path: root/cpukit/librpc (follow)
* cpukit: Add Epiphany architecture port v4Hesham ALMatary2015-05-211-0/+1
* xdr_float.c: Fix typoJoel Sherrill2015-03-031-1/+1
* librpc: Include or1knd part of the recongnized CPUs at xdr_float.cHesham ALMatary2015-03-031-1/+1
| | | | Close #2256
* rpc: misaligned pointer dereference in clnt_udp.c line 363Jeffrey Hill2015-02-231-3/+3
| | | | closes #2248
* rpc: misaligned address exception in get_myaddress.cJeffrey Hill2015-02-231-15/+38
| | | | closes #2249 see #1401
* Delete or rename MIN/MAX macros and definesSebastian Huber2014-11-211-1/+1
| | | | Include <sys/param.h> if necessary to get the MIN()/MAX() macros.
* Add or1k to the list of targets that use IEEE 754 in xdr_float.cHesham ALMatary2014-08-251-0/+1
* librpc: Use POSIX key instead of task variablesChristian Mauderer2014-03-242-16/+48
* Common file changes in support of Moxie portAnthony Green2013-02-281-1/+1
| | | | Signed-off-by: Anthony Green <green@moxielogic.com>
* v850 port: Initial addition with BSP for simulator in GDBJoel Sherrill2012-06-111-1/+2
| | | | | | | | | | | | | | | | | | Port + v850 does not have appear to have any optimized bit scan instructions + v850 does have single instructions for wap u16 and u32 + Code path optimization preferences set + Add BSP variants for each GCC CPU model flag and a README - v850e1 variant does not work (fails during BSP initialization) BSP for GDB v850 Simulator + linkcmds matches defaults in GDB simulator with RTEMS mods + crt1.c added from v850 newlib port for __main() + BSP exits cleanly + printk and console I/O work + uses clock tick from IDLE task + Tests not requiring real clock ISR work Documentation + CPU Supplment chapter for v850 added
* librpc: PR2066: Fix for short enumsSebastian Huber2012-06-067-15/+23
| | | | | | | | | | The XDR library has a problem on architectures with short enums like the default ARM EABI. Short enums means that the size of the enum type is variable and the smallest integer type to hold all enum values will be selected. For many enums this is char. The XDR library uses int32_t for enum_t. There are several evil casts from an enum type to enum_t which leads to invalid memory accesses on short enum architectures. A workaround is to add appropriate dummy enum values.
* Remove CVS Id Strings (manual edits after script)Joel Sherrill2012-05-112-2/+1
| | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns.
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-115-15/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+4
* Remove CVS-Ids.Ralf Corsépius2012-05-041-4/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-11-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-11-301-3/+11
| | | | | * librpc/src/rpc/clnt_udp.c (struct cu_data): Introduce unions _cu_inbuf, _cu_outbuf to avoid aliasing.
* 2011-05-16 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-05-171-10/+17
| | | | | * libnetworking/Makefile.am: Reformat. * librpc/Makefile.am: Reformat.
* Make self-contained.Ralf Corsepius2011-05-0511-0/+28
* Include <sys/cdefs.h> (Eliminate rtems/bsd/sys/cdefs.h).Ralf Corsepius2011-03-2413-13/+13
* 2010-05-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-291-2/+2
| | | | | * librpc/src/xdr/xdr_mem.c (xdr_memcreate): Cast addr to uintptr_t instead of size_t.
* 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-272-6/+6
| | | | | | * librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/clnt_udp.c: Revert to using u_long instead of rpcprog_t, rpcvers_t to stay bug-ward compatible to freebsd.
* 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-271-4/+4
| | | | * librpc/src/xdr/xdr_mem.c: Cosmetics from freebsd.
* 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-271-3/+7
| | | | * librpc/src/rpc/rtems_portmapper.c: Reflect changes to librpc.
* 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-279-72/+70
| | | | | | | | | * librpc/include/rpc/clnt.h, librpc/include/rpc/rpc_msg.h, librpc/src/rpc/clnt_generic.c, librpc/src/rpc/clnt_raw.c, librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/clnt_udp.c, librpc/src/rpc/pmap_clnt.c, librpc/src/rpc/pmap_getmaps.c librpc/src/rpc/pmap_getport.c: Partial merger from freebsd (portability fixes).
| | | | * librpc/include/rpc/xdr.h: Cosmetics from freebsd.
* 2010-05-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-261-22/+22
| | | | * librpc/src/rpc/clnt_udp.c: Cosmetics from freebsd.
* 2010-05-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-261-36/+54
| | | | | * librpc/src/rpc/clnt_tcp.c: Partial merger from freebsd (Fix strict-aliasing).
* 2010-05-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-261-10/+13
| | | | | * librpc/src/rpc/clnt_raw.c: Partial merger from freebsd (Improved 16 bit compatibility; Fix strict-aliasing).
* 2010-05-25 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-251-10/+21
| | | | | * librpc/src/rpc/rpc_prot.c: Partial merger from freebsd (Improved 64 bit compatibility; bug fix).
* 2010-04-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-04-292-5/+5
| | | | | * librpc/src/rpc/clnt_udp.c, librpc/src/xdr/xdr_mem.c: Use [u]intptr_t instead of [u_]long for better 16bit compliance.
* 2010-04-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-04-291-2/+2
| | | | | * librpc/src/rpc/pmap_rmt.c: Use uintptr_t for better 16bit compliance.
* Add HAVE_STRINGS_H for better POSIX compliance.Ralf Corsepius2010-03-281-0/+3
* Add HAVE_CONFIG_H support to let files receive configure defines.Ralf Corsepius2010-03-2845-0/+183
* 2009-05-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-05-201-1/+1
| | | | * librpc/src/xdr/xdr_float.c: Change detection logic for h8300.
* 2009-01-08 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-01-081-3/+1
| | | | | * librpc/src/xdr/xdr_float.c: M32C has no native float but GCC soft float should be IEEE format.
* Add missing initializers.Ralf Corsepius2008-12-231-0/+34
* #include <stdint.h> instead of <rtems/stdint.h>.Ralf Corsepius2008-12-111-1/+1
* #include <rpc/types.h>.Ralf Corsepius2008-12-081-0/+2
* #include <rtems/bsd/sys/cdefs.h>.Ralf Corsepius2008-12-081-0/+3
* 2008-12-04 Jukka Pietarinen <jukka.pietarinen@mrf.fi>Joel Sherrill2008-12-041-0/+1
| | | | | * configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: Add Lattice Mico32 support.
* 2008-11-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-11-051-1/+5
| | | | * librpc/src/xdr/xdr_float.c: Add M32C, M32R, and Blackfin.
* Stop using old-style function definitions.Ralf Corsepius2008-09-0119-195/+189
* Add missing prototypes.Ralf Corsepius2008-08-182-12/+16
* Cleanup.Ralf Corsepius2008-08-012-8/+8
* Misc. ansifications. Add prototypes.Ralf Corsepius2008-08-011-36/+36
* Misc. ansifications. Add prototypes.Ralf Corsepius2008-08-013-58/+59
* Misc. ansifications.Ralf Corsepius2008-08-011-3/+5
* Remove stray local decls. Misc. ansifications.Ralf Corsepius2008-08-011-7/+5
* Misc. ansifications.Ralf Corsepius2008-08-013-26/+26
