path: root/cpukit/librpc (follow)
* 2004-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-231-229/+0
| | | | | * ChangeLog: Merge-in libmisc/ChangeLog, librpc/ChangeLog. * libmisc/ChangeLog, librpc/ChangeLog: Remove.
* Cleanup ChangeLog.Ralf Corsepius2004-01-231-81/+53
* 2004-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-192-1/+7
| | | | * Makefile.am: Add PREINSTALL_DIRS.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-142-1/+10
| | | | | * Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES.
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-112-32/+60
| | | | | | | * Makefile.am: Include compile.am, again. Put man-pages into EXTRA_DIST to work around automake not distributing conditionally installed *_MANS. Distribute include/rpcsvc.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-092-2/+11
| | | | | * Makefile.am: Add libs to CLEANFILES Set lib*_g_a_SOURCES = lib*_a_SOURCES.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-092-17/+20
| | | | | * Makefile.am: Build lib*$(LIB_VARIANT).a instead of $(ARCH)/lib*.a.
* 2004-01-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-072-34/+23
| | | | * Makefile.am: Build library using EXTRA_LIBRARIES and automake rules.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-4/+7
| | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-302-8/+14
| | | | * Makefile.am: Add $(dirstamp) to compilation rules.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-302-35/+39
| | | | * Makefile.am: Add $(dirstamp) to preinstallation rules.
* 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-275-117/+164
| | | | | | | | * src/rpc/Makefile.am, src/xdr/Makefile.am, src/Makefile.am: Removed. * Makefile.am: Merge-in src/rpc/Makefile.am, src/xdr/Makefile.am, src/Makefile.am. Various fixes. Reformat.
* 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-2711-22/+34
| | | | | | | | | | | | * include/rpc/rpc.hinclude/rpc/rpc.h: Rename struct rtems_rpc_task_variables into struct _rtems_rpc_task_variables (Avoid symbol conflict between struct and variable). struct _rtems_rpc_task_variables *rtems_rpc_task_variables; Reflect changes above. * src/rpc/clnt_perror.c, src/rpc/clnt_raw.c, src/rpc/clnt_simple.c, src/rpc/rpcdname.c, src/rpc/rtems_rpc.c, src/rpc/svc.c, src/rpc/svc_auth.c, src/rpc/svc_raw.c, src/rpc/svc_simple.c: Reflect changes above.
* 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-213-3/+8
| | | | | | | * src/rpc/Makefile.am: Remove __P from AM_CPPFLAGS. Rely on sys/cdefs.h providing it. * src/xdr/Makefile.am: Remove __P from AM_CPPFLAGS. Rely on sys/cdefs.h providing it.
* 2003-09-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-243-32/+41
| | | | | * Makefile.am: Merge-in include/Makefile.am. * include/Makefile.am: Remove.
* CleanupRalf Corsepius2003-07-081-12/+0
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-081-1/+1
| | | | | | | * configure.ac: Remove (Merged-in into ../configure.ac) * Makefile.am, include/Makefile.am, src/Makefile.am, src/rpc/Makefile.am, src/xdr/Makefile.am: Reflect having merged configure.ac into ../configure.ac.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-086-60/+21
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-112-1/+5
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-192-1/+5
| | | | * configure.ac: Fix package name.
* 2002-11-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-042-1/+5
| | | | * src/rpc/pmap_rmt.c: Removed warnings.
* 2002-10-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-312-0/+5
| | | | * src/rpc/svc_run.c: Remove warning.
* 2002-10-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-287-0/+15
| | | | | | | | * src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c, src/rpc/svc_tcp.c: Add include of <sys/select.h> to eliminate warning. * src/rpc/rpcdname.c: Add prototype of getdomainname() to eliminate warning.
* 2002-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-252-1/+5
| | | | * configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-212-3/+9
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-08-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-202-0/+6
| | | | | * src/xdr/xdr_stdio.c: Per PR268, add include of <netinet/in.h> to avoid warning on ntohl().
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-112-0/+6
| | | | | * src/rpc/rtems_portmapper.c: include <stdlib.h> (Get rid of gcc31 warnings about abort/exit).
* 2002-08-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-062-1/+7
| | | | * configure.ac: or32 does not currently support librpc.
* 2002-07-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-301-0/+13
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * src/rpc/Makefile.am: Merge src/rpc/PSD.doc/Makefile.am. * include/Makefile.am: Merge include/rpc/Makefile.am. Merge include/rpcsvc/Makefile.am. * include/rpc/Makefile.am: Remove. * include/rpcsvc/Makefile.am: Remove. * src/rpc/PSD.doc/Makefile.am: Remove. * configure.ac: Remove duplicate AC_PROG_RANLIB. Remove include/rpc/Makefile. Remove include/rpcsvc/Makefile. Remove src/rpc/PSD.doc/Makefile. 2002-07-23 Joel Sherrill <joel@OARcorp.com> * src/rpc/pmap_clnt.c (pmap_set): Changed prototype to match .h. 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * src/xdr/Makefile.am: Use .$(OBJEXT) instead of .o. * src/rpc/Makefile.am: Use .$(OBJEXT) instead of .o. 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * src/xdr/Makefile.am: Eliminate LIBNAME. * src/rpc/Makefile.am: Eliminate LIBNAME. 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: RTEMS_TOP(../..). 2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove RTEMS_PROJECT_ROOT. 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Use AC_CONFIG_AUX_DIR(../..). Add AC_PROG_RANLIB. 2002-06-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: RTEMS_TOP(../../../..). AC_CONFIG_AUX_DIR(../../../..). Remove RTEMS_CANONICAL_HOST. Use RTEMS_ENV_RTEMSCPU. Add AC_PROG_RANLIB. * include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * include/Makefile.am: Include $(top_srcdir)/../automake/*.am. * include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * Makefile.am: Include $(top_srcdir)/../automake/*.am. ACLOCAL_AMFLAGS = -I ../aclocal. * src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/Makefile.am: Include $(top_srcdir)/../automake/*.am. 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS. 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * include/rpc/Makefile.am: Use 'PREINSTALL_FILES ='. 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * include/rpc/Makefile.am: Apply include_*HEADERS instead of H_FILES. 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. 2000-10-30 Joel Sherrill <joel@OARcorp.com> * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * src/rpc/Makefile.am, src/rpc/auth_time.c, src/rpc/clnt_simple.c, src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/clnt_unix.c, src/rpc/get_myaddress.c, src/rpc/pmap_clnt.c, src/rpc/pmap_getmaps.c, src/rpc/pmap_getport.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c, src/rpc/svc_tcp.c, src/rpc/svc_udp.c, src/rpc/svc_unix.c: Use of _read, _write, and _close as macros conflicted with newlib's use of these as routine names. They were renamed to include "_RPC_" prefix. 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. 2000-09-22 Joel Sherrill <joel@OARcorp.com> * src/xdr/xdr_float.c: Added A29K support. 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * src/rpc/Makefile.am, src/xdr/Makefile.am: Include compile.am 2000-08-10 Joel Sherrill <joel@OARcorp.com> * ChangeLog: New file.
* 2002-07-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-306-55/+26
* 2002-07-23 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-232-1/+5
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-223-2/+7
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-221-3/+1
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-222-2/+6
* 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-052-1/+5
* 2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-012-2/+4
* 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-272-1/+7
* 2002-06-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-2510-44/+44
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2810-10/+16
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-0/+44
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-112-0/+7
* 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-282-1/+5
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-052-2/+10
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-092-1/+5
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-022-1/+5
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-3116-36/+50
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-252-1/+6
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-222-0/+5
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-054-1/+7
