path: root/cpukit/librpc (follow)
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-112-1/+5
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-192-1/+5
| | | | * configure.ac: Fix package name.
* 2002-11-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-042-1/+5
| | | | * src/rpc/pmap_rmt.c: Removed warnings.
* 2002-10-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-312-0/+5
| | | | * src/rpc/svc_run.c: Remove warning.
* 2002-10-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-287-0/+15
| | | | | | | | * src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c, src/rpc/svc_tcp.c: Add include of <sys/select.h> to eliminate warning. * src/rpc/rpcdname.c: Add prototype of getdomainname() to eliminate warning.
* 2002-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-252-1/+5
| | | | * configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-212-3/+9
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-08-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-202-0/+6
| | | | | * src/xdr/xdr_stdio.c: Per PR268, add include of <netinet/in.h> to avoid warning on ntohl().
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-112-0/+6
| | | | | * src/rpc/rtems_portmapper.c: include <stdlib.h> (Get rid of gcc31 warnings about abort/exit).
* 2002-08-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-062-1/+7
| | | | * configure.ac: or32 does not currently support librpc.
* 2002-07-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-301-0/+13
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * src/rpc/Makefile.am: Merge src/rpc/PSD.doc/Makefile.am. * include/Makefile.am: Merge include/rpc/Makefile.am. Merge include/rpcsvc/Makefile.am. * include/rpc/Makefile.am: Remove. * include/rpcsvc/Makefile.am: Remove. * src/rpc/PSD.doc/Makefile.am: Remove. * configure.ac: Remove duplicate AC_PROG_RANLIB. Remove include/rpc/Makefile. Remove include/rpcsvc/Makefile. Remove src/rpc/PSD.doc/Makefile. 2002-07-23 Joel Sherrill <joel@OARcorp.com> * src/rpc/pmap_clnt.c (pmap_set): Changed prototype to match .h. 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * src/xdr/Makefile.am: Use .$(OBJEXT) instead of .o. * src/rpc/Makefile.am: Use .$(OBJEXT) instead of .o. 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * src/xdr/Makefile.am: Eliminate LIBNAME. * src/rpc/Makefile.am: Eliminate LIBNAME. 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: RTEMS_TOP(../..). 2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove RTEMS_PROJECT_ROOT. 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Use AC_CONFIG_AUX_DIR(../..). Add AC_PROG_RANLIB. 2002-06-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: RTEMS_TOP(../../../..). AC_CONFIG_AUX_DIR(../../../..). Remove RTEMS_CANONICAL_HOST. Use RTEMS_ENV_RTEMSCPU. Add AC_PROG_RANLIB. * include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * include/Makefile.am: Include $(top_srcdir)/../automake/*.am. * include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * Makefile.am: Include $(top_srcdir)/../automake/*.am. ACLOCAL_AMFLAGS = -I ../aclocal. * src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/Makefile.am: Include $(top_srcdir)/../automake/*.am. 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS. 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * include/rpc/Makefile.am: Use 'PREINSTALL_FILES ='. 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * include/rpc/Makefile.am: Apply include_*HEADERS instead of H_FILES. 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. 2000-10-30 Joel Sherrill <joel@OARcorp.com> * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * src/rpc/Makefile.am, src/rpc/auth_time.c, src/rpc/clnt_simple.c, src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/clnt_unix.c, src/rpc/get_myaddress.c, src/rpc/pmap_clnt.c, src/rpc/pmap_getmaps.c, src/rpc/pmap_getport.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c, src/rpc/svc_tcp.c, src/rpc/svc_udp.c, src/rpc/svc_unix.c: Use of _read, _write, and _close as macros conflicted with newlib's use of these as routine names. They were renamed to include "_RPC_" prefix. 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. 2000-09-22 Joel Sherrill <joel@OARcorp.com> * src/xdr/xdr_float.c: Added A29K support. 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * src/rpc/Makefile.am, src/xdr/Makefile.am: Include compile.am 2000-08-10 Joel Sherrill <joel@OARcorp.com> * ChangeLog: New file.
* 2002-07-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-306-55/+26
* 2002-07-23 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-232-1/+5
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-223-2/+7
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-221-3/+1
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-222-2/+6
* 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-052-1/+5
* 2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-012-2/+4
* 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-272-1/+7
* 2002-06-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-2510-44/+44
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2810-10/+16
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-0/+44
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-112-0/+7
* 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-282-1/+5
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-052-2/+10
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-092-1/+5
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-022-1/+5
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-3116-36/+50
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-252-1/+6
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-222-0/+5
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-054-1/+7
* Minor problems addressed with the merger and with the arm_bare_bsp.Joel Sherrill2000-07-271-1/+1
| | | | | | That BSP now has a stub clock driver so the tests can link even if they won't execute. A handful of Makefiles had to be updated and we had to account for printk.c being a shared file now.
* Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill2000-07-261-0/+4
| | | | | | | | | | | a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
* Added H8 as IEEE whether this is true or not.Joel Sherrill2000-06-291-0/+1
* Disabled #ident since the h8300-rtems binutils do not like theJoel Sherrill2000-06-291-1/+1
| | | | generated assembly from it.
* Corrected prototype for xdrrec_endofrecord to match C body.Joel Sherrill2000-06-291-1/+1
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-12133-338/+35655
* Added on 4.5 branch.Joel Sherrill2000-05-032-0/+0
* Added on 4.5-branchJoel Sherrill2000-05-014-0/+0
* New files.Joel Sherrill2000-04-292-0/+4
* New files added as part of librpc upgrade.Joel Sherrill2000-04-2914-0/+0
* New files added as part of librpc upgrade.Joel Sherrill2000-04-2978-0/+0
* New directory added as part of librpc upgrade.Joel Sherrill2000-04-2923-0/+0
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-134-0/+19
| | | | adds .cvsignore.
* Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill2000-01-311-1/+0
| | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
* Missed in previous automake conversion patches from Ralf CorsepiusJoel Sherrill1999-11-231-0/+36
* Miscellaneous patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-231-2/+2
| | | | | that are part of the Makefile.am conversion effort but were missed in the previous commits.
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-6/+6
