path: root/cpukit/librpc (follow)
* 2010-05-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-291-2/+2
| | | | | * librpc/src/xdr/xdr_mem.c (xdr_memcreate): Cast addr to uintptr_t instead of size_t.
* 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-272-6/+6
| | | | | | * librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/clnt_udp.c: Revert to using u_long instead of rpcprog_t, rpcvers_t to stay bug-ward compatible to freebsd.
* 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-271-4/+4
| | | | * librpc/src/xdr/xdr_mem.c: Cosmetics from freebsd.
* 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-271-3/+7
| | | | * librpc/src/rpc/rtems_portmapper.c: Reflect changes to librpc.
* 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-279-72/+70
| | | | | | | | | * librpc/include/rpc/clnt.h, librpc/include/rpc/rpc_msg.h, librpc/src/rpc/clnt_generic.c, librpc/src/rpc/clnt_raw.c, librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/clnt_udp.c, librpc/src/rpc/pmap_clnt.c, librpc/src/rpc/pmap_getmaps.c librpc/src/rpc/pmap_getport.c: Partial merger from freebsd (portability fixes).
| | | | * librpc/include/rpc/xdr.h: Cosmetics from freebsd.
* 2010-05-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-261-22/+22
| | | | * librpc/src/rpc/clnt_udp.c: Cosmetics from freebsd.
* 2010-05-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-261-36/+54
| | | | | * librpc/src/rpc/clnt_tcp.c: Partial merger from freebsd (Fix strict-aliasing).
* 2010-05-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-261-10/+13
| | | | | * librpc/src/rpc/clnt_raw.c: Partial merger from freebsd (Improved 16 bit compatibility; Fix strict-aliasing).
* 2010-05-25 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-251-10/+21
| | | | | * librpc/src/rpc/rpc_prot.c: Partial merger from freebsd (Improved 64 bit compatibility; bug fix).
* 2010-04-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-04-292-5/+5
| | | | | * librpc/src/rpc/clnt_udp.c, librpc/src/xdr/xdr_mem.c: Use [u]intptr_t instead of [u_]long for better 16bit compliance.
* 2010-04-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-04-291-2/+2
| | | | | * librpc/src/rpc/pmap_rmt.c: Use uintptr_t for better 16bit compliance.
* Add HAVE_STRINGS_H for better POSIX compliance.Ralf Corsepius2010-03-281-0/+3
* Add HAVE_CONFIG_H support to let files receive configure defines.Ralf Corsepius2010-03-2845-0/+183
* 2009-05-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-05-201-1/+1
| | | | * librpc/src/xdr/xdr_float.c: Change detection logic for h8300.
* 2009-01-08 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-01-081-3/+1
| | | | | * librpc/src/xdr/xdr_float.c: M32C has no native float but GCC soft float should be IEEE format.
* Add missing initializers.Ralf Corsepius2008-12-231-0/+34
* #include <stdint.h> instead of <rtems/stdint.h>.Ralf Corsepius2008-12-111-1/+1
* #include <rpc/types.h>.Ralf Corsepius2008-12-081-0/+2
* #include <rtems/bsd/sys/cdefs.h>.Ralf Corsepius2008-12-081-0/+3
* 2008-12-04 Jukka Pietarinen <jukka.pietarinen@mrf.fi>Joel Sherrill2008-12-041-0/+1
| | | | | * configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: Add Lattice Mico32 support.
* 2008-11-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-11-051-1/+5
| | | | * librpc/src/xdr/xdr_float.c: Add M32C, M32R, and Blackfin.
* Stop using old-style function definitions.Ralf Corsepius2008-09-0119-195/+189
* Add missing prototypes.Ralf Corsepius2008-08-182-12/+16
* Cleanup.Ralf Corsepius2008-08-012-8/+8
* Misc. ansifications. Add prototypes.Ralf Corsepius2008-08-011-36/+36
* Misc. ansifications. Add prototypes.Ralf Corsepius2008-08-013-58/+59
* Misc. ansifications.Ralf Corsepius2008-08-011-3/+5
* Remove stray local decls. Misc. ansifications.Ralf Corsepius2008-08-011-7/+5
* Misc. ansifications.Ralf Corsepius2008-08-013-26/+26
* Remove stray clnt_perror().Ralf Corsepius2008-08-011-2/+0
* Add missing prototypes.Ralf Corsepius2008-08-011-7/+7
* Add missing prototypes.Ralf Corsepius2008-08-013-55/+52
* Add missing prototypes.Ralf Corsepius2008-08-012-22/+23
* Add missing prototypes.Ralf Corsepius2008-08-011-6/+6
* Add missing prototypes.Ralf Corsepius2008-08-011-3/+4
* Remove register vars.Ralf Corsepius2008-08-011-26/+26
* Misc. ansifications.Ralf Corsepius2008-08-011-36/+36
* Misc. ansifications.Ralf Corsepius2008-08-011-40/+40
* Cosmetics.Ralf Corsepius2008-08-011-1/+1
* Misc. ansifications.Ralf Corsepius2008-08-011-14/+14
* Cosmetics.Ralf Corsepius2008-08-011-4/+10
* Cosmetics.Ralf Corsepius2008-08-011-2/+2
* Cosmetics.Ralf Corsepius2008-08-011-1/+2
* Misc. ansifications.Ralf Corsepius2008-08-011-54/+55
* Add missing prototypes.Ralf Corsepius2008-08-013-6/+6
* Misc. ansifications.Ralf Corsepius2008-08-011-27/+27
* More ansifications.Ralf Corsepius2008-08-011-23/+26
* Misc. ansifications.Ralf Corsepius2008-08-012-10/+10
