* | v850 port: Initial addition with BSP for simulator in GDB | Joel Sherrill | 2012-06-11 | 1 | -1/+2 |
| | | | | | | | | | | | | | | | | | | Port + v850 does not have appear to have any optimized bit scan instructions + v850 does have single instructions for wap u16 and u32 + Code path optimization preferences set + Add BSP variants for each GCC CPU model flag and a README - v850e1 variant does not work (fails during BSP initialization) BSP for GDB v850 Simulator + linkcmds matches defaults in GDB simulator with RTEMS mods + crt1.c added from v850 newlib port for __main() + BSP exits cleanly + printk and console I/O work + uses clock tick from IDLE task + Tests not requiring real clock ISR work Documentation + CPU Supplment chapter for v850 added | ||||
* | librpc: PR2066: Fix for short enums | Sebastian Huber | 2012-06-06 | 7 | -15/+23 |
| | | | | | | | | | | The XDR library has a problem on architectures with short enums like the default ARM EABI. Short enums means that the size of the enum type is variable and the smallest integer type to hold all enum values will be selected. For many enums this is char. The XDR library uses int32_t for enum_t. There are several evil casts from an enum type to enum_t which leads to invalid memory accesses on short enum architectures. A workaround is to add appropriate dummy enum values. | ||||
* | Remove CVS Id Strings (manual edits after script) | Joel Sherrill | 2012-05-11 | 2 | -2/+1 |
| | | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 5 | -15/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+4 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -4/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-11-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-11-30 | 1 | -3/+11 |
| | | | | | * librpc/src/rpc/clnt_udp.c (struct cu_data): Introduce unions _cu_inbuf, _cu_outbuf to avoid aliasing. | ||||
* | 2011-05-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-05-17 | 1 | -10/+17 |
| | | | | | * libnetworking/Makefile.am: Reformat. * librpc/Makefile.am: Reformat. | ||||
* | Make self-contained. | Ralf Corsepius | 2011-05-05 | 11 | -0/+28 |
* | Include <sys/cdefs.h> (Eliminate rtems/bsd/sys/cdefs.h). | Ralf Corsepius | 2011-03-24 | 13 | -13/+13 |
* | 2010-05-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-29 | 1 | -2/+2 |
| | | | | | * librpc/src/xdr/xdr_mem.c (xdr_memcreate): Cast addr to uintptr_t instead of size_t. | ||||
* | 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-27 | 2 | -6/+6 |
| | | | | | | * librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/clnt_udp.c: Revert to using u_long instead of rpcprog_t, rpcvers_t to stay bug-ward compatible to freebsd. | ||||
* | 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-27 | 1 | -4/+4 |
| | | | | * librpc/src/xdr/xdr_mem.c: Cosmetics from freebsd. | ||||
* | 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-27 | 1 | -3/+7 |
| | | | | * librpc/src/rpc/rtems_portmapper.c: Reflect changes to librpc. | ||||
* | 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-27 | 9 | -72/+70 |
| | | | | | | | | | * librpc/include/rpc/clnt.h, librpc/include/rpc/rpc_msg.h, librpc/src/rpc/clnt_generic.c, librpc/src/rpc/clnt_raw.c, librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/clnt_udp.c, librpc/src/rpc/pmap_clnt.c, librpc/src/rpc/pmap_getmaps.c librpc/src/rpc/pmap_getport.c: Partial merger from freebsd (portability fixes). | ||||
| | | | | * librpc/include/rpc/xdr.h: Cosmetics from freebsd. | ||||
* | 2010-05-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-26 | 1 | -22/+22 |
| | | | | * librpc/src/rpc/clnt_udp.c: Cosmetics from freebsd. | ||||
* | 2010-05-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-26 | 1 | -36/+54 |
| | | | | | * librpc/src/rpc/clnt_tcp.c: Partial merger from freebsd (Fix strict-aliasing). | ||||
* | 2010-05-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-26 | 1 | -10/+13 |
| | | | | | * librpc/src/rpc/clnt_raw.c: Partial merger from freebsd (Improved 16 bit compatibility; Fix strict-aliasing). | ||||
* | 2010-05-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-25 | 1 | -10/+21 |
| | | | | | * librpc/src/rpc/rpc_prot.c: Partial merger from freebsd (Improved 64 bit compatibility; bug fix). | ||||
* | 2010-04-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-29 | 2 | -5/+5 |
| | | | | | * librpc/src/rpc/clnt_udp.c, librpc/src/xdr/xdr_mem.c: Use [u]intptr_t instead of [u_]long for better 16bit compliance. | ||||
* | 2010-04-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-29 | 1 | -2/+2 |
| | | | | | * librpc/src/rpc/pmap_rmt.c: Use uintptr_t for better 16bit compliance. | ||||
* | Add HAVE_STRINGS_H for better POSIX compliance. | Ralf Corsepius | 2010-03-28 | 1 | -0/+3 |
* | Add HAVE_CONFIG_H support to let files receive configure defines. | Ralf Corsepius | 2010-03-28 | 45 | -0/+183 |
* | 2009-05-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-05-20 | 1 | -1/+1 |
| | | | | * librpc/src/xdr/xdr_float.c: Change detection logic for h8300. | ||||
* | 2009-01-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-01-08 | 1 | -3/+1 |
| | | | | | * librpc/src/xdr/xdr_float.c: M32C has no native float but GCC soft float should be IEEE format. | ||||
* | Add missing initializers. | Ralf Corsepius | 2008-12-23 | 1 | -0/+34 |
* | #include <stdint.h> instead of <rtems/stdint.h>. | Ralf Corsepius | 2008-12-11 | 1 | -1/+1 |
* | #include <rpc/types.h>. | Ralf Corsepius | 2008-12-08 | 1 | -0/+2 |
* | #include <rtems/bsd/sys/cdefs.h>. | Ralf Corsepius | 2008-12-08 | 1 | -0/+3 |
* | 2008-12-04 Jukka Pietarinen <jukka.pietarinen@mrf.fi> | Joel Sherrill | 2008-12-04 | 1 | -0/+1 |
| | | | | | * configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: Add Lattice Mico32 support. | ||||
* | 2008-11-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-11-05 | 1 | -1/+5 |
| | | | | * librpc/src/xdr/xdr_float.c: Add M32C, M32R, and Blackfin. | ||||
* | Stop using old-style function definitions. | Ralf Corsepius | 2008-09-01 | 19 | -195/+189 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-18 | 2 | -12/+16 |
* | Cleanup. | Ralf Corsepius | 2008-08-01 | 2 | -8/+8 |
* | Misc. ansifications. Add prototypes. | Ralf Corsepius | 2008-08-01 | 1 | -36/+36 |
* | Misc. ansifications. Add prototypes. | Ralf Corsepius | 2008-08-01 | 3 | -58/+59 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -3/+5 |
* | Remove stray local decls. Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -7/+5 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 3 | -26/+26 |
* | Remove stray clnt_perror(). | Ralf Corsepius | 2008-08-01 | 1 | -2/+0 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-01 | 1 | -7/+7 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-01 | 3 | -55/+52 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-01 | 2 | -22/+23 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-01 | 1 | -6/+6 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-01 | 1 | -3/+4 |
* | Remove register vars. | Ralf Corsepius | 2008-08-01 | 1 | -26/+26 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -36/+36 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -40/+40 |
