* | libtest: Add T_get_one_clock_tick_busy() | Sebastian Huber | 2020-07-23 | 1 | -73/+0 |
| | | | | Update #3199. | ||||
* | libtest: Add T_busy() | Sebastian Huber | 2020-07-23 | 1 | -17/+3 |
* | libtest: <rtems/test.h> to <rtems/test-info.h> | Sebastian Huber | 2020-07-23 | 1 | -1/+1 |
| | | | | | | | | Rename this header file to later move <t.h> to <rtems/test.h>. The main feature provided by <rtems/test-info.h> is the output of standard test information which is consumed by the RTEMS Tester. Update #3199. | ||||
* | build: Move test support to librtemstest.a | Sebastian Huber | 2019-03-26 | 1 | -0/+124 |
One reason to move the test support into a dedicated library are the standard output __wrap_*() functions. They may conflict with application level wrappers. Update #3199. |
