sequence of thread switches. Update #3199. | ||||
* | libtest: Constify | Sebastian Huber | 2020-08-10 | 1 | -1/+1 |
* | libtest: Improve T_check_task_context | Sebastian Huber | 2020-08-07 | 1 | -0/+46 |
* | libtest: Fix T_interrupt_test() in SMP configs | Sebastian Huber | 2020-08-06 | 1 | -0/+45 |
* | libtest: Add T_interrupt_test() | Sebastian Huber | 2020-07-23 | 1 | -0/+441 |
* | libtest: Add rtems_test_run() | Sebastian Huber | 2020-07-23 | 1 | -0/+87 |
* | libtest: Add T_CHECK_FMT | Sebastian Huber | 2020-07-23 | 10 | -164/+171 |
| | | | | | | | | | | | | Rename internal function T_check_true() to T_check() and use the new flag T_CHECK_FMT to indicate if a format string is present. This is a preparation step to make the format string optional. Make the check context the first parameter. The API remains the same. Update #3199. | ||||
* | libtest: Add T_stop() | Sebastian Huber | 2020-07-23 | 1 | -3/+9 |
* | libtest: Split POSIX Keys support | Sebastian Huber | 2020-07-23 | 3 | -80/+192 |
* | libtest: Add T_get_scope() | Sebastian Huber | 2020-07-23 | 1 | -0/+39 |
* | libtest: Add push/pop fixture support | Sebastian Huber | 2020-07-23 | 1 | -21/+89 |
* | libtest: Support custom scope messages via fixture | Sebastian Huber | 2020-07-23 | 1 | -8/+24 |
* | libtest: Add T_make_runner() | Sebastian Huber | 2020-07-23 | 1 | -2/+8 |
* | libtest: Add T_get_one_clock_tick_busy() | Sebastian Huber | 2020-07-23 | 2 | -73/+121 |
* | libtest: Add T_busy() | Sebastian Huber | 2020-07-23 | 2 | -17/+61 |
* | libtest: Move <t.h> to <rtems/test.h> | Sebastian Huber | 2020-07-23 | 13 | -13/+13 |
| | | | | Update #3199. |
