* configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: New
port to Altera NIOS II.
PR 849/networking
* librpc/src/rpc/rtems_portmapper.c: Increased stack size
by ARGSIZE to prevent overrun.
* libnetworking/lib/ftpfs.c, librpc/include/rpc/svc.h,
librpc/src/rpc/get_myaddress.c, librpc/src/rpc/pmap_getmaps.c,
librpc/src/rpc/pmap_getport.c: Remove warnings.
* librpc/include/rpc/svc.h: Partial update from FreeBSD.
* librpc/include/rpc/clnt.h: Partial update from FreeBSD.
* librpc/include/rpc/clnt_soc.h, librpc/include/rpc/svc_soc.h:
New (Partial update from FreeBSD).
* librpc/Makefile.am: Reflect changes above.
* librpc/include/rpc/des.h: Remove (Unused, unsupported).
* librpc/src/rpc/auth_des.c,
librpc/src/rpc/auth_time.c,
librpc/src/rpc/authdes_prot.c,
librpc/src/rpc/clnt_unix.c,
librpc/src/rpc/crypt_client.c,
librpc/src/rpc/des_crypt.c,
librpc/src/rpc/des_soft.c,
librpc/src/rpc/getpublickey.c,
librpc/src/rpc/key_call.c,
librpc/src/rpc/key_prot_xdr.c,
librpc/src/rpc/svc_auth_des.c,
librpc/src/rpc/svc_unix.c: Remove (Unused, obsolete).
* librpc/src/rpc/PSD.doc/rpc.prog.ms,
librpc/src/rpc/PSD.doc/rpcgen.ms,
librpc/src/rpc/PSD.doc/nfs.rfc.ms,
librpc/src/rpc/PSD.doc/xdr.rfc.ms,
librpc/src/rpc/PSD.doc/rpc.rfc.ms,
librpc/src/rpc/PSD.doc/xdr.nts.ms:
* libfs/src/dosfs/msdos_format.c, librpc/src/xdr/xdr.c: Added
initialization to remove warnings.
* librpc/Makefile.am: Split preinstallation rules in to separate
preinstall.am-files.
* librpc/preinstall.am: New (Generated from corresponding Makefile.am).
* librpc/include/rpc/clnt_stat.h, librpc/include/rpc/rpcent.h:
New (From FreeBSD).
* librpc/include/rpc/rpc.h: Partial update from FreeBSD.
* librpc/include/rpc/types.h: Partial update from FreeBSD.
Use stdint.h types instead of sys/types.h.
* librpc/src/rpc/bindresvport.c: Partial update from FreeBSD.
* librpc/include/rpc/clnt.h, librpc/src/rpc/authunix_prot.c,
librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/pmap_prot2.c,
librpc/src/rpc/pmap_rmt.c, librpc/src/rpc/rtems_portmapper.c,
librpc/src/rpc/svc_simple.c: Fix warnings.
* librpc/include/rpc/auth_des.h, librpc/include/rpc/xdr.h,
librpc/src/rpc/auth_des.c, librpc/src/rpc/auth_unix.c,
librpc/src/rpc/rpc_prot.c, librpc/src/xdr/xdr.c:
Misc. ansi-fications, misc. updates from FreeBSD.
* librpc/include/rpc/xdr.h: Remove questionable comments.
* librpc/include/rpc/auth.h: Remove __P, ansi-fy.
* librpc/src/rpc/auth_none.c: Reflect changes above.
* librpc/include/rpc/svc.h, librpc/include/rpc/xdr.h:
Remove __P(xx).
* httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am,
libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am,
libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
* automake/compile.am, httpd/Makefile.am, itron/Makefile.am,
libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am,
libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am,
posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am,
score/Makefile.am, wrapup/Makefile.am:
Remove build-variant support.
* librpc/include/rpc/types.h: Include <rtems/stdint.h>.
* librpc/src/rpc/clnt_raw.c, librpc/src/rpc/rpcdname.c,
librpc/src/rpc/rtems_portmapper.c, librpc/src/rpc/svc.c,
librpc/src/rpc/svc_simple.c: Misc. cast-related fixes.
Convert to ANSI.
* librpc/include/rpc/rpc.h (struct _rtems_rpc_task_variables):
Use pointers to types instead of void* to avoid casts.
* librpc/src/rpc/clnt_perror.c, librpc/src/rpc/clnt_raw.c,
librpc/src/rpc/clnt_simple.c, librpc/src/rpc/rpcdname.c,
librpc/src/rpc/svc.c, librpc/src/rpc/svc_auth.c,
Eliminate lvalue casts gcc-3.4 warns about.
* score/src/coremsg.c: Eliminate unsigned32.
* score/include/rtems/system.h: Set __RTEMS_REVISION__ to 99.
* librpc/include/rpc/xdr.h: Use elipsis in xdrproc_t prototype.
* configure.ac, libmisc/cpuuse/README, libmisc/stackchk/README,
librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am,
score/include/rtems/score/mppkt.h: i960 obsoleted and all references
removed.
