* | libtest: Add primitive test case memory allocator | Sebastian Huber | 2020-11-19 | 1 | -0/+86 |
This primitive test case memory allocator uses memory from the low-level memory information provided by the BSP. At the beginning of each test case, the memory available to the test case is reinitialized. This allows the use of a simple allocate only allocator. |
