* libblock/src/bdbuf.c, libblock/src/ramdisk.c,
libcsupport/src/newlibc.c, libcsupport/src/sync.c,
libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c,
libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c,
libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c,
libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c,
libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c,
libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c,
libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c,
libnetworking/libc/res_send.c, libnetworking/libc/res_update.c,
libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c,
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/svc.c,
score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Too
much was accidentally committed -- revert.
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c,
librpc/src/rpc/svc.c, sapi/include/confdefs.h,
* ChangeLog: Merge-in libmisc/ChangeLog, librpc/ChangeLog.
* libmisc/ChangeLog, librpc/ChangeLog: Remove.
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
* Makefile.am: Include compile.am, again.
Put man-pages into EXTRA_DIST to work around automake not
distributing conditionally installed *_MANS.
Distribute include/rpcsvc.
* Makefile.am: Add libs to CLEANFILES
Set lib*_g_a_SOURCES = lib*_a_SOURCES.
* Makefile.am: Build lib*$(LIB_VARIANT).a instead of
$(ARCH)/lib*.a.
* Makefile.am: Build library using EXTRA_LIBRARIES and automake rules.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Add $(dirstamp) to compilation rules.
* Makefile.am: Add $(dirstamp) to preinstallation rules.
* src/rpc/Makefile.am, src/xdr/Makefile.am, src/Makefile.am:
Removed.
* Makefile.am: Merge-in src/rpc/Makefile.am, src/xdr/Makefile.am,
src/Makefile.am.
Various fixes. Reformat.
* include/rpc/rpc.hinclude/rpc/rpc.h: Rename struct
rtems_rpc_task_variables into struct _rtems_rpc_task_variables
(Avoid symbol conflict between struct and variable).
struct _rtems_rpc_task_variables *rtems_rpc_task_variables;
Reflect changes above.
* src/rpc/clnt_perror.c, src/rpc/clnt_raw.c, src/rpc/clnt_simple.c,
src/rpc/rpcdname.c, src/rpc/rtems_rpc.c, src/rpc/svc.c,
src/rpc/svc_auth.c, src/rpc/svc_raw.c, src/rpc/svc_simple.c:
* src/rpc/Makefile.am: Remove __P from AM_CPPFLAGS.
Rely on sys/cdefs.h providing it.
* src/xdr/Makefile.am: Remove __P from AM_CPPFLAGS.
* configure.ac: Remove (Merged-in into ../configure.ac)
* Makefile.am, include/Makefile.am, src/Makefile.am,
src/rpc/Makefile.am, src/xdr/Makefile.am:
* configure.ac: Fix package name.
* src/rpc/pmap_rmt.c: Removed warnings.
* src/rpc/svc_run.c: Remove warning.
* src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/pmap_rmt.c,
src/rpc/rtime.c, src/rpc/svc_tcp.c: Add include of <sys/select.h>
to eliminate warning.
* src/rpc/rpcdname.c: Add prototype of getdomainname() to eliminate
warning.
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* src/xdr/xdr_stdio.c: Per PR268, add include of <netinet/in.h>
to avoid warning on ntohl().
* src/rpc/rtems_portmapper.c: include <stdlib.h> (Get rid of gcc31
warnings about abort/exit).
* configure.ac: or32 does not currently support librpc.
* src/rpc/Makefile.am: Merge src/rpc/PSD.doc/Makefile.am.
* include/Makefile.am: Merge include/rpc/Makefile.am.
Merge include/rpcsvc/Makefile.am.
* include/rpc/Makefile.am: Remove.
* include/rpcsvc/Makefile.am: Remove.
* src/rpc/PSD.doc/Makefile.am: Remove.
* configure.ac: Remove duplicate AC_PROG_RANLIB.
Remove include/rpc/Makefile.
Remove include/rpcsvc/Makefile.
Remove src/rpc/PSD.doc/Makefile.
2002-07-23 Joel Sherrill <joel@OARcorp.com>
* src/rpc/pmap_clnt.c (pmap_set): Changed prototype to match .h.
2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* src/xdr/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/rpc/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/xdr/Makefile.am: Eliminate LIBNAME.
* src/rpc/Makefile.am: Eliminate LIBNAME.
2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.ac: RTEMS_TOP(../..).
2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.ac: Use AC_CONFIG_AUX_DIR(../..).
Add AC_PROG_RANLIB.
2002-06-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
AC_CONFIG_AUX_DIR(../../../..).
Remove RTEMS_CANONICAL_HOST.
Use RTEMS_ENV_RTEMSCPU.
Add AC_PROG_RANLIB.
* include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
ACLOCAL_AMFLAGS = -I ../aclocal.
* src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am.
2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS.
2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.in: Remove.
2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rpc/Makefile.am: Use 'PREINSTALL_FILES ='.
2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rpc/Makefile.am: Apply include_*HEADERS instead of
H_FILES.
2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-10-30 Joel Sherrill <joel@OARcorp.com>
effects in RTEMS source code.
* src/rpc/Makefile.am, src/rpc/auth_time.c, src/rpc/clnt_simple.c,
src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/clnt_unix.c,
src/rpc/get_myaddress.c, src/rpc/pmap_clnt.c, src/rpc/pmap_getmaps.c,
src/rpc/pmap_getport.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c,
src/rpc/svc_tcp.c, src/rpc/svc_udp.c, src/rpc/svc_unix.c:
Use of _read, _write, and _close as macros conflicted with
newlib's use of these as routine names. They were renamed to
include "_RPC_" prefix.
2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-09-22 Joel Sherrill <joel@OARcorp.com>
* src/xdr/xdr_float.c: Added A29K support.
2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* src/rpc/Makefile.am, src/xdr/Makefile.am: Include compile.am
2000-08-10 Joel Sherrill <joel@OARcorp.com>
* ChangeLog: New file.
Add AC_PROG_RANLIB.
Add AC_PROG_RANLIB.
H_FILES.
